AV8ORJWC
Posted: Mon Jan 15, 2007 2:48 pm Post subject: Firewall covering |
Chris - as I was reviewing your website for cowl information and
pictures to balance with Deems great work, I noticed that you and
Bethany have a page on your website
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Firewall%20Pa
inting.html that uses some interesting product. Can you expound with a
new thread?
John Cox
#40600
Chris Johnston wrote:
<CJohnston(at)popsound.com>
Hey Deems -
Are you using the plenum? I've not really decided, and was wondering
if
| Quote: | others had thoughts about it. I don't know much about the mechanics of
it, but it seems like it'd improve cooling etc. Also it (I guess)
would
| Quote: | reduce stress on the cowl and attachments, as the plenum is pressurized
and not the entire cowl. Am I incorrect here? What about inspecting
the engine through the oil filler hole? You wouldn't see the top of
the
| Quote: | engine there - is that a bummer? Also, doesn't the engine get hot
where
| Quote: | it gets close to the plenum? Is this a problem? I'd love any info
before I go calling Sam about it.
cj
#40410
fuse
>Just thought I'd chime in here - I just sent my check off for my Sam
>James RV-10 Cowl, and I do have my standard cowl here as well, so when
>the new cowl comes I'll give a pirep and snap some pics illustrating
>the differences in quality and shape. I got the RV-10 cowl for the
>standard, not the cold air induction. We'll see.
>cj
>#40410
>fuse
CJohnston(at)popsound.com Guest
Posted: Mon Jan 15, 2007 4:34 pm Post subject: Firewall covering |
Sure.
Well, I do a lot of research when it comes to airplane building, and
frequently, my history with race cars comes to my aid. When you think
about it, a race car and an aircraft have similar needs. It needs to be
light and strong, you want to keep your fluids where you put them, and
much of the time, you battle heat issues. So when people started
talking about the infamous "tunnel", I started listening. I considered
and rejected a bunch of things (foil backed graphite sheets, etc.) and
finally found this stuff.
http://www.lizardskin.com/pages/ceramic.php
I called "the guy" over there, and he seemed to know what he was talking
about. I took notes at the time, but I've since lost them. The point
was that the paint is thick, it dries VERY lightweight, and it
apparently does a good job of rejecting heat. It also kind of seals
little voids which is an added plus. I also took note of this page of
the website:
http://www.lizardskin.com/pages/testimonials4.php
So there it was. It seemed to fit the bill, and I'll also use some
mylar faced fiberglass race car insulation on the firewall and in the
tunnel to add a bit more to the insulating properties. Initially, I
thought I'd just use it in the tunnel area under my false floor, and
under the pilot/copilot floor as shown here
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Tunnel%20Modi
fication.html
but after thinking more about it, I decided to do the firewall as well.
The pros are basically that it's supposed to reduce the temp in the
cabin, and seal the firewall a bit extra (I also did firewall sealant
around the seams and nutplates). It sticks well to everything, and it's
very light. It's also water soluble and paintable. The cons? Well the
paint isn't smooth after you apply it. it's so thick, that it's got
kind of a car undercoat texture. It's very messy to apply. You must
mask very well and very carefully. Also, you must peal the mask before
the paint fully dries. It uses a special gun that you have to buy.
There's no way you could spray it with a normal gun. No way. Also, I
suppose for inspections, you can't pull it away from the firewall to see
the condition of the shop heads and stiffeners. I decided that I'd be
ok with that, as long as I could still see the steel engine mount
thingys at the corners of the firewall. So in the end, I masked those,
and the rivet lines for the forward fuse deck, and the attach point for
my parking brake, and painted the rest. I might also paint the
underside of the false floor I built in the tunnel after I get the
brackets riveted to it.
As an aside, don't get to thinking that the sound deadening stuff on the
lizard skin website is going to be your friend, because it's REALLY
heavy.
Hope that answers any questions.
cj
#40410
fuse
AV8ORJWC
Posted: Mon Jan 15, 2007 5:18 pm Post subject: Firewall covering |
Thanks for the great post.
A comment. Dan Newland who specializes in fire suppression blankets
reminded me that one of their company's products ORCON must be removable
during the conditional inspection to search for corrosion. A result of
condensation from moisture in air vapors. When foam material is glued,
it is real bear to tear off to effect such a corrosion inspection. On
our airline birds, the suppression batting gets soaked and is impossible
to dry out effectively. We have to throw it away and you would then
know why tickets are so expensive if you saw the cost. The amount of
corrosion that forms from the condensate.... WOW.
The idea of a product which covers the aluminum skin and may also
provide corrosion protection is of value. I don't know the answer but I
will do some digging. I know they say in their marketing that it does
protect the surface.
The Question. Their site mentions MSRP of $189.00 for a 2 gallon
container. How much did you use? Is the residual available for
purchase. Bethany had a blue paste in one picture but then it looked
dark grey on drying. Should we pursue a group buy and divvy it up like a
Coop?
John Cox
#600
Posted: Mon Jan 15, 2007 6:02 pm Post subject: Firewall covering |
I'm not sure how much I used, but there's got to be over a gallon left.
It was expensive (paint and gun system), but I was willing to give it a
try. I was kind of reserving judgment til I got flying so I could see
what the real poop on it was, as it's kind of a commitment to go
squirting some unknown quantity all over the inside of your airplane. I
didn't want to bring it up then figure out that it sucked, basically.
However, if others feel like taking the plunge right along with me, I'm
willing to pass around the gun system and the leftover paint to whoever
wants to use it. I just want to be clear up front that yes, I think it
should work, yes it looks like it should work, yes, I'm happy with my
results (untested as they may be), but I don't KNOW that it is as neato
as I think it is. One test that I've been meaning to do is just get my
heat gun out and heat up the engine side with it while touching the
interior side with my hand. Not too scientific, but I don't have an IR
temp gauge to use. I'll check it out this evening and report back.
But back to the question, I really don't see the need for others to go
buying this special gun when this is the only thing you'll ever use it
for. We'll just pass it around to whoever wants to check it out - it
only takes a day to squirt the stuff. Let me know if you want to, maybe
just cover shipping to you. I'm willing to throw a tool and some
leftover paint in the pot if it's helpful to other builders. I expected
it all to just collect dust in my garage anyway...
Oh - yea, it looks purplish while you're mixing it (you have to mix with
a drill driven paint mixer for a couple minutes til it looks smooth) but
dries a flat chalky black. Also, it's pretty tough stuff. It doesn't
flake or chip easily.
cj
#40410
fuse
lm(at)viscomvisual.com Guest
Posted: Mon Jan 15, 2007 10:52 pm Post subject: Firewall covering |
There is another product from 'Super Soundproofing' named "Sound Damping
Liquid" that seems to have similar properties. Question: Has anybody used
this? What are the pros and cons to 'LizardSkin'? The spray gun seems to be
a lot cheaper and material about the same.
http://www.soundproofing.org/sales/liquid.htm
Lorenz.
#40280
[quote] --
rvbuilder(at)sausen.net Guest
kearney(at)shaw.ca Guest
Posted: Wed Jan 17, 2007 10:37 am Post subject: Firewall covering |
Hmmm
Wouldn't a Soob be lighter and quieter?
Cheers
Les (who is now looking for a Nomex suit!).
armywrights(at)adelphia.n Guest
Deems Davis
Posted: Thu Jan 18, 2007 8:43 am Post subject: Firewall covering |
Brian Sutherland http://www.mykitlog.com/rv10builder installed this on
his -10, you can find it on his website. I'd contact him directly for
any questions.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Rob Wright wrote:
Rick S.
Posted: Thu Jan 18, 2007 10:46 am Post subject: Firewall covering |
Rob,
I'm using it. I saw it on Nextel cup cars firewalls first, Koolmat even recommends it on thier site. My install is just like Brian's. I cutout the engine mount areas but put the heat boxes on top of the mat. I was surprised at the weight, it was heavier than I expected about 4 lbs I guesstimate but it will hold off the heat and fire if it performs as Koolmat states. I am using dots of Red RTV to attach at the perimeter to allow the cover to be removed for corrosion inspection annually. It's nice looking material and I could not get it to burn with my propane torch, take the flame away and it just turned black.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Thu Jan 18, 2007 9:00 pm Post subject: Firewall covering |
I'm unfamiliar with the corroding properties of stainless, since we all talk
about the ALCLAD stuff so much. Any quick tidbits?
Rob
patrick.pulis(at)seagas.c Guest
Posted: Thu Jan 18, 2007 9:32 pm Post subject: Firewall covering |
Rob, stainless steel comes in many grades, however the 'anti-corrosion'
properties are achieved by alloying the steel with chromium and other
metals and the fact that the resulting metal produces and extremely hard
oxide layer (aluminium has the same hard protective oxide layer) which
gives the ultimate protection.
If this oxide layer doesn't form or cannot be maintained as would be the
case when air is excluded from the surface, then the presence of
moisture will allow corrosion to occur.
Try wrapping a thin rubber band tightly around a small piece of
stainless and submerge it in water for a week. You'll notice that
corrosion soon forms where the rubber band contacts the edges of the
stainless, however the rest of the surface is otherwise sound. That's
because the rubber band stops any air from reaching the steel and
degrades the formation of the protective oxide layer over the surface of
the metal.
If the rubber bad is tight enough, it will eventually start eating its
way into the steel from either side where the rubber band touches the
steel.
So the aim is to ensure that stainless has access to airflow in order to
ensure that the protective oxide layer is maintained. I hope this
helps.
Patrick Pulis
#40299
Downunder in the lovely warm summer weather of Adelaide, South Australia
DO NOT ARCHIVE
