		kitfox(at)bresnan.net Guest
				 Posted: Sun Dec 31, 2006 7:51 pm    Post subject: rims |
				Would any one on the list have a set of alum 8" rims that fit the
  KF model 1 in their hanger or garage , they would be willing to
  sell ?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Dwayne
				 Posted: Tue Jan 09, 2007 9:43 pm    Post subject: Re: rims |
				I believe that Douglas Wheel still make the ones that you are talking about and they're pretty inexpensive. You will have to fabricate and weld the blocks for the rotors though. They were around $30 a while back.
		dave
				 Posted: Wed Jan 10, 2007 7:33 am    Post subject: rims |
				Dwayne , thank you for that and it you can find them for 30$ let me know.
 I am going to put on the new tires on existing rims this week I hope.
 Incase anyone her has done them and got tips -- let me know.
 breaking the bead on the old tires is always tough.
 Dave
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Tom Jones
				 Posted: Wed Jan 10, 2007 7:47 am    Post subject: Re: rims |
				Dave,
 I fought with trying to break the bead on the old tire on the rim for a couple of hours then gave in and took it to the tire store to have them dismount the old tire and mount the new King Fox tire on the rim.  I had him put the tube in the new tire too.  They look pretty cool!
 I was afraid of bending that aluminum wheel if I got to wild with it.
 Tom Jones
		rexinator(at)gmail.com Guest
				 Posted: Wed Jan 10, 2007 8:04 am    Post subject: rims |
				Dave
  I haven't changed tires on my Kitfox yet, but I've changed many tires
 on motorcycles and cars professionally. Motorcycle rims are of course
 much more related to use similar techniqes since I usually do them with
 only hand levers. I just recieved a set of those smooth tires from Mippi
 Ultralights and I'll eventually do it when the tires I've got are worn
 enough.
  I can offer advice for technique which should work for all rims. If
 someone else who has experience with the Kitfox rims responds with good
 information then use that. If not give me a shout and I'll write you
 some steps to follow.
 Rex Hefferan
 Colorado
 M2/582
 dave wrote:
  Dave
		kitfoxmike
				 Posted: Wed Jan 10, 2007 8:52 am    Post subject: Re: rims |
				what I did to break the bead on my tires when I changed them last was to let all the air out(dah!) and then take my car and drive over the edge(close to the rim), poped the bead real nice and easy.
		Fox5flyer Guest
				 Posted: Wed Jan 10, 2007 9:22 am    Post subject: rims |
				Dave, my advice would be to take them to an ATV shop to remove the tires.
 They have the right equipment and damage to the wheels is minimized.
 Having new lugs welded on new wheels isn't a big deal, but you'll probably
 need to spin them on a lathe to ensure trueness when the rotors are mounted.
 Deke
		lcfitt(at)sbcglobal.net Guest
				 Posted: Wed Jan 10, 2007 11:46 am    Post subject: rims |
				Rex,  I would like to hear your tips.  These puppies are tough to break the
 bead.  I damaged one of my rims using a mechanical bead breaker - actually
 it was the hub that was damaged.
 Lowell
		dave
				 Posted: Wed Jan 10, 2007 12:29 pm    Post subject: rims |
				Rex,
 Would be more than happy to hear your input.
 I have done ATV ones as well and I know they are ral tough to get tbe bead
 over the bead lock rib.
 I might screw up the rims  but i am going to look at it and make a tool to
 break the bead .
 If i screw it up  I will be looking fora wheel soon : (
 If I am  successful , well I will share as well.
 Hopefully the latter.
 Dave
		Float Flyr
				 Posted: Wed Jan 10, 2007 2:16 pm    Post subject: rims |
				I used to break the bead by driving over the sidewall of the tire with
 another vehicle.  Just be sure not to drive over the rim itself.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		brianm(at)snolab.ca Guest
				 Posted: Wed Jan 10, 2007 2:58 pm    Post subject: rims |
				Hi
 The method I have been using for years to break tire beads is to place the
 jack base on the side wall next to the rim then simple jack the jack. As you
 try to lift your truck the base pushes downward harder and harder breaking
 the bead most times on the first try.
 This works much better if using the old style bumper jack or similar.
 Hope this helps
 Brian
				 Posted: Wed Jan 10, 2007 3:14 pm    Post subject: rims |
				OK here goes with my advice to change tires. Obviously these are similar
 to ATV rims and a good dealer may do it properly, but most do not
 garrantee that no damage will occur. Since many of us are DIY types we
 can enjoy the process if it doesn't get too aggravating. Changing tires
 can do that so I'll stress the most important tips. TIP NUMBER ONE:
 THINK EACH STEP THROUGH BEFORE YOU START IT AND IMAGINE WHAT MIGHT GO WRONG!
 Breaking the bead is expected to be tough.
  Kitfoxmike has a good suggestion using a car to break the bead loose
 from the rim. Of course you will want to protect the rim from scratches
 so place it on something like a floor mat. First try to wedge the tire
 in place under the car tire.  I suggest someone to drive the car slowly
 while you hold the rim and let the car tire approach the kitfox tire/rim
 so as to entirely miss the rim (this may seem obvious, but advice like
 this shouldn't allow anything unsaid.) What you are wanting to do is
 pinch the tire just enough accomplish the task. This might best be done
 in small "bites". You may not need to drive onto the maximum amount of
 kitfox tire to get it done. Make sure that both sides of the rim are
 loose before going on to the next step.
 If this doesn't work, here's what we do when we get a motorcycle flat
 out in the boonies to break the bead while on the side of the trail. Use
 the kick stand and lean the weight of the motorcycle at the edge of the rim.
  You may want to get 2 or 3 tire levers from a motorcycle shop to work
 the tire off the rim. Place the wheel on the floor mat and get ready to
 remove the tire from the rim.There are also accessories called rim
 protectors which may help protect the rim from tire lever damage. The
 biggest advice here is: TIRE LEVERS SHOULD ONLY LEVER SMALL SECTIONS OF
 BEAD AT A TIME. Use a very small amount of dishwashing liquid in water
 to lubricate the tire bead only just where it will roll over the rim.
  MAKE SURE YOU HOLD AS MUCH BEAD INTO THE LOWEST AREA OF THE INTERIOR OF
 THE RIM WHILE YOU LEVER THE OTHER SIDE OF THE BEAD A LITTLE AT A TIME
 OVER THE OUTSIDE OF THE RIM. You should be knelling with your knees
 holding the tire beads in position.  Position the "spoon" of a lever
 under the lip of the rim and hook  under the bead. Try to fit 2 levers
 side by side near each other (maybe an inch or 2 apart) and move one
 lever at a time to work the bead off the rim. Once you get the second
 lever rotated and i'st part of the bead over the rim you should be able
 to pull the first one free and position it on the other side of the
 second one just as close to it as you can to minimize the amount of bead
 you are attempting to lever off the rim. SMALL "BITES" is the rule here.
 Otherwise you risk bending the rim. You should not need to put very much
 force on each lever each time you rotate it over the rim edge. If you
 are having to grunt you probably aready bent a rim.
  Putting the new tire on the rim is usually much easier. Turn the spoon
 of the lever around to hook under the inside of the rim instead of the
 bead. Always  check that you have as much bead in the lowest part of the
 wheel as possible whether mounting or unmounting a tire.
 Good Luck and if it gets to be too much of a challenge it's better to
 seek professional help.
  I'll be out of contact until Thursday afternoon.
 Rex
 Colorado
 dave wrote:
  Rex,
  bead over the bead lock rib.
  tool to break the bead .
  Dave
		Malcolmbru(at)aol.com Guest
				 Posted: Wed Jan 10, 2007 3:26 pm    Post subject: rims |
				I had to cut the tire off with a knife and chisel and put some antisez to  stop it from happening again mal
		smokey_bear_40220(at)yaho Guest
				 Posted: Wed Jan 10, 2007 4:34 pm    Post subject: rims |
				What my father used to do with tubless tires was take
 out the valve stem and hook a vacuum pump to it.
 For tube tires, using the jack to press down on the
 tire just missing the rim was the most controlled
 method he used.
 Haven't had to change mine yet....
 Kurt S.
 --- kitfoxmike <kitfoxmike(at)yahoo.com> wrote:
  	  | Quote: | 	 		   what I did to break the bead on my tires when I
  kitfoxmike
		tleiss(at)earthlink.net Guest
				 Posted: Wed Jan 10, 2007 6:11 pm    Post subject: rims |
				I took my rims to my local golf course maintenance shop,  They have a tire
 machine for the small rims. The guys there were happy to help. Took off the
 old tires, I took the rims home and polished them and a few days later
 brought them back and they put the tires back on.  They wouldn't even let
 me buy them a beer. I did try.
 Todd Leiss
 Model IV Speedster 912UL
  	  | Quote: | 	 		   [Original Message]
  From: kurt schrader <smokey_bear_40220(at)yahoo.com>
  Date: 1/10/2007 7:39:04 PM
  Subject: Re: Re: rims
  method he used.
  Kurt S.
  > kitfoxmike
  > Do not archive
				 Posted: Wed Jan 10, 2007 7:14 pm    Post subject: rims |
				I was rushed to finish my previous post about tire changing and failed
 to remember to include the tube removal and replacement. As it turns out
 I had a change in plans and I'm back in range of the internet.
  The tube procedure is pretty simple so shouldn't cause much problem.
 Here is what I should have included.
  After working one side of the tire off the rim you then reach inside
 the tire and remove the tube. There may be a nut that holds the valve
 stem to the rim, if so you must remove it first.
  Installing a tube is the reverse of the removal steps.  There can be
 difficulty with some motorcycle tires in being able to manipulate the
 valve stem into the hole in the rim through the small gap between the
 rim and the tire bead. I don't expect this problem with the kitfox rim
 and tires. Others with experience will have to advise us of their
 experience.
  Some others have posted the use of a vehicle jack to act as a bead
 breaker and that is a great solution which I forgot about. There is the
 stated problem that they are not the style typical of most cars now days.
  I hope I've remembered the procedure completely and this helps folks
 enough to ease the process. I'll try to find the time soon to change a
 Kitfox tire myself and refine these instructions. Then I'll post it to
 the Kitfox Wikipedia and include photos. Meanwhile I'll check my email
 several times a day in case anyone would like any clarification. Just
 send me or the list your question.
  I've done a page a few years ago showing an easier and quick way to
 replace certain motorcycle fork seals without the special tools normally
 needed. Here's a link to that if anyone is interested in what the
 instructions might resemble.
 www.klr650.marknet.us/*Fork*_*Seal*s.pdf
 Rex
 Colorado
		HBN(at)srnet.com Guest
				 Posted: Sat Jan 20, 2007 7:54 am    Post subject: rims |
				DeWayne--
      If you are still needing rims, I have a  pair from a Model III which I believe are the same ones used on the Model I. The  Parts List describes the wheels as P/N LW-27R, 8" diam., 6" wide. The hubs, P/N  LHH-14, are included, and have the bearing races, P/N LGBH-18 installed.The  wheels do have the Brake Disc mounting pads welded on. If you can use them I  would be happy to send them for $25 plus shipping.
          Harold  Nelson
  [quote]Do not arhive[b]
		akflyer Guest
				 Posted: Sat Jan 20, 2007 8:20 am    Post subject: Re: rims |
				If he does not want them I will take them...
 Leni
		henrysfork1(at)msn.com Guest
				 Posted: Sat Jan 20, 2007 8:49 am    Post subject: rims |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Let me know if DeWayne is not interested as I would be, Thanks
  Dee
  [quote]   ---
		akflyer Guest
				 Posted: Sat Jan 20, 2007 8:53 am    Post subject: Re: rims |
				time for a bidding war lol...
