		4rcsimmons(at)comcast.net Guest
				 Posted: Mon Jan 22, 2007 7:48 am    Post subject: Dzus Clips in Wing Lockers |
				Ok list,
  Another question!
  The Dzus clips as we show have nothint to retain them. This will tned to runaway clips.
  In theory, there is to be no space between the Locker and the I think Dzus rails is how they are labeled.
  The retention devices I see all take up considerable space and will raise the locker and it will no longer be flush.
  What are some of you using to retain the Dzus clip that keeps the lid flush to the Top Skin.
  Don not archive
 Rich Simmons
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gig Giacona
				 Posted: Mon Jan 22, 2007 8:04 am    Post subject: Re: Dzus Clips in Wing Lockers |
				Here are the ones I used they are very thin.  http://www.aircraftspruce.com/catalog/hapages/snaprings.php
 SR5SS
 It is as flush as it needs to be.
  	  | 4rcsimmons(at)comcast.net wrote: | 	 		  Ok list,
  Another question!
  Don not archive
 Rich Simmons
  [b] |
601XL Under Construction
				 Posted: Mon Jan 22, 2007 8:58 am    Post subject: Dzus Clips in Wing Lockers |
				Hi Rich,
  I used the little Dzus retaining rings - from Aircraft Spruce.  They don't actually cause any problems with seating of the baggage door.  They take up space already available in the hole in the strip.
  Paul
  XL fuselage
  At 07:47 AM 1/22/2007, you wrote:
  [quote]Ok list,
  Another question!
  Don not archive
  Rich Simmons
		daveaustin2(at)can.rogers Guest
		agbeyer(at)sbcglobal.net Guest
				 Posted: Mon Jan 22, 2007 3:30 pm    Post subject: Dzus Clips in Wing Lockers |
				Hi Rich,
  This same question came up a month or two back.  I wrote, what I did was make the holes a little larger for easyer alighnment of the Dzus fasteners.  The holes were too large for the standard Dzus Clips, so I used small "O" rings that fit the groove of the fastener.  It's simple and works great.
  Al from Oshkosh
  601 HDS
		naumuk(at)alltel.net Guest
				 Posted: Mon Jan 22, 2007 3:38 pm    Post subject: Dzus Clips in Wing Lockers |
				Al-
      Good tip on the O rings. I have  the ACS retainers and they keep coming off.
      No matter what, the main secret  to installing Dzus is to have plenty of clearance for the major diameter. Rather  than wrench the springs up and down to fit different heights, I went with  different length Dzus. They're cheap enough.
  Bill Naumuk
 HDS Fuselage
 Townville, Pa
  [quote]   ---
