		CJcanuck
				 Posted: Tue Jan 23, 2007 10:44 am    Post subject: Winter Ops |
				I'm hoping to go out to BC in the next few weeks and collect my new CJ  .  With that in mind I'm looking for any techniques on winter ops and/or cold wx engine management techniques that anyone might be able to provide.
 Questions like; Proper use of cowl gills to avoid shock cooling of cylinders during runup/takeoff/letdown?  Any issues with the pneumatics during prolonged cold soaking, such as frozen water separators or brakes?  Part of my trip home takes me through the Rockies and the higher elevation airfields in Alberta,  any special considerations in powerplant management at these fields?
 Thanks in advance!
		rvfltd(at)televar.com Guest
				 Posted: Tue Jan 23, 2007 12:44 pm    Post subject: Winter Ops |
				Mark,
 Other than the insulated cowl blanket that you have already ordered, I
 might suggest installing the oil cooler winterization kit.  This kit has
 a movable door that installs in the oil cooler duct.  In winter some
 CJ's are nearly impossible to keep the oil in the green at altitude on a
 cold day, this kit solves the problem and also comes with a FOD screen
 to keep junk out of the oil cooler duct.  A bit more on the insulated
 cowl blanket, if you sew Velcro on to a few spots on the inside where
 the insulated blanket fits against the lower cowl and install 2 of the
 110 volt heating pads it really makes a huge difference IF you have
 access to electricity it will work wonders.
 I have a hunch that at the temps you will be operating in your shutters
 will be closed most of the time.  Do you have a heater of any kind?  Are
 you traveling alone?  If you are use duct tape to tape all the seams on
 the rear canopy closed, the majority of all the cold air coming into the
 cockpit comes in under the rear skirt of the rear canopy.   In the nose
 and main gear wells there are many holes that you can tape up to stop
 the cold air also.
 Give me a call (at) 509-826-4610 if  you need some more info on any of the
 above.
 Always Yakin,
 Doug
 CJcanuck wrote:
 Thanks in advance!
 Alcohol!  The cause of, and solution to, all of man's problems!
 http://forums.matronics.com/viewtopic.php?p=89800#89800
		steve.fox(at)mac.com Guest
				 Posted: Tue Jan 23, 2007 1:12 pm    Post subject: Winter Ops |
				Mark-
 You may also want to see if you can track down a winter flight suit
 - CWU- 64/P or plan on wearing a snow mobile one piece suit. Even if
 you have heat, it's going to be cold. I just flew this weekend and my
 YAK has heat, but after about 30 minutes in -10F my feet and lower
 back really started feeling the cold.
 Steve
 On Jan 23, 2007, at 3:42 PM, Doug Sapp wrote:
  Mark,
  ordered, I might suggest installing the oil cooler winterization
  kit.  This kit has a movable door that installs in the oil cooler
  duct.  In winter some CJ's are nearly impossible to keep the oil in
  the green at altitude on a cold day, this kit solves the problem
  and also comes with a FOD screen to keep junk out of the oil cooler
  duct.  A bit more on the insulated cowl blanket, if you sew Velcro
  on to a few spots on the inside where the insulated blanket fits
  against the lower cowl and install 2 of the 110 volt heating pads
  it really makes a huge difference IF you have access to electricity
  shutters will be closed most of the time.  Do you have a heater of
  any kind?  Are you traveling alone?  If you are use duct tape to
  tape all the seams on the rear canopy closed, the majority of all
  the cold air coming into the cockpit comes in under the rear skirt
  of the rear canopy.   In the nose and main gear wells there are
  many holes that you can tape up to stop the cold air also.
  the above.
  Always Yakin,
  Doug
 > Thanks in advance!
		dave(at)davelaird.com Guest
				 Posted: Tue Jan 23, 2007 5:28 pm    Post subject: Winter Ops |
				I've often wondered if heated motorcycle clothing would help in the
 winter...
 like the stuff here:
 http://www.gerbing.com/
 I have no idea what the current load is.... but even if you don't
 have a 12 volt output then maybe you could secure some batteries in
 the backseat somehow and run off of them....
 Dave Laird
 N63536  1983 CJ6A  "Betty"
 Dallas
 On Jan 23, 2007, at 3:12 PM, Stephen Fox wrote:
  Mark-
  suit  - CWU- 64/P or plan on wearing a snow mobile one piece suit.
  Even if you have heat, it's going to be cold. I just flew this
  weekend and my YAK has heat, but after about 30 minutes in -10F my
  feet and lower back really started feeling the cold.
  Steve
 > Mark,
 > in the green at altitude on a cold day, this kit solves the
 > problem and also comes with a FOD screen to keep junk out of the
 > oil cooler duct.  A bit more on the insulated cowl blanket, if you
 > sew Velcro on to a few spots on the inside where the insulated
 > blanket fits against the lower cowl and install 2 of the 110 volt
 > heating pads it really makes a huge difference IF you have access
 > of the above.
 > Always Yakin,
 > Doug
 >> Thanks in advance!
