Antenna placement
rparigor(at)SUFFOLK.LIB.N
PostPosted: Tue Jan 23, 2007 10:54 am    Post subject: Antenna placement Reply with quote
Have a few questions about antenna placement for our Europa (fiberglass).
The Advanced Aircraft Electronics L2 Transponder antenna came with a piece
of balsa to mount it on. What is idea here? Bond the antenna to balsa,
then balsa to fiberglass?
As far as the fore and aft position of Transponder antenna, 2 available
positions are ~ 5 feet behind pilot, or ~ 8 feet behind pilot. 5 feet will
allow a slight lower position in flight, but is closer to the motor. Which
choice is preferable of the 2?
As far as the left and right position of the transponder antenna, there is
an ~ 2" thin wall aluminium pitch tube running fore and aft. I could mount
the antenna direct under this tube by ~ 2" that would make for a
friendlier movement about. Or I can displace it to one side 6 (8 feet) or
12 inches (5 feet). What would preference be?
I will have Advanced Aircraft Electronics 5T antenna mounted just behind
the baggage bay bulkhead. It will be powering a Vertex 700 panel mounted
hand held. I will mount it bent 90 degrees where approx 1/2 is vertical,
and half will be on the roof horizontal(to work equal bad on both nav and
Com). Talking to Advanced they said it will provide approx 70% of the
performance on both Nav and Com compared to proper straight orientation,
and be far better than rubber ducky antenna with 90 degree bend.
Any comments from those who have done this 90 degree bend?
I want to place my ELT whip antenna (ACK EO1)vertical inside fuse, where
it will be diagonal from the center of 90 degree bend of Advanced 5T
antenna by about 18 inches.
Will this close proximity potentially cause any receive or transmit
problems for Vertex?
If I were to test the ACK and had the vertex on, could this close
proximity cause harm the the Vertex?
Other info:
Transponder antenna will be either 2 or 5 feet aft of ELT antenna
Primary Com antenna is a Bob Archer in top of rudder
Thx.
Ron Parigoris
N6030X(at)DaveMorris.com
PostPosted: Tue Jan 23, 2007 11:33 am    Post subject: Antenna placement Reply with quote
I'm only going to comment on a small part of this. As a ham operator
with a few decades of experimentation with antennas (primarily HF,
but also some VHF), I've seen most everything you can do right and
wrong with antennas.
First of all, almost nothing you have described here is going to have
a *huge* impact. The bad effects you might achieve will be
minor. When you are 50 miles from an ATC comm station trying
desperately to raise someone, the minor impacts could become more
significant, but for 99% of your flying, it won't matter too
much. So, here are a few thoughts:
Try to keep all antennas a quarter wavelength away from other metal
that is in the same plane (not airplane, geometric plane). In feet,
that's about 234 / Frequency in Megahertz. Run coax feeders 90
degrees away from the antenna as far as possible to prevent
interference. Receivers will work with any piece of wire and you'll
be able to hear *something*, but when you get the wire length exactly
right and you have no interference with surrounding metal, you'll be
rewarded with a really nice strong signal and low noise.
Putting a 90 degree bend in the antenna will screw up its SWR. That
may only affect your reception by 3db, but it could potentially cause
your solid state, computer controlled transmitter to automatically
reduce its output power. I'm not sure. You'll have to try it
out. When you're flying in New Mexico over an area where you can't
raise ATC even at 8500 feet and the terrain is fiercely hostile (for
instance here:
http://www.davemorris.com/Photos/Mooney%20N6030X%20Shiprock%20NM/IMG_2098.jpg)
, you'll want as good a transmitter as you can get. So, the question
becomes, are you going to need NAV out in the boonies more than COM,
or vice versa. My guess is you're going to have a darn nice GPS on
board, and you may never use your handheld NAV function on the
radio. So, optimize it for COM if that applies to you.
If the ELT antenna is 18 inches minimum from the COM antenna, that's
not the ultimate in separation, but it will be adequate. I doubt
you'd be able to tell the difference if you moved it a full quarter
wavelength away. It may affect the radiation lobes, causing them to
be oriented more forward and aft, and giving you less effectiveness
off the wingtips, but it will be so miniscule you probably won't
notice the difference unless you are way far from the ground
station. When you test the ELT, turn down the volume in the Vertex,
or just unplug it. It won't harm it, but you won't like the noise.
Aircraft that have a non-metal tail cone about 31 inches in diameter
can take advantage of my Morris Com Loop antenna, which is a full
wavelength loop mounted on the fuselage wall. It provides slight
gain, greater immunity to noise, and requires no ground plane.
http://www.davemorris.com/MorrisComLoop.cfm
Dave Morris
www.N5UP.com
www.N6030X.com
glastar(at)gmx.net
PostPosted: Tue Jan 23, 2007 10:17 pm    Post subject: Antenna placement Reply with quote
Ron, shape the Balsa so it conforms to the shape of your fuselage, epoxy
it to the fuselage, glue the antenna on the balsa (blades are straight)
cover blades and balsa with a layer of glass going also on the fuselage
shell.
That's what we did on several Glastar's and it worked out great.
br Werner
