Jon Reining
Posted: Tue Jan 23, 2007 3:56 pm Post subject: Cold Air Induction |
Bless me father for I have forgotten, it's been six months since I've been to Oshkosh...
With all this discussion on engine mounts, cold air incudtion and cowls (and since it has been awhile since I learned why at Oshkosh) - what does cold air induction do for you? More horsepower? Less weight? Basically, how does it work and why is it good?
If you get a Barrett Engine with Cold Air Induction, will it fit in a Holy Cowl?
If you do one or the other, or both, what is the net impact on horsepower and speed?
Jon Reining
40514 - tailcone
rvbuilder(at)sausen.net Guest
Posted: Tue Jan 23, 2007 5:15 pm Post subject: Cold Air Induction |
Yes, yes, and yes. The cold air induction basically removes the
intake tubes from the oil sump (stock configuration) which heat soaks
the incoming air. Hot air is less dense which means less HP. Barrett's
sump is also magnesium which is lighter than the stock sump. As for the
holy cowl, you need to go with the James cowl anyway which is made for
the cold air unless you want to do a bunch of work on the stock cowl ala
Gary Specketer. Figure on the credit for the stock cowl being around
$800 by the time you subtract the various parts.
Net impact, unknown at this time. The first couple of this
combination are still coming out of the gate. I believe the cowl on
something like an RV-4 gains you about 10 mph and the cold air induction
is good for around 10 ponies.
Michael
Deems Davis
Posted: Tue Jan 23, 2007 5:21 pm Post subject: Cold Air Induction |
Standard Lycoming induction has the induction air routed through the oil
sump, the result is that the air intake to the cylinders is heated by
the surrounding oil in the sump. Cold Air Induction takes ram air and
routes it directly to each cylinders intake bypassing the oil sump. this
requires a custom oil sump and hence the recent discussion. If you
remember your pilot training, Cold air is more dense and produces a
stronger air charge going into the cylinder, which results in more
manifold pressure and more power (OOPS there I go again hot rodding!).
Its kind of like putting a booster on your engine without adding any
moving parts. Free power (well almost free) !. The answer as to does it
add horsepower depends on who's asking, but I'm VERY happy with the
results of my Dyno run !
Less weight : marginally but not enough to be concerned with.
Holy Cowl fit : Will James has made an RV-10 lower cowl that fits the
BPE Cold air induction. He also has the Holy cowl for standard induction.
Net effect: Horsepower increases, Allen can tell you how much if you
contact him. All things being equal speed should increase, but it takes
a lot more ponies to equal 1 additional knot. (I'm not sure what the
ratio is but it's definitely NOT 1:1. Since there are no RV-10's flying
with cold air yet there are no performance numbers to report only
'hopes'. Perhaps later this year.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Jon Reining
40514 - tailcone
http://forums.matronics.com/viewtopic.php?p=89901#89901
cloudvalley(at)comcast.ne Guest
Posted: Tue Jan 23, 2007 7:00 pm Post subject: Cold Air Induction |
Hello, We are nor anywhere near the engine stage yet, but my wife and I would like to know if Vans will give you credit on their cowl, if one decides to get a Holy Cowl. Also, how do you get in touch with Will James. Thank you.
Brian and Ruth Preston
#40666
> ; movi ng parts. Free power (well almost free) !. The answer as to does it
[quote] add horsepower depends on who's asking, but I'm VERY happy with the
Deems Davis # 406
Jon Reining wro te: [b]>
>--> RV10-List message posted by: "Jon Reining"
Oshkosh...
Cowl?
speed?
>Jon Reining
>40514 - tailcone
>Read this topic online here:
>http://for ums.ma >>
Deems Davis
Posted: Tue Jan 23, 2007 7:12 pm Post subject: Cold Air Induction |
Yes, Van's will give you a credit.
Try this: http://www.jamesaircraft.com/
Deems Davis # 406
cloudvalley(at)comcast.net wrote:
Quote: | Hello, We are nor anywhere near the engine stage yet, but my wife and
#40666
Posted: Tue Jan 23, 2007 7:22 pm Post subject: Cold Air Induction |
Yes, they will credit you for anything you want to delete from the kits including the cowl. They do tell you if you order the cowl after the fact expect the price to be a great deal higher. Makes sense as it keeps them from having to deal with people that change their minds after it shipped. As I said earlier, it’s about an $800 difference.
You can get in touch with Will at www.jamesaircraft.com.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cloudvalley(at)comcast.net
Sent: Tuesday, January 23, 2007 9:00 PM
Subject: Re: Cold Air Induction
#40666
> Deems Davis # 406
> Jon Reining wro te: >
> Oshkosh...
> Cowl?
> speed?
> >Jon Reining
> >40514 - tailcone
> http://www.matronics.com/Navigator?RV10-List | 01234
AV8ORJWC
Posted: Wed Jan 24, 2007 7:21 am Post subject: Cold Air Induction |
Mike do you want to amend the below answer regarding Oregon Aero seats?
John Cox
#40600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Tuesday, January 23, 2007 7:21 PM
Subject: RE: Cold Air Induction
Michael
Posted: Wed Jan 24, 2007 7:47 am Post subject: Cold Air Induction |
Good point. I’m guessing that would also apply to things like spars. J
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Wednesday, January 24, 2007 9:21 AM
John Cox
#40600
Michael
Tim(at)MyRV10.com Guest
Posted: Wed Jan 24, 2007 8:12 am Post subject: Cold Air Induction |
I think John is right that they may not want to eliminate the
seats for you. That said, those seats are surprisingly
extremely comfortable and far nicer than I would have imagined
when you're on long trips. My story is that I flew all the
way to Oregon and borrowed a fellow -10'ers fully decked
leather suburban for some sightseeing. The seats in the
-10 were way more comfortable after a few hours than the
nice seats in that truck. They're more comfortable than
my couch or recliner or office chair too. Having spent
192+ hours in them, I'm certainly glad I didn't try to
buck that price and do something different.
John W. Cox wrote:
Quote: | Mike do you want to amend the below answer regarding Oregon Aero seats?
*/John Cox/*
*/#40600/*
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *RV Builder
(Michael Sausen)
*Sent:* Tuesday, January 23, 2007 7:21 PM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Cold Air Induction
<http://www.jamesaircraft.com>.
Michael
AV8ORJWC
Posted: Wed Jan 24, 2007 6:49 pm Post subject: Cold Air Induction |
As an adjunct to the comments about Cirrus as an alternative to a
$250,000 Van improved kit. You will find from most Cirrus pilots that
their seats are not as comfortable as VANS. With the handle
modification, I think it is a safe and reasonable feature.
The seat war was a long time ago from a distant galaxy.
John Cox
deej(at)deej.net Guest
Posted: Wed Jan 24, 2007 7:44 pm Post subject: Cold Air Induction |
John W. Cox wrote:
Quote: | The seat war was a long time ago from a distant galaxy.
*waves hand slowly* These ARE the seats you are looking for...
-Dj
Posted: Thu Jan 25, 2007 5:51 am Post subject: Cold Air Induction |
*waves hand slowly* You don't want those aftermarket parts.
ROFLMAO
