		cookwithgas(at)HOTMAIL.CO Guest
				 Posted: Fri Jan 26, 2007 11:41 am    Post subject: 601XL "Tail Number" Opinion Poll |
				Guys:
 I registered my tail number some time ago (N5SL) and now I'm ready to stick
 it on the airplane.  I got the black, 3", pre-spaced numbers from Aircraft
 Spruce.  Here's where I'm having trouble making a decision:
 Even though it is called a "Tail Number" I've noticed a lot of 601's have
 the numbers on the fuselage below the longerons.  Please reply with where
 you think the numbers ought to be and why.  I located a few examples below
 to help make the decision:
 Tail:
 http://www.zenvair.com/jannakos1.jpg
 http://www.zenithair.com/zodiac/pic06/b-carlson.jpg
 http://www.zenithair.com/zodiac/pic06/8190003.jpg
 Fuselage:
 http://www.zenvair.com/ray3.jpg
 http://www.zenithair.com/zodiac/pic06/c-richmond4.jpg
 http://www.zenithair.com/zodiac/pic06/n8830c-2.jpg
 Thanks for your input.
 Scott Laughlin
 601XL/Corvair
 Polished, not painted
 Omaha, Nebraska
 www.cooknwithgas.com
 Valentine’s Day -- Shop for gifts that spell L-O-V-E at MSN Shopping
 http://shopping.msn.com/content/shp/?ctId=8323,ptnrid=37,ptnrdata 4095&tcode=wlmtagline
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Jan 26, 2007 12:28 pm    Post subject: 601XL "Tail Number" Opinion Poll |
				FAR 45.25 (location)
 http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgFAR.nsf/0/89cbae
 6ceae8fe13852566ab006bed58!OpenDocument&Click=
 TinyURL: http://tinyurl.com/yptdok
 <quote>
 Sec. 45.25
 Location of marks on fixed-wing aircraft.
 (a) The operator of a fixed-wing aircraft shall display the required marks
 on either the vertical tail surfaces or the sides of the fuselage, except as
 provided in Sec. 45.29(f).
 (b) The marks required by paragraph (a) of this section shall be displayed
 as follows:
 (1) If displayed on the vertical tail surfaces, horizontally on both
 surfaces, horizontally on both surfaces of a single vertical tail or on the
 outer surfaces of a multivertical tail. However, on aircraft on which marks
 at least 3 inches high may be displayed in accordance with Sec. 45.29(b)(1),
 the marks may be displayed vertically on the vertical tail surfaces.
 (2) If displayed on the fuselage surfaces, horizontally on both sides of the
 fuselage between the trailing edge of the wing and the leading edge of the
 horizontal stabilizer. However, if engine pods or other appurtenances are
 located in this area and are an integral part of the fuselage side surfaces,
 the operator may place the marks on those pods or appurtenances.
 <end quote>
 FAR 45.29 (size)
 http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGFAR.NSF/0/b75de9
 a6d18e489186256edf006d6cec!OpenDocument&ExpandSection
 TinyURL: http://tinyurl.com/26cclr
 All though I can't make it out from the FARs I am told that aircraft
 entering the US now (post 9/11) need to have the numbers be 12 inches high.
 Paragraph (h) seems to be related to this:
 "(h) After March 7, 1988, each operator of an aircraft penetrating an ADIZ
 or DEWIZ shall display on that aircraft temporary or permanent nationality
 and registration marks at least 12 inches high."
 -- Craig
		Gig Giacona
				 Posted: Fri Jan 26, 2007 1:37 pm    Post subject: Re: 601XL |
				If you are going to use just black 3" number put them on the tail. As short as your number is I' put them on horz.
 If someone was going to color match the numbers with a paint job I'd go with the fuselage.
 With vanity numbers like yours, and mine, I'd go with big color matched numbers on the fuse.
601XL Under Construction
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Fri Jan 26, 2007 1:43 pm    Post subject: Re: 601XL |
				If you go with the 3" numbers - I'd put them horizontally on the tail.  For myself, I'm going with 12 inch numbers on the fuselage in case I ever need to penetrate an ADIZ or cross certain international borders.
 N601TJ (reserved)
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		gboothe5(at)comcast.net Guest
				 Posted: Fri Jan 26, 2007 3:51 pm    Post subject: 601XL "Tail Number" Opinion Poll |
				An Opinion Poll? Scott you really know how to stir things up!!
 Gary Boothe
 Cool, CA
 601 HDSTD, WW Conversion 90% done,
 Tail done, wings done, working on c-section
				 Posted: Fri Jan 26, 2007 5:58 pm    Post subject: 601XL "Tail Number" Opinion Poll |
				Here's another example Scott.
 Think I obsessed over where and how for a few days too.
 Had black on aluminum for a year, then went to vinyl over paint. Your
 examples are too good to say which is better. Some either way are really
 neat!
 Take your pick and we'll respect you in the morning.
 http://www.macsmachine.com/images/completion/full/601ezrearlft.gif
 Larry McFarland - 601HDS at www.macsmachine.com
 Scott Laughlin wrote:
  <cookwithgas(at)hotmail.com>
  Guys:
  stick it on the airplane.  I got the black, 3", pre-spaced numbers
  from Aircraft Spruce.  Here's where I'm having trouble making a decision:
  have the numbers on the fuselage below the longerons.  Please reply
  with where you think the numbers ought to be and why.  I located a few
  examples below to help make the decision:
  Scott Laughlin
  601XL/Corvair
  Omaha, Nebraska
		leinad
  Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
				 Posted: Fri Jan 26, 2007 6:23 pm    Post subject: Re: 601XL |
				Scott,
 I was planning to use large numbers on the fuselage sides for the following reason.   The sides are flat ALMOST.   My plans called for the .016 side skins, and didn't know thicker skins were an option until I was past that phase of construction, and the "flat" sides don't look flat.   Painting BIG numbers on the side is one idea I have to obscure the imperfection.
 Dan
  _________________ Scratch building XL with Corvair Engine |
