kitfox69(at)earthlink.net Guest
Posted: Fri Jan 26, 2007 8:09 am Post subject: NSI Engine help. |
For you pilots flying behind NSI EA 81 engines who are having problems, I have a reference to help you.
Jay Roese in the Rochester, New York area solved my multitude of NSI Engine problems. I highly
recommend him. He has agreed to talk to anyone who needs his expertise. He has an extensive background
with Subaru engines and builds racing engines a well as rebuilds engines for car dealers. I now have a SMOOOOOTH
running Subaru engine in my MOD IV Kitfox, thanks to Jay. This not meant in any way as an advertisement, only as a help for those NSI engine owners who are having problems.
His E-Mail addrss is: phatbasstrd(at)rochester.rr.com (phatbasstrd(at)rochester.rr.com)
His Cell #: 1-585-729-5098
Floyd Johnson
kitfox69(at)earthlink.net (kitfox69(at)earthlink.net)
EarthLink Revolves Around You.
GENTRYLL(at)AOL.COM Guest
Posted: Fri Jan 26, 2007 9:02 am Post subject: NSI Engine help. |
Thanks, We need all the help we can get.
Do you have an Ellison SEF-2 on your engine and if so How much fuel pressure are you running?
asq(at)roadrunner.com Guest
Posted: Fri Jan 26, 2007 9:13 am Post subject: NSI Engine help. |
Good news Floyd! See you at 4N2 this summer.
Larry Huntley,Dundee,NY
Posted: Fri Jan 26, 2007 11:21 am Post subject: NSI Engine help. |
I am now running an EFS3A on my engine, because the 2 didn't have enough air capacity. I'm running
about 3 PSI currently, with good results.
Fox5flyer Guest
Posted: Fri Jan 26, 2007 11:28 am Post subject: NSI Engine help. |
Good to hear from you Floyd and thanks for the information. Can you tell us what some of the problems you were having with your NSI?
Deke
GENTRYLL(at)aol.com Guest
Posted: Fri Jan 26, 2007 12:11 pm Post subject: NSI Engine help. |
Do you have an EA-81?
Posted: Fri Jan 26, 2007 12:22 pm Post subject: NSI Engine help. |
Hi Deke,
Do you have a couple of hours? I would do this off line, but it will probably be valuable to other
NSI engine drivers. I'll stick to the details and spare everyone the 10 years of frustratiion.
I tore the engine down, finally, and asked Jay Roese to check it out. He was refered to me by a friend
who knows him well. The engine was apart when Jay first saw it and he had some immediate observations.
First off, the engine was advertised as having an 8.6 compression ratio. It had 7.7pistons in it. For the uninnitiated,
that means the compression ratio was 7.7:1. Next, the pistons and rods were missmatched. In other words, from
two different engines. A total NO NO. Jay next asked if the engine had been overheated? The answer was yes,
because the engine wasn't purged at NSI and their radiator was too small, which they replaced with one which
was still too small. Eventually Jay figured that out by getting engine cooling needs specs from Subaru engineers,
then took it to RIT for a flow test, where they determined that the latest NSI radiator only had 85% of the engines needed
cooling capacity. The reason he asked was that he suspected, and later varified, that the cylinders and pistons were
oval as a result of overheating.
He instantly recognized that the cam was ground into the core shaft, so that was trashed too.
At this point he took the engine back to his shop and did a through check. We completely overhauled it. Bored the
cylinders, new 8.9:1 pistons and rings, new stock cam, and anything else he deemed necessary. Basically, the
block and bearings were OK. We just replaced seals. The heads were OK and didn't need any work.
Next came the SFDI ignition abortion. Jay investigates everything! He is dedicated and very through, so he contacted
Electromotive, who supplies the modules. They told him that there is no way that system could work. The two systems
were working against each other. I decided to just use one module, base on the 30 year reliability of electronic ignition
systems on automobiles. My Decision! So far, so good.
Next, he used a exhaust computer module to check that part out. Surprise!, the NSI system is very inefficient, so he built me a
very simple tuned exhaust system. I built a carb heat unit which works well.
He determined that the air volume needs of the engine were more than the Ellison EFS2 could supply, so I opted for an
EFS3A which actually provides too much air, but that was easilly remedied by restricting the FULL OPEN throttle movement.
In a week or two, we are going to address the oil system. According to Jay, the engine is designed to run ar '0" or negative
pressure. With the oil tank where it is, it is pressurizing the crankcase to 4 to 5 PSI. Probably why I have seen some postings
here about blown seals. He is going to design a tank which fits under and behind the dry sump oil pan. I'll keep everyone posted on the results.
I'm sure there is more, but with so many changes, it is hard to remember what else we tackled.
I would urge anyone with questions to contact Jay. He will talk to you in laymans terms and you will understand what he
is telling you. I hope this helps folks having problems with these engines.
I now have about 20 hours on the engine and it is running well and has more torque than it ever had before.
Best regards, Floyd
Posted: Fri Jan 26, 2007 12:33 pm Post subject: NSI Engine help. |
Can you give us some speed and performance data relative to RPM. We need your weight and Prop Specifics to compare.
Michael Logan
Posted: Fri Jan 26, 2007 4:08 pm Post subject: NSI Engine help. |
Floyd,
What are you using for the pickups on the ignition now that you have gone to one module?
Mike
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Floyd Johnson
Sent: Friday, January 26, 2007 11:07 AM
To: Kitfox-List
Subject: NSI Engine help.
Floyd Johnson
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
_________________ Mike Logan
Fredericksburg, VA |
Posted: Fri Jan 26, 2007 6:44 pm Post subject: NSI Engine help. |
I'm currently using the new Electromotive WEDGE SHAPED pickup. It is much more precise.
I can get the part number for you, or you can go to ELECTROMOTIVE.COM and find it.
They have a complete manual for the ignition modules which you can download. It has all
the information you would need for troubleshooting etc. Be sure to download the one for your
particular module. Floyd
Fox5flyer Guest
Posted: Sat Jan 27, 2007 5:23 am Post subject: NSI Engine help. |
Thanks for the info Floyd. You sure had your share of problems.
Were you the original owner. Is it the normally aspirated or turbo?
So far so good with mine. Only a couple easily resolved minor issues
(seal, spark plug) that caused me any trouble in just shy of 400
hours. It's still configured just as it was delivered. Keep us
updated as your testing progresses.
Deke
S5
Michael Logan
Posted: Sat Jan 27, 2007 6:09 am Post subject: NSI Engine help. |
Should that be directignition.com? They are located about 50 miles north of here in Manassas, VA. I have talked to them a number of times and they are very helpful. I am not sure what you mean by the wedge shaped pickup. Is it a crank mount? If it is, what did you use for mounting the parts?
I still have the NSI system in my hangar but I am using the Real World Solutions ignition and injector system with the NSI ignition pickups. The NSI system has the toothed wheel attached to the flywheel end of the crank and the sensors are attached to the inside of the "bell housing."
Mike
Sent: Friday, January 26, 2007 9:44 PM
Subject: RE: NSI Engine help.
Michael Logan
Posted: Sat Jan 27, 2007 6:13 am Post subject: NSI Engine help. |
By the way, I hated my NSI system. It never ran smooth, did not develop power like it should and always ran very hot. When I tore the engine down, I found some "extra" parts that Lance and his crew left that blocked off some of the oil flow. I know they were extra because I was very careful in counting up all the little parts that I took out.
I had RAM engines build up an engine for me and am working on the installation now. It is a very smooth and powerful running engine, much more power than NSI.
Mike
Posted: Sat Jan 27, 2007 6:30 am Post subject: NSI Engine help. |
What are you going to have to do as far as cowl, motor mount, exhaust, etc. to go from the NSI to Ram. I am considering the sme thing
Posted: Sat Jan 27, 2007 10:39 am Post subject: NSI Engine help. |
I didn't change engines, just rebuilt the NSI. I'm using the same cowling, and modified the airscoop to direct all
the air thru the radiator.
