pj.ladd(at)btinternet.com Guest
Posted: Wed Jan 24, 2007 9:15 am Post subject: that old video |
Get to post my tired old video again!>>
Hi,
enjoyed it again too. The clip is just over a minute, how high were you
when the clip started?
Switching off the engine is a little different from having it suddenly stop.
Reaction time is different and of course you tend to switch off only when
you are confident of reaching your strip. No searching round looking for a
landing spot while your flying accuracy goes to hell. Thats what throws your
height away.
Great video
Cheers
Pat
Posted: Wed Jan 24, 2007 9:30 am Post subject: that old video |
throws your
| height away.
| Pat
Patrick:
A good pilot always has the next best forced landing area in sight.
If I may add, once a suitable forced landing area is selected, it is
usually best not to change one's mind. We have some folks on this
List that have experienced that mistake, me included.
_________________ John Hauck
Titus, Alabama |
Posted: Wed Jan 24, 2007 12:07 pm Post subject: that old video |
good pilot always has the next best forced landing area in sight.>>
Hi John,
I agree absolutely, but it is a counsel of perfection, and its that few
minutes when your attention wanders that bite you in the bum. Can any of us
say with all honesty that we know where you will land if it goes quiet NOW
100% of the time.. Some of the stuff you fly over and some of the
extensive woodland that some listers have produced pics. of are pretty short
of choices.
I agree also about not changing your mind although in my couple of `outs` I
haven`t had time to channge my mind before I was on the ground.
Cheers
Pat
Posted: Wed Jan 24, 2007 12:30 pm Post subject: that old video |
pretty short
| of choices.
| Pat
Patrick:
In those cases you mention above, I still take the best choice of what
is available.
Never give up until you finish crashing.
Titus, Alabama |
possums(at)bellsouth.net Guest
Posted: Thu Jan 25, 2007 8:55 am Post subject: that old video |
At 12:15 PM 1/24/2007, you wrote:
Hi,
you when the clip started?
Cheers
Pat
I'd be guessing, but I think is would be 500 - 600 ft off the ground.
Then engine was turned off about 2000 ft AGL and I know
that 600 ft is too high too land in that field at that point
of the approach - so I'm guessing closer to 500. I can hear myself
saying "too high" at one point on the tape.
JetPilot
Posted: Thu Jan 25, 2007 10:16 am Post subject: Re: that old video |
Where can I see this video ????
Kolb MK-III Xtra, 912-S |
a58r(at)verizon.net Guest
Posted: Sat Jan 27, 2007 4:45 am Post subject: that old video |
I think is would be 500 - 600 ft off the ground.>>
Hi Possum,
To take over a minute from that height to the ground is very good. Better
than my Challenger. On the other hand I had the engine quit at around that
height and you had turned the engine off at 2000ft so you were pretty well
sorted out to make such a good landing while I arrived too fast in a cloud
of dust after about 30 seconds.
Incidentally I read in an article by our Popular Flying Assoc. Chief Coach
the following points re forced landings. I have deleted stuff which does not
apply to our sort of planes.
1.Fly the plane.
2. Fly best L/D (around 1.4 of stall speed)
3. Turn downwind. This will let you cover more ground and therefore give a
wider selection of fields.
4. Pick Field. Surface, Size, Shape, Slope, Situation.
5. Turn off engine. You do NOT want it to start again just when you are
lined up.
Of course if you have time get off a MAYDAY. (Possum from 2000 ft had enough
time to make a cup of tea.)
Farnborough, our main testing and research centre, reckon that an `unalerted
reaction time` is 6 seconds.
Unless your plane has lots of inertial energy (ours dont) and you have high
skill levels (which of course we all have) do NOT attempt to turn back in
the event of an engine failure at take off.
Use an arc of 45 degrees either side of the nose.
The RAF does not teach turn backs at all in their Grob 109 Tutors. The
instructors are limited to 600ft minimum turn back height, less in narrow
fields.
Fly the plane until impact no matter what you are going to hit. Lack of
attention can stall you in and the impact even at low level could drop the
engine on you. Flying into the far hedge at 20 mph is better than into the
near hedge at 60.
Most of this is familiar to many of us but in the light of recent discussion
I thought it was relevant.
Cheers
Pat
Posted: Sat Jan 27, 2007 11:34 am Post subject: that old video |
At 07:44 AM 1/27/2007, you wrote:
Hi Possum,
Better than my Challenger. On the other hand I had the engine quit
at around that height and you had turned the engine off at 2000ft so
you were pretty well sorted out to make such a good landing while I
arrived too fast in a cloud of dust after about 30 seconds.
I had plenty of time to set up the landing, that's why I think the
altitude was about right.
That camera had a wide angle lens on it to get the wings in the shot,
so it makes things
look a little farther away than the really are.
First time I cut my engine off, I was going to restart about 800
feet. I got so excited after
flying my "glider" down from 3,000 ft, that I forgot to turn on the
ignition and had to land deadstick.
That is a common mistake, I hear.
BTW : It doesn't mater how you juggle the coke or the throttle, it
still won't crank
with the ignition off.
It's cold out there so here's another old video from a few summers ago called
"We're pretty normal people .....most of the time"
http://video.google.com/videoplay?docid=6342651231744705575
JetPilot
Posted: Sat Jan 27, 2007 12:06 pm Post subject: Re: that old video |
That last video was awesome possums. I had not seen that before, im sure there are many newcommers to the list that are seeing these videos for the first time. Keep on posting
Where was the beach video done ? Also, on the video of the glide to landing, how did you mount the camera to the tail of your kolb ?
Posted: Sat Jan 27, 2007 12:24 pm Post subject: that old video |
We're pretty normal people>>
Hi Possum,
I really liked that video. What freedom you guys have, and room of course.
There is probably not a beach in the UK as empty of people as that.
I like the soundtrack. Who was it, sounded like Jimmy Buffet to me. He is
almost unknown here but i like his Margaritaville stuff.
Cheers
Pat
knowvne(at)aol.com Guest
Posted: Sat Jan 27, 2007 2:35 pm Post subject: that old video |
| Where was the beach video done ? |
| Mike
Mike B:
Believe that beach was on St George Island on the Northwest Florida
coast, not far from where I grew up in Tallahassee, Florida.
I have been fortunate to fly this beach many times over the years.
Titus, Alabama |
biglar
Posted: Sat Jan 27, 2007 3:02 pm Post subject: that old video |
I loved that video the 1st time I saw it, and enjoyed it just as much now.
What a way to go. Living in Possum-land can't be ALL bad.
Lar. Do not Archive.
Larry Bourne
Santa Fe, NM
www.gogittum.com
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
JetPilot
Posted: Sat Jan 27, 2007 4:55 pm Post subject: Re: that old video |
John Hauck wrote: |
I know Tallahassee very well, where did you live John ? I lived there for 4 years while I went to FSU. I flew my Cessna 150 all over that area, based my plane at Bainbridge for a while and then at the big airport in tallahassee. Did you ever fly out to Dog island ? I should have recognized that coastline, but I did not buzz the beaches as often as I should have I much prefered to fly down the apalachicola river at 10 feet as it wound its way south, and low over the bean and cotton fields near bainbridge.
I was flying trail formation over the river with my friend one day, my friend flew past a fishing boat and I saw the guys head follow my friends plane, so I went over him at 10 feet and 100 MPH. The next day some dude went to the bainbridge airport looking for this idiot that almost knocked him out of his boat. Luckily the line guy was my buddy and assured the guy that no pilots that fly out of that airport would do such a thing
My buddy used to fly circles around the 22 nd floor of the Florida state capitol building with his Cessna 140, and no one ever said a word about it. Now that would probably get him thrown in prison. They are doing their best to take the fun out of Aviation, but have not succeeded completely
Michael A. Bigelow
rlaird
Posted: Sat Jan 27, 2007 5:06 pm Post subject: that old video |
So, Mr. Hauck, were you ever this good?
http://www.youtube.com/watch?v=lUvmPj9zU64
On 1/27/07, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
DO NOT ARCHIVE
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Sat Jan 27, 2007 5:30 pm Post subject: that old video |
Robert L:
Well...........I didn't need a helicopter to knock the cap off a
bottle of beer, and I used my helicopter to kill gooks, not play
games.
mkII
PS: Last rotary wing flight June 1976.
DO NOT ARCHIVE
Titus, Alabama |
biglar
Posted: Sun Jan 28, 2007 8:20 pm Post subject: that old video |
I keep playing this fool thing and keep grinning at it. Dog-gone, but that
sure looks like fun. I emailed it to my cousin, to show her what light
plane flying can be like............ Lar.
Do not Archive.
Larry Bourne
Santa Fe, NM
www.gogittum.com
Quote: | Here's a part of a video that a friend called "Possums" sent to me a few
years ago. He lives in Atlanta, Georgia, and took this video on a trip to
an island south of Pensacola, Florida. This is what I dream of someday
doing in my plane, if I ever get it flying. Lar.
Larry Bourne
Santa Fe, NM
www.gogittum.com
> called
Palm Springs, CA
"Vamoose" |
