kitfox69(at)earthlink.net Guest
Posted: Sat Jan 27, 2007 10:59 am Post subject: NSI extra engine parts. |
Hi Again Mike,
When I mentioned the initial overheating problems, besides the undersized radiator, the engine core was full of
junk which clogged the radiator. When I flushed the block, I got over a cup of what looked like core sand out of it.
That was AFTER the radiator was plugged. I would suggest to anyone having overheating problems with their
NSI engines that they flush out the block and radiator in both directions several times. Do it into a bucket so you can observe the results and do them seperately, ie remove the radiator from the system and flush it seperately. Jay can provide
a larger radiator and I can provide dimensions for brackets which make it a no brainer to install. BTY, NSI had the
hoses hooked up backwards, so it will be necessary to replace one with a longer hose to make it reach properly.
If anyone needs details, I can check mine and provide pictures. Regards, Floyd N69FJ
Posted: Sat Jan 27, 2007 7:35 pm Post subject: NSI extra engine parts. |
This problem isn't restricted to NSI either. My
flying buddy built a 2/3rds scale Jenny and installed
a MotoGuzzy engine in it. Before he ran it, he opened
the pan and dumped about a cup full of shavings out of
it. Seems they never cleaned that up after the engine
was milled/built.
My NSI was clean and ran smooth, but my main problems
have been keeping that oil pressure above 30 psi at
flight idle, which is my personal limit, and that darn
blow by oil seperator that wasn't right to begin with.
Also I sure don't get the power I expected from it
for the fuel flow.
I expect to field strip it this year and do some
upgrades. It will be worth it to know if all was well
when take it apart completely.
Kurt S. S-5/NSI turbo
--- Floyd Johnson <kitfox69(at)earthlink.net> wrote:
| Quote: | Hi Again Mike,
full of junk which clogged the radiator......
Need Mail bonding?
Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users.
http://answers.yahoo.com/dir/?link=list&sid=396546091
Posted: Sun Jan 28, 2007 4:27 am Post subject: NSI extra engine parts. |
Kurt,
Just a note regarding oil pressure. Per Jay Roese, who I trust
implicitly. If your oil pressure is 10 pounds per 1000 RPM,
you are good to go. ie: 1 pound per 100 RPM. So if you are ideling at 1200
RPM's 12 Pounds won't hurt the engine.
Don't be afraid to give Jay a ring to explain this. Regards, Floyd
| Quote: | [Original Message]
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Date: 1/27/2007 10:40:56 PM
Subject: Re: RE:NSI extra engine parts.
was milled/built.
for the fuel flow.
> Hi Again Mike,
Need Mail bonding?
