jdalton77(at)comcast.net Guest
Posted: Sun Jan 28, 2007 8:27 am Post subject: OK . . Slow down and andswer a simple question |
Listers,
With all of these these complex questions being discussed I often feel intimidated to ask simple ones. You see, I'm a neophyte. If it's woodworking, I could write the book. If it's software, I'd go toe-to-toe with Bob's eletrical wizardry any time any place. But I'm new to this. So please bear with me as I continue to ask simple questions and don't flame me, tell me I should "look in the archives," read the book, or anything else that would sour my experience. By the way, I've made similar comments on the RV-10 board, and on Vans Airforce, and you would be surprise how many emails I got from people like me thanking me for it. 'nuff said on that.
Now my newbie question (and yes, I have the book and have read it). The way I read about contactors, they need power to the "small" terminal to move the switch and allow the two large terminals to join which in turn allows the "real power" to pass through them. But I was confused by the batter contactor (and the ground power contactor), which seems to only need a switch with a connection to the gound at the firewall to be activated. I'm not sure I get how that works. This is not the case for the starter contactor, which needs power to activate. I know I could wire it up and make it work, I just want to know "why" so I am confident in my own work.
Jeff
khorton01(at)rogers.com Guest
Posted: Sun Jan 28, 2007 8:56 am Post subject: OK . . Slow down and andswer a simple question |
On 28 Jan 2007, at 11:26, jdalton77(at)comcast.net wrote:
| Quote: | Listers,
that.
my own work.
With the battery contactor, there is an internal connection that
allows it to use the power from the battery to energize the coil on
the solenoid that pulls the contactor closed. No power flows through
the coil in the solenoid until you provide a ground by closing the
battery master switch. As soon as you have provided a ground, now
the current can flow from the battery, through the coil, which
creates a magnetic field that pulls the solenoid closed. This makes
the connection that allows battery power to now flow to the rest of
the aircraft.
Ottawa, Canada
http://www.kilohotel.com/rv8
