frank.hinde(at)hp.com Guest
nuckollsr(at)cox.net Guest
Posted: Sun Jan 28, 2007 8:27 am Post subject: Alternator mistake |
At 08:54 AM 1/28/2007 -0600, you wrote:
<frank.hinde(at)hp.com>
Thought it might be useful to document my rather silly (bonehead
stupid) error I made in installng my alt.
First off I bought an "Autozone special" for an electrically dependant
IFR airplane....It appeared to be functioning OK for a while but clearly
IFR is serious business but I really had not put the level of care
required when selecting the alt.
So I decided to replace with a plane power unit ( I plmbed it into my
existing B lead contctor with OV trip)
About that time the GNS 430 started acting up with a bunch of
unconnected errors. This usually means one thing..Bad grounding. But
what could it be? I had a bullet proof "forrest of tabs" ground block
and dual path grounds.
Turns out as I was removing the old alt from the engine I saw it...I had
painted the bracket to prevent corrosion and I believe the alt could not
get a good ground connection to the engine block.
The new plane power unit has CAD plated hardware and I also added a
smear of "malaax" (conductive grease used on household electrical cables
from Home Depot etc) to prevent corrosion and ensure a good connection.
The alt must have a good connection to the engine block in order to
provide a stabilised voltage.
Personally I'm amazed I missed the error during install, I could have
simply added a grounding strap between the alt and the engine block too.
Of couse it may have been the old alt was breaking down but I am pleased
to report my instruments are now behaving perfectly...
Good data sir! Thank you. Some of you may recall some
conversations about voltage regulator stability as
it relates to shared pathways for both sensing the
voltage to be controlled and OTHER duties like supplying
field current . . . and in this case conducting output
current to the crankcase and ultimately electrical system
ground.
Even small resistances carrying significant currents
produce voltage drops in accordance with Mr. Ohm's
famous E=IR. When E is large with respect to the regulator's
ability to sense and react to changes in bus voltage,
the extraneous voltage signals become a form of "noise"
in voltage regulator's control loop.
Frank's experiences, investigation and subsequent conclusions
go right to this point of system performance. I'll make
a note to include some words about alternator case bonding
which was only mildly important for ER alternators but
exceedingly important for achieving advertised performance
from IR alternators.
Incidentally Frank, which model of PP alternator did you
install? Would you be willing to copy/scan the installation
data that comes with it and send it to me? I note that
some models on their website speaks of ov votlage protection
and they've even used the (ugh!) word "crowabar" in the
context of speaking about ov protection. The photo at
http://www.plane-power.com/images/AL12_EI70%20Wiring.pdf
shows what appears to be an add-on to the back of their
product for the purpose of providing OV protection.
I'm curious as to whether or not you can turn the alternator
OFF by way of the "field switch" after it has once been
turned ON.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
gcomfo(at)tc3net.com Guest
Posted: Sun Jan 28, 2007 10:46 am Post subject: Alternator mistake |
Posted: Sun Jan 28, 2007 5:11 pm Post subject: Alternator mistake |
At 01:45 PM 1/28/2007 -0500, you wrote:
Bob: Plane Power have advised me verbally that the alternator can be
shut down by way of the "field" switch but their installation drawing is
quite primative and I cannot be sure from it whether or not what they say is
true. It will be a while before I run the engine but my intent is to check
that function when I do run it. The module on the rear is described as a
crowbar OV control. I'm actually working on the -8 again. My word.
Gordon Comfort
N363GC
Looking forward to getting your report. So all that 'stuff'
you put in the -4 is making it too crowded? I envy you sir,
I think the -8 is my personal favorite.
( EVERY day . . . )
Posted: Sun Jan 28, 2007 8:40 pm Post subject: Alternator mistake |
Hello Bob,
I installed the smaller 60Amp unit than the one shown in the link you
provided, Not sure what form factor it is but it is considerably smaller
than the 70A unit shown (which incidently looks identical to the ND
Toyota Camry unit I replaced). The reason I fitted this one was that was
all that Van's had in stock and should be big enough even with the dual
electric fuel pump/IFR installation in my airplane.
I do note the voltage regulator is set a little low at around 13.7V.
The crowbar unit on the back appears to just have small single wire that
presumably just collapses the field current. To be honest I was little
reluctant to rely on this device so I wired it in series with my
existing OV protection the basis of which is one of Eric's big
contactors.
Can you turn the unit off?...Hmm, well the instructions do not
specifically mention this. They do say you can turn the unit ON by
energising the filed but I did not see that you could turn it
off...Personally I would not try to do this unless it was an emergency.
I'll have a look in the hangar for the instructions, I do know they were
pretty sparse electriclly speaking.
Incidently different topic, the backup SD-8 alternator cranks out quite
a bit more than 8amps...I can reliably run almost evrything in the
airplane...i.e one FI electric fuel pump, GNS430 and an audio
panel...The battery volts will dip below 12v on a transmit but apart
from that it is enough to drive home if don't use any lights. I would
say the unit makes nearer 12A.
Frank
turned ON.
( EVERY day . . . )
klehman(at)albedo.net Guest
Posted: Mon Jan 29, 2007 5:38 am Post subject: Alternator mistake |
If the OV shutdown is simply a crowbar on the IGN terminal that pretty
much means that I would not trust it either. Better than nothing maybe
but... Can you confirm where that wire goes Frank?
Ken
Hinde, Frank George (Corvallis) wrote:
Hello Bob,
contactors.
Frank
turned ON.
Posted: Mon Jan 29, 2007 6:16 am Post subject: Alternator mistake |
At 10:39 PM 1/28/2007 -0600, you wrote:
Hello Bob,
That's disappointing. 13.7 will EVENTUALLY replenish the charge
in a SVLA battery but the recharge time to 99% of capacity can
be 3-10x longer than at 14.2 or even 14.6 volts.
Their website is remarkably silent on the topic of voltage
setpoints for both OBAM aviation and TC aviation products.
Nonetheless, if they've been granted permission to install
on TC aircraft, they're no doubt in possession of data which
describes the voltage regulation characteristics of their
PMA products . . . I would expect the OBAM aviation products
to be identical.
Drop them a note and ask. You're a $paying$ customer. It's
not an unreasonable question.
| Quote: | The crowbar unit on the back appears to just have small single wire that
contactors.
Unless there's a b-lead disconnection device like that shown
in Figure Z-24 and Z-24a, there is no risk to the alternator
to attempt a shutdown via the "ALT FIELD" switch. If this
switch functions as we've come to expect from traditional
installations, the alternator will simply stop producing power
and resume when it's closed. This test can be accomplished at
low rpm, everything turned off and by watching the voltmeter
to wiggle when the switch is operated.
| Quote: | I'll have a look in the hangar for the instructions, I do know they were
Thank you for sharing this information. I've written Steve Klodd,
head chef at Plane Power to inquire about the functionality of
product features cited on his website. We shall see . . .
| Quote: | Incidently different topic, the backup SD-8 alternator cranks out quite
Also interesting. I've often thought that the capabilities of
the SD-8 would drift upward with time. The availability of
high-performance magnets continues to improve and I've always
thought that the magnet assemblies shipped to B&C might just
become better with technological age. You may well be
experiencing this phenomenon. I'll ask Tim about it the next
time we talk.
Posted: Mon Jan 29, 2007 8:16 am Post subject: Alternator mistake |
Hard to tell Ken but it is a very small wire that appears to go to the
center of the machine so my assumption is that it goes directly to one
of the slip ring brushes, the other end is bolted presumably to a
contact that goes to the opposite brush or maybe the case...I'm thinking
it shorts out (or grounds) the field coil.
I'm definatly not an electrical expert so I may well be a little off
here.
Frank
Posted: Mon Jan 29, 2007 9:20 am Post subject: Alternator mistake |
You are arousing my curiousity for sure though. If it bypasses the
silicon and crowbars directly to the field windings, that would make it
a totally acceptable one time OV protection in my mind. I think that
would be as good or better than I have with Z-24 if it limits
alternator damage to the voltage regulator. More money than my locally
obtained alternator but easier to install. One nice thing about Z-24 is
that I can test the OV function with the engine off without damaging
anything.
I am looking forward to Bob's AEC9004 for a universal solution though.
If he can demonstrate stalling alternators without damaging them that
would be marvelous.
Ken
here.
Frank
Posted: Mon Jan 29, 2007 10:03 am Post subject: Alternator mistake |
Ya, for me I have come to regard the $400 alternator as almost
sacrificial, as long as it does not fry my $6000 GNS 430!..>And
especially as long as it doesn't do it when I need it in hard IMC.
It seems alternators have very low failure rates generally (and I have
an SD8 backup) then a resettable alternator is a pretty low priority for
me...Would I fly 500 miles home on an SD8 backup in IFR? Probably not,
but I might wait a day and do it VFR then send the alt away for repair
upon my return home.
My second error (apart from the grounding thing) was using a cheap
rebuild for what has become a critical application (I'm doing my IFR
training in the RV7a). The fact it took me about a day to fabricate all
the brackets, source a suitable belt etc and $400 is looking pretty
inexpensive...
Anyway some rambling thoughts
Frank
Posted: Mon Jan 29, 2007 11:24 am Post subject: Alternator mistake |
At 11:59 AM 1/29/2007 -0600, you wrote:
<SNIP>
| Quote: | My second error (apart from the grounding thing) was using a cheap
inexpensive...
Not rambling thoughts but critical design review.
I don't know how many builders have written or called
about sources for materials to accomplish some portion
of their project DIY. I always try to ask, "Are you
doing this because you WANT to learn how it's done
and enjoy doing it for the experience . . . or is it
to save money."
More often than not, the answer is, "to save money".
I've come to realize that our rudimentary commodity
of exchange is $time$ . . . and when one considers
the total cost of acquisition and ownership in terms
of total $time$, they quite often find that it would
have been better to spend their $time$ acquiring
cash at something they're good at than to spend more
$time$ in an attempt to get something new done right
the first time.
| Quote: | You are arousing my curiousity for sure though. If it bypasses the
anything.
You can test Z-24 with the engine running. Just run at
ramp rpm and wait until the battery is recharged after
cranking the engine. The magnitude of the load dump
transient is a function of alternator output current
and rpm at the time the b-lead opens. A lightly
stressed alternator doesn't "bump" vigorously.
Note on page 2 of
http://www.aeroelectric.com/Mfgr_Data/Semiconductors/MC33092A.pdf
. . . the regulator is spec'd to stand off a load dump
transient of 40v for 125 mS. I think this is typical
of the industry and mirrors DO-160 recommendations
for 14v systems.
( EVERY day . . . )
