Posted: Wed Feb 01, 2006 8:32 pm Post subject: pitot tube |
Don't know if you are speaking of the length of the probe
or the tubing going to the cabin instrument. The probe
can be any length. The tubing also. -within reason, not talking miles
here.
Pressure drop of a fluid in a pipe (air being also a fluid)
is a function of cross section times distance traveled.
The diff in a pitot static system is that there is no flow,
hence no pressure drop.
-BB
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Thu Feb 02, 2006 6:26 am Post subject: pitot tube |
Thanx Bob, it's the tube itself and I figured it didn't matter...
DVD
On 2/1/06, robert bean <slyck(at)frontiernet.net> wrote:
here.
-BB
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Thu Feb 02, 2006 7:12 am Post subject: pitot tube |
They only say that to make us feel better...
David.Lehman
Posted: Thu Feb 02, 2006 5:23 pm Post subject: Re: pitot tube |
| slyck(at)frontiernet.net wrote: | Don't know if you are speaking of the length of the probe
here.
-BB |
Bob...
Here's a "duh"... Given what you wrote, I really don't need the "tube" because the bulkhead fitting is forward of the nose about 7/8" and should be in undisturbed air?...
Thanx...
DVD
jhankin(at)planters.net Guest
Posted: Mon Feb 06, 2006 5:09 am Post subject: Pitot Tube |
With my Firefly on the ground the pitot tube is almost level, with it in
flying attitude the tube is a good bit down. Will this affect the
performance of the air speed indicator. It is now in the middle of the nose
cone.
Jimmy Hankinson
912-863-7384
Firefly 035
JYL (Sylvania)
Pegasus Field (Home)
2000 Feet X 100 Feet- Grass
Rocky Ford, Georgia
Richard Pike
Posted: Mon Feb 06, 2006 7:41 am Post subject: Pitot Tube |
Mine is slightly pointing down while on the ground and it works OK. It
is below the nose bowl by several inches and slightly aft of the front end.
Richard Pike
MKIII N420P (420ldPoops)
Jimmy wrote:
cone.
Jimmy Hankinson
912-863-7384
Firefly 035
JYL (Sylvania)
Rocky Ford, Georgia
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
