naumuk(at)alltel.net Guest
Posted: Wed Jan 31, 2007 3:01 pm Post subject: Cleaning aluminum, aerobatics |
Eddie-
I can see your problem- John's post never takes a stand other than "prep
carefully". You might want to narrow your search down by saying what type of
paint you intend to use (Enamel, lacquer, etc.) and see if anyone bites.
Good building.
Bill Naumuk
HDS Fuselage
Townville, Pa
John Bolding
It's actually not an alternative but rather the norm in the finishing industry. Aluminum parts going thru a conveyorized parts washer (long tunnel with several tanks and hundreds of spray nozzles) use some pretty aggressive chemicals sometimes depending on what they are trying to remove but for alum that started out clean and only has smudges and oils from our skin plus oily residue the air drill spit out Dawn or Woolite plus water gets it down to the shine. RINSE WELL WITH AGITATION !! Skip the alcohol, the part is already clean. DON'T dry it with compressed air, a LITTLE oil in the air goes a long way, use a fan or a CLEAN cotton rag.
If you were outside I'd use WO-1 or Alumaprep to put in a little tooth for better adhesion but you can do that with the proper color of Scotchbrite (I keep forgetting which color it is)
LOW&SLOW John Bolding
I was searching the archives for a good alternative to cleaning parts before priming (indoors) and found John Bolding's writeup below.
So, what is a good, safe cleaner that I can use indoor without risking exposure to carcinogen chemicals and without causing chemical reactions on the aluminum parts?
Should I consider using soap and distilled water followed by rubbing alcohol?
Thanx...Eddie
Posted: Wed Jan 31, 2007 5:38 pm Post subject: Cleaning aluminum, aerobatics |
Eddie-
Figures, 15 minutes after I post this, John comes through. Can't
complain though, eh?
Good building.
Bill Naumuk
HDS Fuselage
Townville, Pa
