Z-13/8 Switch Question
george(at)georgejenson.co
PostPosted: Wed Jan 31, 2007 12:23 pm    Post subject: Z-13/8 Switch Question Reply with quote
Listers / Bob,
I'm planning my electrical system (Z-13/8, Plane Power main alt) and panel
and want the switches and layout to be as simple and logical as possible. I
am considering using two 2-1 switches for the master and the alternators as
follows:
Master Switch
Down EBUS: Closes circuit between battery bus and E-bus.
Middle BATT: Only Battery bus is live.
Up MAIN: Normal flight position, grounds contacter making Main bus live,
E-bus is live via diode from Main.
Alternator Switch
Down BKUP: Grounds contactor making SD-8 backup live to battery.
Middle OFF: No power source available.
Up MAIN: Closes circuit between Main bus and main alternator field.
To my thinking, this is plenty logical and user-friendly. In effect, these
two would replace the following three switches in Z-13/8:
1. DC Power Master Switch (2-3)
2. E-Bus Alternate Feed (1-3)
3. Aux Alt Off/On (1-3)
Questions:
1. Is this a bad idea in terms of failure exposure - does my risk go up by
using fewer switches or by using 3-position switches? If so, the next three
questions are largely moot.
2. Can it be done such that the first is BATT / EBUS / MAIN and the second
is OFF / BKUP / MAIN such that fully down is off, fully up is normal, and
middle is "Houston, we have a problem"? This is my first choice, but I
haven't been able to work out a way to do it with any other 3-position
switch that I'm aware of. If there is an Off-On-On like a 2-1 but with Off
on bottom, that would do it, if there is some cool way to do it with a 2-10
I haven't conjured it.
3. I lose the ability to have both alternators plugging away at the battery
at the same time, is this a bug or a feature?
4. I also lose the ability of having both the Main bus live, and the E-Bus
live direct from the Battery bus w/o the attendant voltage drop from the
diode. Again, bug or feature?
Thanks in advance,
George Jenson
Tucson, AZ
RV-7 standard build, fuselage underway
nuckollsr(at)cox.net
PostPosted: Wed Jan 31, 2007 1:46 pm    Post subject: Z-13/8 Switch Question Reply with quote
At 01:21 PM 1/31/2007 -0700, you wrote:
<george(at)georgejenson.com>
Listers / Bob,
I am considering using two 2-1 switches for the master and the alternators
as follows:
Master Switch
Alternator Switch
Questions:
three questions are largely moot.
Combined functions open opportunities for single
failures of a switch to affect more than one function.
Choose your combinations carefully. Also be aware that
fewer switches is "simpler" but combined functionality
is more "complex."
2-10 I haven't conjured it.
This could turn into a long debate as to the desirability
of doing (or not doing) any particular thing. Keep in mind that
the Z-figures have been combed for a number of years to keep
the operation logical and produced an attractive failure mode
effects analysis. While the switch panels illustrated to support
Z-13/8 may have a lot of features, I've resisted efforts to
combine functionality for systems other than cabin comfort,
landing/taxi/wig-wag and other lighting. See:
http://www.aeroelectric.com/PPS/Switch_Panels/Z13-30-ElexIgn.pdf
battery at the same time, is this a bug or a feature?
13/8 is not intended to be run with two alternators.
What you propose will predictably function as you've suggested.
Just be aware that the considerations for architecture and
functionality goes deeper than numbers of switches and occupied
panel space. Consider further that you'll no doubt want to
sell this airplane at some future date. The more familiar your
prospective customer is with the functionality of the controls,
the better.
PostPosted: Wed Jan 31, 2007 2:51 pm    Post subject: Z-13/8 Switch Question Reply with quote
Bob,
Thanks for the quick reply and solid logic.
1. I'll stick with the Z-13/8 as shown - losing one switch isn't worth
gaining an unknown amount of risk and giving up being "more likely to be
familiar" to a prospective future purchaser.
2. Thanks for the switch layout link - hadn't seen those and they are very
useful.
I was referring to the main alternator and the SD-8 backup as two
alternators. Either that wasn't clear, or I mistakenly called it an
alternator. I was basing that on B&C's description:
SD-8 Alternator
Click picture for description Spline-driven 8 AMP - 14 Volt power system
for mounting on vacuum pump pad. Price includes alternator assembly with
male spline and regulator (protrudes 4.75" from mounting surface.)
Am I misunderstanding what you meant by 13/8 not having two alternators? In
any case, as 13/8 appears, you could indeed have both the Main Alternator
and the Backup SD-8 "whatever its called" both connected to the battery at
once. I'm assuming this is OK but I was asking if it is necessary or
beneficial? A better question would be under what circumstances would you
want them both connected and charging?
Thank you again for all you do,
George Jenson
Tucson, AZ
RV-7 Std Build, fuselage underway
PostPosted: Wed Jan 31, 2007 3:40 pm    Post subject: Z-13/8 Switch Question Reply with quote
Bob,
<snip>
>SD-8 Alternator
OOPS . . . a better word would have been OPERATED.
In any case, as 13/8 appears, you could indeed have both the Main
Alternator and the Backup SD-8 "whatever its called" both connected to the
battery at once. I'm assuming this is OK but I was asking if it is
necessary or beneficial? A better question would be under what
circumstances would you want them both connected and charging?
Your load analysis for NORMAL ops should be well satisfied by
the main alternator. The standby alternator is to enhance ALT
FAILED operations to support 8+ amps of E-bus loads indefinitely
while en route. This saves 100% of battery charge in reserve for
loads that exceed the SD-8 output during approach and landing.
My pleasure sir.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
