		Mike Whisky
				 Posted: Sun Jan 28, 2007 12:01 pm    Post subject: How does this tank test kit work? |
				Hello I purchased Vans tank test kit but how should this fuel feed cover is supposed to work? Am I missing something here?
 Michael
		|  Description: |
		|  Filesize: |
		 722.31 KB |
		|  Viewed: |
		 601 Time(s) |
 _________________ RV-10 builder (flying)
#511 |
		rvbuilder(at)sausen.net Guest
				 Posted: Sun Jan 28, 2007 3:54 pm    Post subject: How does this tank test kit work? |
				Unfortunately, almost everything in that kit is useless and doesn't
 apply to the -10.  You will have to improvise most of it.
 Michael Sausen
 -10 #352 Limbo
		wvu(at)ameritel.net Guest
				 Posted: Sun Jan 28, 2007 7:30 pm    Post subject: How does this tank test kit work? |
				Michael,
 I tested mine using Dan Checkoway's method, described here:
 http://www.rvproject.com/20020710.html .  It is quite sensitive to
 atmospheric changes but should give a good feel.
 Anh
		Mike Whisky
				 Posted: Mon Jan 29, 2007 12:40 am    Post subject: Re: How does this tank test kit work? |
				Thank you Michael & Anh, I am just wondering why they sell it this way? Anyway I'll go the alternative route.
 Thanks for the fast replys
 Michael
 http://www.wellenzohn.net
#511 |
		henkjan(at)zme.nl Guest
				 Posted: Mon Jan 29, 2007 12:58 am    Post subject: How does this tank test kit work? |
				Why is it useless? I used it on both tanks recently
 Henkjan van der Zouw
 40355
 -----Oorspronkelijk bericht-----
 Van: owner-rv10-list-server(at)matronics.com
 [mailto:owner-rv10-list-server(at)matronics.com] Namens RV Builder (Michael
 Sausen)
 Verzonden: maandag 29 januari 2007 0:54
 Aan: rv10-list(at)matronics.com
 Onderwerp: RE: How does this tank test kit work?
  <rvbuilder(at)sausen.net>
 Michael Sausen
 -10 #352 Limbo
		reubanks
				 Posted: Mon Jan 29, 2007 6:16 am    Post subject: Re: How does this tank test kit work? |
				Couldnt view your URL you posted. Below is the error:
 Henkjan's Van's RV10 PH-ZME
 RV10
    All
 Notice: Undefined variable: log_date in /home/content/a/e/r/aeroware2/html/users/display_log.php on line 174
 Notice: strtotime(): Called with empty time parameter in /home/content/a/e/r/aeroware2/html/users/templates/library/chart_functions.php on line 28
 1-29-2007
 Unable to find a work log with the specified id or no id was specified.
		LloydDR(at)wernerco.com Guest
				 Posted: Mon Jan 29, 2007 6:49 am    Post subject: How does this tank test kit work? |
				You need to cut and paste the entire link, as it got truncated.
 Dan
 N289DT
				http://www.mykitlog.com/users/display_log.php?user=phzme&project=1&categ
 ory=0&log 7411&row=1
 I'm no computer wizz, look at www.zme.nl, click at the kitlog logo, it's
 the last entry at the log
 [mailto:owner-rv10-list-server(at)matronics.com] Namens reubanks
 Verzonden: maandag 29 januari 2007 15:16
 Onderwerp: Re: How does this tank test kit work?
 RV10
    All
 ns.php on line 28
 1-29-2007
 http://forums.matronics.com/viewtopic.php?p=91266#91266
		Mike Whisky
				 Posted: Mon Jan 29, 2007 8:09 am    Post subject: Re: How does this tank test kit work? |
				Sorry but I only had one valve, the blue cap and a description in my kit and thats ist. I wonder how you fit this to the standard fuel finger without additional hardware.
 Michael
#511 |
		reubanks
				 Posted: Tue Jan 30, 2007 7:10 am    Post subject: Re: How does this tank test kit work? |
				Hi Dan,
 Yes, I used the entire URL before I sent the reply.
				 Posted: Tue Jan 30, 2007 8:59 am    Post subject: How does this tank test kit work? |
				Either I got a different kit, or we are looking at things differently,
 because it worked for me.  You put a balloon on the vent fitting and seal it
 with a rubberband, put the tank fitting in the finger strainer and cap it
 with the cap that comes in the kit, then put the little valve stem dealy
 (technical term) in the sump hole, cap the tank with the filler cap and fill
 with air until the balloon fills up and then check for leaks.
 Hope this helps.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
		Mike Whisky
				 Posted: Thu Feb 01, 2007 2:18 am    Post subject: Re: How does this tank test kit work? |
				Hello Jesse,
 my issue is actually that the finger strainer has an inside thread as well as the cap. So I guess I am missing the tank fitting? Did it come with the wing kit?
 Michael
#511 |
		Tim Olson
				 Posted: Thu Feb 01, 2007 4:37 am    Post subject: How does this tank test kit work? |
				You use some of the standard AN fittings that probably are in your
 kit to attach your fuel lines to.  AN fittings is one area where
 you may end up spending a bit extra and ordering varieties...if
 you do anything non-standard, you'll be swapping one fitting for
 another, and you'll have to order them.  I think the ones in the
 kit are just the plain straight AN6 nipple fittings.
 Michael Wellenzohn wrote:
  <michael(at)wellenzohn.net>
  Hello Jesse,
  Michael
  -------- RV-10 builder (wings) #511
  http://forums.matronics.com/viewtopic.php?p=92033#92033
				 Posted: Thu Feb 01, 2007 7:50 am    Post subject: How does this tank test kit work? |
				It should have come with the kit as I remember.  It is the 6D fitting that
 has pipe threads on one side and flare fitting on the other side (no angle,
 no "T", just the short straight one) and put the cap on that.
 Do not archive.
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
