john(at)roadmapscoaching. Guest
Posted: Wed Jan 31, 2007 6:49 pm Post subject: manifold pressure connection |
The Vans manifold kit has a 1/16" ID barb on the bulkhead fitting. My AFS 3400 pressure sensor has a 1/4" barb and my Plasma II ignition has a 1/8" barb. Can anyone suggest how to plumb these and what connectors/tees/adapters to use. I have searched everywhere to find a solution. Help!
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
FWF, engine, wiring
Rick S.
Posted: Wed Jan 31, 2007 7:28 pm Post subject: manifold pressure connection |
John,
Does this help?
http://www.rvproject.com/20030729.html
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Dave(at)AirCraftersLLC.co Guest
Posted: Wed Jan 31, 2007 7:34 pm Post subject: manifold pressure connection |
John,
I would (will) get one of Van's 1/8 NPT manifolds to mount under the panel. Alternatively you could use an AN917-1D (Spruce) if you only need two branches. Then plumb the 1/16" tube to it, and branch it off to anything else that needs MP. McMaster-Carr has a huge selection of fittings with 1/8 NPT to barbs. Use Kynar, or brass if plastic makes you nervous. I've used plastic for MP aft of the firewall many times.
Call me if I can help further.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement RM
Sent: Wednesday, January 31, 2007 6:49 PM
Subject: manifold pressure connection
John Testement
40321
Richmond, VA
FWF, engine, wiring
sam.marlow
Posted: Wed Jan 31, 2007 7:45 pm Post subject: manifold pressure connection |
I found a solution at my local hobby store.
---- John Testement RM <john(at)roadmapscoaching.com> wrote:
| Quote: | The Vans manifold kit has a 1/16" ID barb on the bulkhead fitting. My AFS
solution. Help!
John Testement
HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com
40321
Richmond, VA
FWF, engine, wiring
ddddsp1(at)juno.com Guest
Posted: Wed Jan 31, 2007 10:21 pm Post subject: manifold pressure connection |
John,
Order the 1/4 barb from ACS that replaces Vans in the firewall. You can also get an adapter from any auto store.........they use them for the vacuum lines in cars. Heater lines or winshield washer lines.
DEAN 40449
________________________________________________________________________
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
Posted: Thu Feb 01, 2007 5:14 am Post subject: manifold pressure connection |
My favorite place for ANY plumbing fittings is ACE HARDWARE. They carry all the standard stuff, and unlike my big-box hardware stores .. they also carry the strange adapter-type fittings.
Linn
Dave Saylor wrote:
[quote] John,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Testement RM
John Testement
40321
Richmond, VA
FWF, engine, wiring
Posted: Thu Feb 01, 2007 7:47 am Post subject: manifold pressure connection |
I’ve just used the hose that comes with Van’s kit as a short piece inside a larger diameter hose (like pitot line) and that inside the final size if you need bigger to connect to the MAP Sensor. Glue or zip ties to hold them together. Just make sure you don’t get a kink in the little line that comes from Van’s. As I understand it, it’s suction, not pressure, and very little at that. What to do forward of the firewall I can’t help with, because I doubt you want pitot line up there where it’s hot. I would have to bow to the more knowledgeable on that.
Do not archive.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Wednesday, January 31, 2007 9:49 PM
John Testement
40321
Richmond, VA
FWF, engine, wiring
1/30/2007 [quote] [b]
apilot2(at)gmail.com Guest
Posted: Thu Feb 01, 2007 8:44 am Post subject: manifold pressure connection |
Unless you have a turbo, or the engine isn't running, it is always
suction. It is marked as inches of mercury, just like a barometer, so
25" is 4" of suction. Idling at 12" you have about 18" of suction.
That is why it should read pretty close to altimeter setting when the
engine is stopped.
On 2/1/07, Jesse Saint <jesse(at)saintaviation.com> wrote:
As I understand it, it's suction, not pressure, and very little
jwt(at)roadmapscoaching.c Guest
Posted: Thu Feb 01, 2007 6:23 pm Post subject: manifold pressure connection |
Thanks everyone for ideas on the MAP sensor plumbing.
John Testement
40321
Richmond, VA
FWF, engine, wiring
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Thursday, February 01, 2007 10:45 AM
Subject: RE: manifold pressure connection
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
John Testement
40321
Richmond, VA
FWF, engine, wiring
1/30/2007 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
5-- No virus found in this Edition.
1/31/2007
