zackrv8
Posted: Fri Feb 02, 2007 5:11 am Post subject: Nose Gear Wheelpant/Strut Fairing Clearance |
Any flying Rv10's out there know if the 1/4" clearance between the nosegear wheelpant and the nosegear strut fairing is enough? Any rub issues from normal use?
Zack
_________________ RV8 #80125
RV10 # 40512 |
flysrv10(at)gmail.com Guest
Posted: Fri Feb 02, 2007 6:07 am Post subject: Nose Gear Wheelpant/Strut Fairing Clearance |
Good enough. I have just about the same clearance and since there is
no movement between the two, there is no problem. Just be sure that
you have the clearance through the full wheel movement.
On Feb 2, 2007, at 8:11 AM, zackrv8 wrote:
Zack
RV8 #80125
RV10 # 40512
http://forums.matronics.com/viewtopic.php?p=92242#92242
