headset - bad mike test proc needed
eedetail
PostPosted: Fri Feb 02, 2007 1:52 pm    Post subject: headset - bad mike test proc needed Reply with quote
Folks,
the tower's been telling me that I am barely readable - and I was blaming my radio. However, I've been flying another plane lately, and today my mike quit working. I now think that my radio is not bad, but the headset is.
Anyone here have a quick and dirty ground test for a mike?
I'll be trying a different brand in my plane tonite, but kinda want to double check before springing for a new headset.
TimE
pilot4pay
PostPosted: Fri Feb 02, 2007 3:03 pm    Post subject: headset - bad mike test proc needed Reply with quote
The mike needs a bias voltage, have you tried a headset adapter cord to a
handheld?
I once had a problem with some headset mikes, and solved the problem by
flicking them with my finger like you'd flick a fly. Apparently having them
sitting unused for a time allowed the carbon granules to kinda stick
together, the little shock from the snap shook them up enough to get it
working again. Worth a try...
Craig Smith
Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin
eedetail
PostPosted: Fri Feb 02, 2007 3:17 pm    Post subject: Re: headset - bad mike test proc needed Reply with quote
Havent tried that and I'll have to ask around for an adaptor.
I should mention it was cold -10C outside. But, I was flying an Arrow and it warmed up pretty quickly. I am gonna try a borrowed headset in the zodiac this evening.
TimE
pilot4pay
PostPosted: Fri Feb 02, 2007 4:38 pm    Post subject: headset - bad mike test proc needed Reply with quote
Those are exactly the conditions that caused the mike on my "guest' headset
to solidify. It sat in the cold hangar all winter. I was miffed when it
wouldn't work on the first time it was used. After giving it a good snap
they stared working again. I'm guessing a bit of condensation, and cold gets
the carbon stuck together. It's the vibrations of the carbon that generates
the signal.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
--George Carlin
eedetail
PostPosted: Fri Feb 02, 2007 4:48 pm    Post subject: Re: headset - bad mike test proc needed Reply with quote
Craig,
Thanks for the info. This set hadnt sat in the cold all night, but it did sit for a little while. I believe it's an electret type mike, is the other type of mike any better or worse?
I see your' a future 640 builder - Currently flying a 601HD.
TimE
lhelming(at)sigecom.net
PostPosted: Fri Feb 02, 2007 4:53 pm    Post subject: headset - bad mike test proc needed Reply with quote
Try your headset in another plane that has a perfectly working radio. I bet
someone around your area would try that for you. Larry n Indiana
pilot4pay
PostPosted: Sat Feb 03, 2007 6:17 am    Post subject: headset - bad mike test proc needed Reply with quote
Not sure what other type your referring to, electret seems to be the most
common type employed in headsets. I remember doing a little research into
the microphone issue to try to figure out why mine weren't working, but it
would take a bit of time to dig it all out. If you have a name for the type
you are thinking of let me know what and I'll try to help.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
--George Carlin
Bill Denton
PostPosted: Sat Feb 03, 2007 6:56 am    Post subject: headset - bad mike test proc needed Reply with quote
The repair processes that have been put forward, such as tapping the mic or
slamming it against a brick wall Wink could lead one to believe that what is
being referred to is an old "carbon" mic.
This type of mic used granules of carbon, which could become stuck together.
Sharply tapping the mic would often free up the granules and restore the
mics performance.
Back in the day, Ma Bell's headsets used carbon mics, and you'd be amazed at
how much of an improvement in voice quality a few taps could give you.
But while I'm no longer really "in" any type of electronics field, it's been
years since I've heard of carbon mics being used for anything...
nuckollsr(at)cox.net
PostPosted: Sat Feb 03, 2007 7:32 am    Post subject: headset - bad mike test proc needed Reply with quote
At 01:52 PM 2/2/2007 -0800, you wrote:
Folks,
TimE
Sure. Plug it into an intercom. You should be able to
"talk to yourself" . . . wiggle the plugs, flex the
wires. It MIGHT be that your ship's jacks are suffering
from old age.
Get a hand held. Leave the antenna off. Tune ship's radio
and hand held to some locally unused frequency. Plug mic
into ship's transceiver, headphones into the hand-held.
Listen to yourself while wiggling the jacks and wires.
PostPosted: Sat Feb 03, 2007 9:21 am    Post subject: headset - bad mike test proc needed Reply with quote
At 07:34 PM 2/2/2007 -0500, you wrote:
<pilot4profit(at)sbcglobal.net>
the signal.
I don't think anyone has manufactured a new aviation microphone
using carbon granule technology in 30-40 years. Electret and dynamic
have been the technologies of choice for many a moon.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
pilot4pay
PostPosted: Sat Feb 03, 2007 11:39 am    Post subject: headset - bad mike test proc needed Reply with quote
Gosh Bob, I'm not trying to mislead anyone. The headset I have that gave me
the trouble is branded flightline. They are low price economy stereo
headsets purchased new 3 yrs ago. When the mike crapped out, I tried to find
out how it worked. Can't remember exactly where the info came from but
that's what I was told. The mike capsule is a cylinder roughly 1/4" dia.
metal sidewall, 2 leads on back side circuit board, looks black from front.
Tried googling flightline, and try to find manufacturers website not found.
The line is still carried by aircraft Spruce, but I don't think this model
is made any more. Sure wish I could find the original poop sheet. At any
rate they returned to function after giving them the finger snap,
electret/dynamic/condenser/carbon whatever.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
--George Carlin
pilot4pay
PostPosted: Sat Feb 03, 2007 11:45 am    Post subject: headset - bad mike test proc needed Reply with quote
For what it's worth I found this from David Clark on testing headsets.
http://www.davidclark.com/PDFfiles/AvHeadsetTestProc.pdf
Hope this helps someone.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
--George Carlin
PostPosted: Sat Feb 03, 2007 1:39 pm    Post subject: headset - bad mike test proc needed Reply with quote
Cool find sir! Thank you. I've archived and indexed a copy
on the website.
( EVERY day . . . )
PostPosted: Sat Feb 03, 2007 1:41 pm    Post subject: headset - bad mike test proc needed Reply with quote
I don't think it was you who mentioned carbon mics (it's true
that a standard 'fix' for those things was to bang them on
a bulkhead from time to time!). Obviously, any piece of electronics
can develop a quirk in connectivity that may be restored to
function by some shock. Didn't mean for it to look like
I was suggesting any understanding or misleading info on your
part.
Craig Smith
billsettle(at)bellsouth.n
PostPosted: Sat Feb 03, 2007 3:03 pm    Post subject: headset - bad mike test proc needed Reply with quote
Speaking of David Clark.....
I used to have a Luscombe that I flew with a Garmin GPSCOM 190 handheld. When I bought the Luscombe about ten years ago, I bought a new David Clark H10-20 headset to go with the H10-30 that I already had. I had purchased the 10-30 2nd hand from a friend who went to the airlines and no longer needed it. My intention was to use both headsets with an intercom when someone flew with me...
I started having problems with my handheld-headset setup that I don't recall the nature of now. I do remember sending my handheld back to Garmin to have them check it out. When It came back with no problems found, I called David Clark and explained my problem to them, whatever it was. I do remember that my David Clark PTT would not always open my mic. The tech rep I spoke with asked me to send both headsets and the PTT to them and he would check them out.
I got a call a week later from the same tech I had spoken with who said he could find no problems with any of the stuff I sent him. He said that the mic on the 10-20 might be a little hot for the Garmin handheld, so he said he was going to send me a different one to try. He said they were going to go ahead and replace the PTT for good measure as well. He then asked me how old the 10-30 was. I told him I did not know as I had bought it second hand about 8 years prior. His response was, "Well we have made some improvements to these since then, so I'm going to go ahead and replace it also..."
The next time I'm in the market for a headset, it will absolutely, positively, without a doubt, be a David Clark.
The problem turned out not to have anything to do with the headsets or PTT. It was the remote connection on the side of the Garmin which I had not sent back to Garmin.
Bill Settle
RV-8 Wings
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Date: 2007/02/03 Sat PM 04:38:01 EST
Subject: RE: Re: headset - bad mike test proc needed
on the website.
( EVERY day . . . )
pilot4pay
PostPosted: Sat Feb 03, 2007 4:40 pm    Post subject: headset - bad mike test proc needed Reply with quote
Bill, you're right on with CD service. A couple years back, I was at
Sun-N-Fun with my wife. We'd flown down in our C172 for the whole show. My
wife complained of pain after a few hours of flight, and as we flew all the
way from MI, she'd logged some time under her DC H10-13s. By the time a day
of flying was done she needed to take something. I mentioned this when I was
at the DC booth and the gentleman gave me a set of the new undercut gel
seals for free.
DC is the best, for customer service.
Craig Smith
XX
On Behalf Of Bill Settle
Sent: Saturday, February 03, 2007 6:03 PM
Subject: Re: RE: Re: headset - bad mike test proc needed
<billsettle(at)bellsouth.net>
Snip----------
back to Garmin.
Bill Settle
RV-8 Wings
Craig Smith
CH640 builder
SN: 0078
--George Carlin
eedetail
PostPosted: Mon Feb 05, 2007 7:39 am    Post subject: Re: headset - bad mike test proc needed Reply with quote
Folks,
Thanks for the good info. I was looking for a way to test my headset without getting to the airport, but I had not really mentioned that important fact. Best way to test them is in the air anyway. Not sure what went wrong, but the one mike is definately dead. Definatly gonna get David Clark this time.
TimE
frank.hinde(at)hp.com
PostPosted: Mon Feb 05, 2007 8:58 am    Post subject: headset - bad mike test proc needed Reply with quote
