		dcreech3(at)hotmail.com Guest
				 Posted: Tue Jan 09, 2007 7:07 pm    Post subject: Ignition noise leaks |
				QUOTE FROM ROBERT LAIRD:  "A good ICOM or Vertex handheld radio should be
 more than adequate for your needs...   The rubber ducky antenna -- assuming
 you don't have any ignition noise leaks on your plane -- is quite good for
 airport and plane-to-plane communication."
 This leads me off on a tangent about the "ignition noise leaks".  My
 handheld Yuasa worked okay in my 503-powered Firestar II for years, but then
 got so that when I transmit, all I seem to put out is engine noise.
 (Reception is still okay).  I had the radio overhauled with no improvement.
 Could something have changed about the engine -- i.e., an "ignition noise
 leak" that wasn't there before?  If this is a possibility, what should I
 look for?
 Lee
		rlaird
				 Posted: Tue Jan 09, 2007 7:18 pm    Post subject: Ignition noise leaks |
				Well, sure... your spark plug wires/caps will decay over time and cause radio noise leaks (and other bad stuff).  Your grounding could be degrading... all kinds of possibilities, unfortunately.
   -- Robert
  On 1/9/07, LEE CREECH <dcreech3(at)hotmail.com (dcreech3(at)hotmail.com)> wrote:[quote] --> Kolb-List message posted by: "LEE CREECH" <dcreech3(at)hotmail.com (dcreech3(at)hotmail.com)>
 look for?
 Lee
Robert Laird
formerly: MkIIIc w/ 912ULS  &  Gyrobee
current:  Autogyro Cavalon w/ 914ULS
Houston, TX area
http://www.Texas-Flyer.com |
 noise
 should I
 | look for?
 | Lee
 Lee:
 A couple neglected items:
 1-antenna coax cable.  Make sure it is in good shape, as well as the
 BNC connectors.  Check it out with a good multimeter.
 2-headset.  I blamed my buddys' poor radios for my inability to hear
 them clearly.  Come to find out my headset wire was inop.  Changed
 headsets to the DRE6000 ANR and my radio problems went away.
  _________________ John Hauck
Titus, Alabama |
		Richard Pike
				 Posted: Tue Jan 09, 2007 7:24 pm    Post subject: Ignition noise leaks |
				I guess what we need to know is, what sort of electrical stuff does the
 airplane have on it? If we eliminate what it doesn't have, then it is easier
 to focus on possible problems.
 Richard Pike
 MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		jindoguy(at)gmail.com Guest
				 Posted: Wed Jan 10, 2007 4:59 am    Post subject: Ignition noise leaks |
				Lee, Did you accidentally get B8ES plugs instead of BR8ES? Have you got the metal caps on your spark plugs? Is your handheld run off batteries or ships power?
 Rick
 On 1/9/07,  LEE CREECH <dcreech3(at)hotmail.com (dcreech3(at)hotmail.com)> wrote: 	  | Quote: | 	 		   --> Kolb-List message posted by: "LEE CREECH" <dcreech3(at)hotmail.com (dcreech3(at)hotmail.com)>
 look for?
 Lee
 Rick Girard
 "Ya'll drop on in"
 takes on a whole new meaning
 when you live at the airport.  [quote][b]
		David.Lehman
  Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
				 Posted: Wed Jan 10, 2007 5:18 am    Post subject: Ignition noise leaks |
				A friend of mine had the same problem with a 503 and Icom handheld...  Icom told him that the handheld is very voltage sensitive and wouldn't handle the higher voltage the regulator was putting out...  He installed some kind of resister and the Icom transmitted perfectly...
 DVD
 look for?
 Lee
  _________________ ô¿ô
"Both optimists and pessimists contribute to the society.  The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
				 Posted: Wed Jan 10, 2007 6:47 am    Post subject: Ignition noise leaks |
				It doesn't have much.  No battery, starter or strobe, just a Key West
 rectifier/regulator which powers the handheld and GPS.  I do use BR8ES
 resistor plugs. Unplugging the radio from ship's power doesn't improve
 matters.
 Lee
 [quote]From: "Richard Pike" <richard(at)bcchapel.org>
 Reply-To: kolb-list(at)matronics.com
 To: <kolb-list(at)matronics.com>
 Subject: Re: Ignition noise leaks
 Date: Tue, 9 Jan 2007 22:23:49 -0500
 easier to focus on possible problems.
 Richard Pike
		Richard Pike
				 Posted: Wed Jan 10, 2007 3:16 pm    Post subject: Ignition noise leaks |
				Since you are using resistor plugs, that is not likely the problem.
 (I do not use resistor plugs, and have no ignition noise problems. Another
 thread...)
 There are several sources for electrical noise. All of them center around
 wires carrying alternating current to somewhere in the cockpit or near the
 antenna. DC wires do not normally carry anything that makes noise. The
 easiest way to get rid of radio noise is to shield any wires carrying A/C,
 like kill switches and tach.
 For your kill switch wires, try using microphone cable. Typically, it is two
 or three wires inside a tinfoil or woven shield. Ground one end of the
 shield to the engine, do not ground the other end of the shield. Same for
 the tach.
 If your Key West is a long way from the engine, then your unshielded A/C
 wires are acting as an antenna between the engine and the Key West. Shield
 those wires and ground them at the engine end, especially if they are close
 to the antenna.
 If the noise rises and falls as you rev the engine, then it might be
 ignition, but in my experience, ignition is a small component of overall
 radio noise. Most of the noise comes from wires in the harness that are
 carring alternating current from within the magneto, typically the tach and
 kill switch wires.
 If you are using an external antenna, consider switching to a rubber duck.
 Experiment with the external antenna grounded/ungrounded to the airframe and
 see if anything changes. And when using the radio seperate from the aircraft
 power supply, make sure the radio batteries are hot.
 Let us know what you find out - got to build up the database ya' know...
 Richard Pike
Kingsport, TN 3TN0
				 Posted: Wed Jan 10, 2007 4:35 pm    Post subject: Ignition noise leaks |
				At 06:15 PM 1/10/07 -0500, you wrote:
 the tach.
 Lee,
 I found most of my problems stemmed from the kill switch wires.  After I put
 the kill switches back on the engine and activated them with woven fish
 line, I had no ignition noise in the radio.  Shielding as Richard states
 will be a big help and may be easier than moving the kill switches.  You may
 want to use very small coax cable.  It might be a little lighter.
 Jack B. Hart FF004
 Winchester, IN
				 Posted: Wed Jan 10, 2007 7:45 pm    Post subject: Ignition noise leaks |
				The wiring harness that includes the kill switch and tach wires does in fact
 run near the radio, (along the bottom left side of the cockpit) but that
 didn't seem to be an issue until SOMETHING changed.
 Lee
 Date: Wed, 10 Jan 2007 18:15:29 -0500
 thread...)
 two or three wires inside a tinfoil or woven shield. Ground one end of the
 the tach.
 to the antenna.
 kill switch wires.
 and see if anything changes. And when using the radio seperate from the
 aircraft power supply, make sure the radio batteries are hot.
 Richard Pike
				 Posted: Thu Jan 11, 2007 8:35 am    Post subject: Ignition noise leaks |
				At 10:45 PM 1/10/07 -0500, you wrote:
 Lee,
 Try another headset.  May be a ground shield has broken loose.  My radio has
 an automatic noise reduction feature.  Check to see if yours is
 inadvertently turned off.  Borrow a different radio and try it to see if it
 picks up the same noise.  If so, you know it is not your radio. Etc. The
 only way to find out what it is to eliminate possibilities until the cause
 becomes obvious.
 Jack B. Hart FF004
 Winchester, IN
		rap(at)isp.com Guest
				 Posted: Sat Jan 13, 2007 6:22 am    Post subject: Ignition noise leaks |
				I used BRE8S plugs for a while on my last  ultralight and had alot higher plug failure rate than the B8ES plugs. Lucky all  the failures were on the ground. Scared me off the resator plugs. Rick Pearce  MK3C
  [quote]   ---
		Richard Pike
				 Posted: Sat Jan 13, 2007 6:35 am    Post subject: Ignition noise leaks |
				I'm with you. If the electrical system is done right, resistor plugs don't  really help the radio much, and considering the small spark plug gap that  Rotax calls for, the spark plugs apparently need all the energy they can get,  not more resistance.
  Yet Rotax specifies them, and lots of people use them, so what do I  know?
  Richard Pike
  [quote]   ---
Kingsport, TN 3TN0
		olendorf
  Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
				 Posted: Mon Feb 05, 2007 10:52 am    Post subject: Re: Ignition noise leaks |
 This one caught me once.  When I changed engines I ran into radio problems as well as a tach problem.  Since I had a new engine I put a new tach on it. Well, the tach didn't work too well so I sent it off to Westach and they tested it.  It was fine. They asked me if my engine was grounded to the airframe and it turns out it wasn't.
 Once I grounded my engine and all the shields from the wires to a central point on the airframe, my tach worked great and the radio noise was much reduced.
 By the way Westach charged me $0.00 and paid the shipping to return my tach to me.
  _________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
