jonlaury
Posted: Fri Feb 02, 2007 10:43 am Post subject: Circuit needed |
I have auxillary fuel tanks that are pumped to a header tank for use. I plan to use an OFF-ON-(ON) switch coupled with a pressure switch (NC, and already in my parts bin) to activate a blinking LED when there's no pressure and to activate the pump. When the pump pressurizes the line and opens the p-switch, the LED goes to steady on.
Does one use a capacitor to get the LED to blink? and is there a "null" between the ON-(ON) positions?
Obviously I need help on the circuit design.
Thanks for any help you can offer.
John
nuckollsr(at)cox.net Guest
Posted: Fri Feb 02, 2007 11:10 am Post subject: Circuit needed |
At 10:17 AM 2/2/2007 -0800, you wrote:
| Quote: | I have auxillary fuel tanks that are pumped to a header tank for use. I
You can buy leds that flash . . . but it
looks like you need the same led to light
steady too. This will take some electronics.
How does the pump develop and magnitude
of pressure? Fuel transfer pumps generally
operate into an open line to another tank
with a very low order of pressure.
You say you have a pressure switch. What
pressure level causes it to change states?
| Quote: | and is there a "null" between the ON-(ON) positions?
No . . . not if it's a really good good switch . . .
Need more 'input' . . .
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
fvalarm(at)rapidnet.net Guest
Posted: Fri Feb 02, 2007 11:31 am Post subject: Circuit needed |
There are 12V LED's that come ready made to blink. Check digikey.
Bevan
RV7A
Egg H6 on order
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Burnaby
Sent: Friday, February 02, 2007 10:18 AM
Subject: Circuit needed
John
jonlaury
Posted: Fri Feb 02, 2007 10:12 pm Post subject: Circuit needed |
| Quote: | Bob,The aux pump pushes fuel into an EFI return line, open to the header tank, via a check valve. The pressure switch that I have isa one psi oil pressure switch, hence NC. It seems to me that it's necessary to not have a null betweenOn and (On) so that pressure is maintained to keep the P-switch open as that open switch is what should keep the pump energized. So what does a "good, good" switch cost? or who makes one? If having the NC switch is causing grief, I could buy a NO switch. Upon first search, I was so happy with finding a one psi switch that I didn't think about it being an Oil Press. switch which would be normally closed to light the idiot light. The idiot light went on when I realized what I had done. At 10:17 AM 2/2/2007 -0800, you wrote:
with a very low order of pressure.The aux pump pushes fuel into an EFI return line, open to the header tank, via a check valve. The pressure switch that I have is | 0 | Quote: | | The aux pump pushes fuel into an EFI return line, open to the header tank, via a check valve. The pressure switch that I have is | 1 | Quote: | | The aux pump pushes fuel into an EFI return line, open to the header tank, via a check valve. The pressure switch that I have is | 2
Posted: Sat Feb 03, 2007 9:20 am Post subject: Circuit needed |
At 10:09 PM 2/2/2007 -0800, you wrote:
| Quote: | Bob,
Against what resistance to flow is the 1 psi expected to
develop? Is the cracking pressure of the check valve
greater than 1 psi?
| Quote: | It seems to me that it's necessary to not have a null between
Switches come in a host of characteristics that
can define operating pressures +/- errors and
drift, hysteresis, transfer times, etc.
| Quote: | So what does a "good, good" switch cost? or who makes one?
what I had done.
Hmmmm . . . let me see if I really understand. You
want a switch to operate when a pump develops a pressure
against the back side of a check valve. Is it the
purpose of this switch do de-energize the pump when
the pressure drops below the desired switch point
(i.e. is no longer moving fluid)?.
Know that off-the-shelf oil pressure switches can have
very wide tolerances to setpoint. Their purpose is
to annunciate gross failures of oil pressure, not to
warn of impending failure due to some reduction in
oil pressure.
There are some alternatives to oil pressure switches
but I need to fully understand the task.
jonlaury
Posted: Sun Feb 04, 2007 9:58 am Post subject: Circuit needed |
I think the problem here is that I haven't communicated what I want this circuit to do.
When I power up the aux fuel pump switch {Off-On-(On)}, I want an LED to flash, indicating power on and no fluid being pumped. When I switch to (On) the pump should energize, pump fuel and pressurize the line and P-switch upstream of the check valve. The P-switch should now take over the power delivery to the pump, as long as it's closed/open under pressure, and light a steady ON LED, indicating fluid being pumped. When the pump exhausts the aux tank fuel, pressure should go to 0psi, P-switch opens/closes, pump stops, LED flashes indicating no more fuel in line.
Downstream, of the check valve, is the EFI return line flow, with some marginal amount of pressure, that I think will add to and be sufficient to actuate the P-switch.
Sorry for the confusion.
J
Posted: Sun Feb 04, 2007 12:25 pm Post subject: Circuit needed |
At 08:59 AM 2/4/2007 -0800, you wrote:
| Quote: | I think the problem here is that I haven't communicated what I want this
circuit to do.
Okay, I think I got it. Here's a cartoon of the concept.
http://www.aeroelectric.com/Pictures/Schematics/Fuel_Pump_Controller.pdf
Moving switch from OFF to ON puts power on a 555 timer
arranged to flash an LED but the pump remains un-powered.
Holding the switch in the (ON) position applies power to
pump and biases the flasher to "stick" in the steady-on
state. If pressure comes up sufficiently to close the
pressure switch, then the pump will continue to run, the
light will stay steady after the switch is released. When
pressure drops below set point on switch, power is removed
from the pump and the flasher is allowed to resume its
transitions between states.
This begs for a microcontroller to allow use of either
a normally open or normally closed switch. Further, while
holding the switch in the (ON) position, the light should
not be allowed to stop flashing UNLESS pressure comes up
indicating that the system will stay in the fuel transfer
mode after the switch is released.
Keep in mind that this is a simplified diagram intended
to speak to operating concept. It needs to be fleshed out
for parts values and system interface details . . .
Do I have it right?
( EVERY day . . . )
jonlaury
Posted: Mon Feb 05, 2007 10:33 am Post subject: Circuit needed |
[quote]EXACTLY! John Okay, I think I got it. Here's a cartoon of the concept.
Do I have it right?[b]
john(at)ballofshame.com Guest
Posted: Mon Feb 05, 2007 10:51 am Post subject: Circuit needed |
re: computer control. Interesting you should mention that. I've been
fiddling around with the BASIC Stamp processors lately.
http://www.hobbyengineering.com/SectionBS.html#IX1024
These things ROCK and are very simple to program. They're perfectly
suited to doing things like simple logic, monitoring, flashing LED's, etc
etc.
They run on 9V so you need a regulator or transformer of some sort. You
will also have to build in some simple protection from spikes and maybe
low voltage. I've been collecting a list of tons of different
applications for these things. Everything from solid state interlocks to
annunciators.
Neat stuff and not too expensive.
-John
www.ballofshame.com
| Quote: | EXACTLY!John Okay, I think I got it. Here's a cartoon of the concept.
Do I have it right?
Posted: Mon Feb 05, 2007 6:35 pm Post subject: Circuit needed |
At 10:51 AM 2/5/2007 -0800, you wrote:
etc.
annunciators.
That works. Right now we're working with one of the Stamp's little
brothers, he PIC12F683. My software guy is getting really talented
with this chip (costs just over $1 in hundreds) and has a lot
of features for the cost. Programmers are dirt-cheap too.
Of the ones we've tried so far, the PICkit-II is our favorite
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref 72536&Row=688347&Site=US
It comes with an editor-assembler-debugger package for under
$40. This chip is the core of our AEC9011 and about a dozen
other products in the development pipe.
( EVERY day . . . )
Posted: Tue Feb 06, 2007 7:07 am Post subject: Circuit needed |
At 10:18 AM 2/5/2007 -0800, you wrote:
Okay, I can pop a uC chip with the code to nicely
implement the idealized control scenario. The weakest
link in the chain is pressure switch selection.
Have you pressure tested the switch you have in hand?
We can make a NC switch work in the software but
it would be much better if you had an NO device.
It would be even better if the switch were adjustable.
Check out pages 4-5 of
http://content.honeywell.com/sensing/hss/hobbscorp/pdf/cat_pav.pdf
( EVERY day . . . )
