Posted: Mon Feb 05, 2007 9:28 pm Post subject: what do you call yourself to ATC? |
Hey all -
just sitting around staring at the James cowl that I picked up this evening from the freight station, and I wondered... when you call ATC and you're flying an RV, what do you call yourself? I know about 97% of you guys just rolled your eyes, but I've never flown in an RV of any type. Or anything experimental at all. Do you say "experimental 12345 downwind abeam" or what? Inquiring minds want to know.
cj
#40410
fuse
www.perfectlygoodairplane.net
jdalton77(at)comcast.net Guest
Albert Gardner
Posted: Mon Feb 05, 2007 10:02 pm Post subject: what do you call yourself to ATC? |
FAR's say that on your first call you must identify yourself as Experimental
123XX but I notice after that sometimes if they have time they want to know
more. Once spent 10 min talking about RV's to ATC in a quite sector. He was
building a 9A.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Tim Olson
Posted: Mon Feb 05, 2007 10:03 pm Post subject: what do you call yourself to ATC? |
You've got it right. "Experimental <N-Number>, 10 miles East at 6500'
inbound with Oscar" For filing, I had been filing HXB/G, but now that
I hear "RV10" is in the system, RV10/G should work too. Usually
ATC asks what kind of plane we are, when they see the speeds we're
making....then I tell them I'm an RV10.
Chris Johnston wrote:
| Quote: | Hey all -
know.
cj #40410 fuse www.perfectlygoodairplane.net do not archive
Jack.Phillips(at)cardinal Guest
Posted: Tue Feb 06, 2007 4:23 am Post subject: what do you call yourself to ATC? |
In my Pietenpol, I usually call in "November X-Ray 899 Juliet Papa". Invariably ATC will ask what type of Experimental I am. They are so used to high speed experimentals like RV's, they want to know what kind of Experimental is crawling across their radar screen at 58 knots.
Jack Phillips
#40610
Finishing the Elevators
coop85(at)bellsouth.net Guest
Posted: Tue Feb 06, 2007 4:49 am Post subject: what do you call yourself to ATC? |
For filing purposes, I've had good luck tell the briefer on the phone I'm a
RV-10/G, however on DUATS RV10 is still not a viable option for some reasons
(just double checked this morning). I'll often pick RV-6 then write in the
comments I'm really a 10 although that has never really worked for some
reason.
Does anyone have any info on the FAA updating their system to enter RV-10
online?
Marcus
Posted: Tue Feb 06, 2007 6:39 am Post subject: what do you call yourself to ATC? |
I hear some call "experimental", a few call "red experimental" and most call
"rv-whatever". I don't know what is officially the right way, but most, in
my experience, say the actual model of airplane, not experimental. I have
heard of several cases where ATC wanted to know about and chat about "that
4-seat RV" and one case where they actually asked the pilot to change
frequencies to chat about the plane, especially when hitting ground speeds
over 185Kts on descent into an airport.
Do not archive.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
GenGrumpy(at)aol.com Guest
Posted: Tue Feb 06, 2007 5:06 pm Post subject: what do you call yourself to ATC? |
Marcus,
I talked with both FAA and others, and Van's has to submit the info to the FAA, then all the rest of the flight plan companies can pick the designation off the FAA list.
I bugged Van's about it several months ago, but not sure I got anyone there to do anything.
Maybe all the other list users can prod Van's to do the necessary (and easy) paperwork with the FAA!
grumpy
40404 and 45.5 hrs and waiting for XBOW return!
In a message dated 2/6/2007 6:51:56 AM Central Standard Time, coop85(at)bellsouth.net writes:
| Quote: | --> RV10-List message posted by: "Marcus Cooper" <coop85(at)bellsouth.net>
reason.
online?
Marcus
Do not archive |
av8or(at)cox.net Guest
Posted: Tue Feb 06, 2007 5:23 pm Post subject: what do you call yourself to ATC? |
What paperwork is involved and where can we get it? I'll fill it out and send it to Van's for their signature. Can't make it easier than that.....
JT Lenhardt
#40262
Posted: Tue Feb 06, 2007 5:57 pm Post subject: what do you call yourself to ATC? |
Van's has to do the paperwork and send to FAA.
All we can do is pressure them to do it!
In a message dated 2/6/2007 7:28:37 PM Central Standard Time, av8or(at)cox.net writes:
[quote] What paperwork is involved and where can we get it? I'll fill it out and send it to Van's for their signature. Can't make it easier than that.....
JT Lenhardt
#40262
Posted: Tue Feb 06, 2007 7:35 pm Post subject: what do you call yourself to ATC? |
I just fired off an e-mail to Van’s. Maybe if everyone did the same as Grumpy suggests we’ll get some action. If that doesn’t work, perhaps we all call and waste more of their time on the phone than it would take to complete the paperwork they’ll get the message J Let’s be nice though, I’d rather be flying under an assumed type than flying something else!
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Sent: Tuesday, February 06, 2007 8:06 PM
Subject: Re: what do you call yourself to ATC?
Marcus,
grumpy
reason.
online?
Marcus
Do not archive http://www.matronics.com/Navigator?RV10-List | 01234
sschmidt(at)ussynthetic.c Guest
Posted: Thu Feb 08, 2007 2:00 pm Post subject: what do you call yourself to ATC? |
I would say more and more I am hearing "RV XXXX", and Experimental is
phasing out. I have talked to a few different ATC controllers and they
all know what an RV is and like to hear that.
Is Steve Darton listening? What do you think?
Is there any problems saying "RV 104XP"? It seems like everyone up here
calls themselves "RV" and I have continued to called myself Experimental
but that is such a long word. I'm actually going to start saying "RV"
now and see what they say.
Scott Schmidt
sschmidt(at)ussynthetic.com
Dave(at)AirCraftersLLC.co Guest
Posted: Thu Feb 08, 2007 3:33 pm Post subject: what do you call yourself to ATC? |
AIM says to use "experimental" initially, then omit, and most operating
limitations only require that much when calling the tower.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
brucelas(at)yahoo.com Guest
Posted: Thu Feb 08, 2007 5:37 pm Post subject: what do you call yourself to ATC? |
john.erickson(at)cox.net Guest
Posted: Thu Feb 08, 2007 6:23 pm Post subject: what do you call yourself to ATC? |
Scott,
The AIM is very specific about this. Here is the quote (the examples in the
quote are from the AIM also).
QUOTE
"3. Civil aircraft pilots should state the aircraft type, model or
manufacturer's name, followed by the digits/letters of the registration
number. When the aircraft manufacturer's name or model is stated, the prefix
"N" is dropped; e.g., Aztec Two Four Six Four Alpha.
EXAMPLE-
1. Bonanza Six Five Five Golf.
2. Breezy Six One Three Romeo Experimental (omit "Experimental" after
initial contact)."
END QUOTE
Basically, using "Experimental XXX" is counter to what the AIM says. When
you think about it, it makes sense. The purpose of using the manufacturers
name in the callsign (not trying to start an argument on who the
manufacturer of an experimental is... For these purposes let's just call it
RV...) is to give the controller a small clue as to your capabilities. RV
XXX does that while Experimental XXX doesn't. Just tag Experimental to the
end of your callsign on initial contact to fulfill the requirements of the
ops limits and the AIM and you're good...
RV-10 #40208 Wings
RV-8 N94DW (or should that be RV 94DW Experimental? )
(btw, moving to Ogden in 2 weeks... Any chance I can get a look at that
gorgeous plane?)
bob.kaufmann(at)cox.net Guest
Posted: Thu Feb 08, 2007 6:25 pm Post subject: what do you call yourself to ATC? |
Damn Lucky
Bob K 0<))
Posted: Fri Feb 09, 2007 6:04 pm Post subject: what do you call yourself to ATC? |
There may be more to the story than just AIM. Here is a copy (picture, not
cut/paste unfortunately) of my Operating Limitations:
This would imply you need to tack on "Experimental" to at least the first
call. While an argument could probably be made that most, if not all
eventually, controllers know a RV-10 is an experimental it legally probably
shouldn't be assumed. FWIW, I always use "Experimental 585MR" then just
"585MR" or even "5MR" if the conversation has gone back and forth a few
times.
Marcus
 Download |
| Filename: |
winmail.dat |
91.93 KB |
| Downloaded: |
385 Time(s) |
Posted: Tue Feb 13, 2007 1:05 pm Post subject: what do you call yourself to ATC? |
I was reading the AIM last night trying to find something about this and
saw the same thing you did.
Sounds like the official way to make a call would be "RV-10 104XP
Experimental", then after the first call just "RV-10 4XP" or even "RV
4XP"
That is what I am going with!
Scott Schmidt
