Another hardware choice?????
indigoonlatigo(at)msn.com
PostPosted: Sun Feb 04, 2007 9:01 pm    Post subject: Another hardware choice????? Reply with quote
I need to order more nutplates and the special K1100 are the dimpled ones.
It seems that Aircraft Spruce And Specialty only carry the non dimpled ones.
Van's sells them, but my orders seem to take one and a hafl weeks to get
to me eventhough I am only one border away. It's starting to drive me
nuts.......plates.
Anyone else have a source???
John G. 409
orchidman
PostPosted: Sun Feb 04, 2007 9:11 pm    Post subject: Re: Another hardware choice????? Reply with quote
John,
Try calling B & B Aircraft Supplies at 913-884-5930. Great people to deal with for all types of nuts, screws, rivets and everything inbetween. They are in KS and will ship same day.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
bldgrv10450(at)comcast.ne
PostPosted: Sun Feb 04, 2007 9:26 pm    Post subject: Another hardware choice????? Reply with quote
You might try Aerocraft
http://www.aerocraftparts.com/Categories.aspx?Category e993992-c33b-4a1b-9923-2b58936f4f12
Not sure if they have the dimpled type but they have some bonding nut plates
that are interesting. The colored silicon bungee goes through the hole and
holds the nut plate up to the surface allowing adhesive attachment to set
and keeping the screw hole clear. When your adhesive is dry, just pull out
the bungee.
Paul Grimstad
RV10-40450 fuselage
Portland, OR 97219
Tim Olson
PostPosted: Mon Feb 05, 2007 4:26 am    Post subject: Another hardware choice????? Reply with quote
I'm surprised ACS wouldn't have them. I'd try calling them. But,
the best advice I can give on those is to pick a couple of the
common ones, like the #8 screw ones, and order a couple dozen
minimum as spares. Over time I came to rely on my excess supply
because I was constantly short, and as you approach the end of the
build you'll find lots of uses for them as you customize things.
The only way to prevent the headaches is to just stock up on
the screws/nuts/washers and common hardware that you use, and
build up your own supply. You'll pay part of it in
repeat shipping anyway if you don't.
ones. It seems that Aircraft Spruce And Specialty only carry the non
dimpled ones. Van's sells them, but my orders seem to take one and a
hafl weeks to get to me eventhough I am only one border away. It's
starting to drive me nuts.......plates.
John G. 409
wcurtis(at)nerv10.com
PostPosted: Mon Feb 05, 2007 9:52 am    Post subject: Another hardware choice????? Reply with quote
Try here:One lughttp://www.bonaero.com/Nuts.htm#MS21053http://www.bonaero.com/images/ms21053.GIFTwo Lughttp://www.bonaero.com/Nuts.htm#MS21049http://www.bonaero.com/images/ms21049.GIF#8 seems to be the smallest they have however. I have no experience ordering from them either.Williamhttp://wcurtis.nerv10.com/ --> RV10-List message posted by: "John Gonzalez" I need to order more nutplates and the special K1100 are the dimpled ones. It seems that Aircraft Spruce And Specialty only carry the non dimpled ones. Van's sells them, but my orders seem to take one and a hafl weeks to get to me eventhough I am only one border away. It's starting to drive me nuts.......plates.Anyone else have a source???Thanks,John G. 409 [quote][b]
dvanwinkle(at)royell.net
PostPosted: Tue Feb 06, 2007 10:01 pm    Post subject: Another hardware choice????? Reply with quote
John and Tim
The K1100 nutplates are listed on page 193 of the 2006 Wicks catalog. They
are actually listed as MS21049-L08K for the 8-32 and MS21049-L3K for the
10-32, with the "K" suffix indicating countersunk or dimpled rivet hole. I
purchased some of the 8-32s from them last summer.
Dean Van Winkle
RV-9A Fus/Finish/FWF
