Qualith of build and durability?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
Kayberg(at)AOL.COM
PostPosted: Sat Feb 03, 2007 12:56 pm    Post subject: Qualith of build and durability? Reply with quote
In a message dated 2/3/2007 2:52:29 PM Eastern Standard Time, georgiemun(at)yahoo.com writes:
Let me ask a couple of questions again, please take no offense to what I am asking.
1. Does the Lightning use the same wing spar design as the Esqual?
2. Why does the carbon fiber stop at the root of the wing and does not continue through to the tip of the spar? Is there a reason for this?
3. What is the third material in the spar (kind of looks like wood)?
4. Has there been improvements in the finish since the web site pictures were taken?
5. I know that there has been load testing performed on the wing, but has this also been performed for load over time? Some times the mixing of glass and carbon fiber does not rear it's ugly head right away. What kind of testing is performed to verify the integrity over many hours of use?
Since you are advocating the taking of no offense, I will assume you will do likewise. Some of us are a little sensitive when we offer personal testimony as to the veracity of something and the reader chooses to reject it. I will assume you are new to composites and trust you will not be offended by my explanations.
1) As I said before, there is no carbon fiber used in a Lightning airframe. So all of your questions that relate to carbon fiber are moot. I realize you see a black color, but that is a pigment, not carbon. Carbon fiber is very expensive and difficult to work with. As I understand it , there was a carbon fiber option for the Esqual, but the weight savings hardly justified the load it lifted from the purchasers bank account.
2) The substance that looks like wood is foam, although wood is used at one point in the spar (it carries little load) As you may know, wood and foam mostly act as spacers for the fiber structure and contribute little to the strength. It is the fibers themselves that have the strength.
3) As I also said before, WHATEVER YOU THINK YOU SEE IN THE PICTURES, the finish on the parts is considered to be first rate. Since I have done my time sanding epoxy, I think I know what I am talking about. When body shop guys, particularly Corvette people, tell me the finish is great, I tend to believe them. If you are anywhere near Martinsburg, WV, come and see us. You can see for yourself. Check www.greenlandings.com for directions and more information. Oh, yeah, the latest website could use better spelling and diction, but that is my fault. We just needed to get the info up, I will adjust it later.
I dont know if the spar is the same as the Esqual. I doubt if anyone does. Unless someone were to peel one of each apart and compare them, it would be difficult to say for certain. However spar design in this type of aircraft is well known from such planes as the Glasairs, Lancairs, Pulsar's, etc. Also well known is how to test them. When you looked on the website and noticed all the sandbags stacked on the wing and the claim that it exceeded the strength of 95% of the General Aviation aircraft flying today, I should think you would be impressed.
The only sure way to verify integrety over many hours of use is to use it for many hours!! As you may also know, epoxys have a half life, typically over 20 years. So the wings will actually be getting stronger for a lenthy period of time before they begin to get weaker. The only real enimy of epoxy is ultraviolet, although heat can soften the material and certain organic solvents can degrade the surface. So there is no real testing other than heat, some solvents and ultraviolet that will indicate longevity. Testing samples of epoxy mixes used during construction is standard in the industry and will easily reveal substandard batches. If you have a good design, assemble it identically each time and test your epoxies, it is quite reasonable to expect long life with a good ultraviolet shield.
I hope this helps.
Doug Koenigsberg
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
pequeajim
PostPosted: Sat Feb 03, 2007 1:38 pm    Post subject: Qualith of build and durability? Reply with quote
Georgie:
Your questions are valid and to be honest, I asked the same kind of questions when first looking at the Lightning. To your question about carbon fiber in the wing spar, yes, it does look like carbon fiber in there and I am not really sure myself the purpose behind it inside the wing as opposed to extending it out to the end of the spar. The pic I attached shows the fiber strands extending just beyond the wing root. I believe that Arion uses CF in the airframe around the dash and attach points for the wings. This is certainly a logical place to put it and would add rigidity. In the 2nd pic I have attached you can see this as well as a black stripe down the middle of the floor where the two fuse halves join together, as well as around the firewall. I don’t know if that is CF or something else.
As for the Lightning being a redesign of the Esqual, no, I believe they took everything that they knew about the Esqual and may have started from scratch. I would think that the aircraft are probably very similar since Buz I believe is flying an Esqual with Lightning wings? (Buz would need to confirm this).
I think your question was leading to the point that if there are so many Esquals flying without mishap and the Lightning’s basic design is based on the Esqual, then this adds proof to the robustness of the Lightning design. I would agree with that, but the designers would need to confirm that statement regarding design.
As far as the finish, I have no issues with how the aircraft parts are shipped to the dealers. You will need to do some sanding and body work, but overall, they are nicely done. Who ever built a Glasair, or Lancair without sanding?
Something else that you have not mentioned. This aircraft flies behind the Jabiru 3300. What a great little engine! Direct drive, standard auto plugs, easy to get as everything, (see attached pic). Beautiful!
I agree with Doug. Take a hike down to Green Landings and see for yourself. It did wonders for my confidence, and went a LONG way towards making up my mind to buy a Lightning. In fact, if you would like to go down together some time, I will ride with you. It’s worth another trip.
Jim!
dashvii(at)hotmail.com
PostPosted: Sat Feb 03, 2007 1:44 pm    Post subject: Qualith of build and durability? Reply with quote
George,
Before you come on the scene several were saying that they wanted
updated and more pics on the website. Pete said that that is in the works,
but it is difficult since they're in a time crunch and trying to help
builders finish their planes. So I have been posting some pics. Doug has
done a good job of trying to answer your questions.
Again, let me say welcome to the site and to try not to be offended. As
Doug implied this is a Lightning enthusiast site. Also try to understand
that folks like Doug at Green Landings have taken on the Lightning as a
builder assist and sales rep. These aren't guys that were hired by the guys
at Shelbyville, but rather he took it on to try to sale planes and make
money for his family. I doubt he'd take on a project plane that wasn't
something of quality, although I've admitedly never met him. There are
several Lightning owners on here, several that are interested, and several
that are just want to owners like myself. I don't work for the company, but
have flown the Lightnings and try to keep the Lightning list flowing with
present happenings at SYI. Buz has flown the prototype to do an indipendent
flight test for verifying numbers. Earl has done some flight testing with
the light sport compliant LIghtnings. The guys at Shelbyville are way too
busy to keep track of all of the traffic that is on the Lightning List. So
usually owners/builders/pilots try to share what information they have on
different subjects. As far as I know nobody that has bought one has been
dissappointed although several have been pleasently surprised.
I can post some pics of current planes on here if you'd like. The quality
is as good as any that I've seen, and better than most. I can also send you
by private email some of the flight test data so that you can go over it
data point by point if you are still in doubt of the performance figures. I
believe that the numbers are pretty incredible. In fact, I doubt there's
any other production aircraft with the same fuel burns and performance. I
am working on doing some indipendent flight testing for some speed mods
right now and after I finish that I can give you those numbers if you want.
Hope to see you around. If you get a chance to fly the plane and look it
over thoroughly I think that you'll come around and joing the "Lightning
Legion." Brian W.
Check out all that glitters with the MSN Entertainment Guide to the Academy
Awards� http://movies.msn.com/movies/oscars2007/?icid=ncoscartagline2
PostPosted: Sat Feb 03, 2007 1:53 pm    Post subject: Qualith of build and durability? Reply with quote
Buz's plane is an Esqual with Esqual wings. His plane does have a Lightning
cowling (modified for the shorter snout on the Esqual, and it has Lightning
gear leg fairings and wheels and wheel fairings. This alone made his plane
about 50mph faster! The overall shape of the planes is similar but it is a
different plane. Brian W.
Invite your Hotmail contacts to join your friends list with Windows Live
Spaces
georgiemun
PostPosted: Sat Feb 03, 2007 1:59 pm    Post subject: Re: Qualith of build and durability? Reply with quote
Doug:
No, I don't take offense, how can I? I'm just learning like many others on here. I appreciate your answers, however, I think that maybe Nick? would be better suited to answering the questions about the use of carbon fiber in the Lightning.
Jim:
Thanks for the pics, they clear up some questions in my mind. I may take you up on that trip down to Green Landings. They sound like a good bunch of guys and if I was driving, you would be right on the way down.
Brian:
Thanks for the offer. I did see your pics posted on the Matronics forum and they actually rekindled my interest in the aircraft, thanks again.
Nick:
I forgot to answer your question as to where the post was. It was on the Homebuilt Airplanes forums www.homebuiltairplanes.com
pequeajim
PostPosted: Sat Feb 03, 2007 2:00 pm    Post subject: Qualith of build and durability? Reply with quote
Thanks for the clarification...
vettin74(at)yahoo.com
PostPosted: Sat Feb 03, 2007 3:27 pm    Post subject: Qualith of build and durability? Reply with quote
The fellow who posted the before metioned Forwarded thread is on a site called www.homebuiltairplanes.com. name is ORION and is the site moderator....read some if the other posts if you will and make your own conclusions...
Nick
George SMith <georgiemun(at)yahoo.com> wrote:
[quote] I am interesting in possibly purchasing the Lightning and have been surfing around the forums for information on the aircraft. Since it is so new, it is difficult to find many people who have experience with it. My concern is that I am need to research this well as spending this much money on a hobby is not well spent if I am not happy with my purchase 2-3 years down the line.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
In reading one particular forum, I came across a couple of guys asking questions about the Lightning and one gentleman�s thoughts on the aircraft after visiting the Arion Aircraft web site.
An interesting new airplane. I haven't heard of this one but they do show quite a bit at their web site to alloow me to make at least a few cursory observations. First, it looks like a slightly modified copy of a Lancair 235 or 320. There are minor differences and it does look to be using a different wing section (although I'd have to confirm that), but overall it seems similar enough to at least raise an eyebrow.
They show quite a few pictures of the parts and the various sub assemblies so you can get at least an idea of what's involved in putting this together. It looks to be a fairly standard structure although one or two areas would need a bit of a closer examination in order to see the details.
But looking through all the presentation materials all I could think of is: Sloppy. If these pictures are truly representative of their parts and their work I'd probably recommend a deeper investigation before committing. The first picture I randomly selected was that of the rudder assembly. Even a cursory glance shows that the molded part came out of the tool with surface wrinkles - almost as if the material bunched up and separated from the tool. Also, looking at the sides of the fuselage, that too looks to be uneven. The surface seems to be poorly shaped (look at the light reflections) with surface discontinuities that make it look like the surface of an orange. It is possible that this is misleading and maybe it has something to do with the tool prep or the primer coat, but quite frankly I can't think of anything that would cause this except poor tooling or maybe poor quality control during fabrication.
Another area that might cause some concern is the wing spar - possibly the strength, but more so the manufacturing itself. First of all, it is a combination of graphite and glass. While feasible, generally this type of structure is not recommended unless one really understands how the materials behave together. The significant difference in stiffness between the glass and the graphite makes each component see the loads a bit differently, with more of the load going to the stiffer component of the structure. If this is not understood in the design of the part, this could lead to eventual structural problems.
From the layup standpoint, if you look at the root of the spar, the graphite ends petty much at the root rib. Why? And then the way it is laid up, it is very sloppy, with untrimmed fibers running every which way. Not really a good presentation and certainly not something that most companies would want to use as a demonstration of their skills.
Regarding their performance numbers, they look to be something that they took from some analysis program without really verifying what they were presenting - I'd prefer to see something that's a bit more accurate and flight proven. I too would be a bit skeptical of several of the claims, although it is a clean airplane and some of the numbers may not be too far off. The glide ratio? Yea, I'd question that too. Even without the prop it sounds way too good to be true.
In short, if you're interested in this airplane I'd suggest that you hire someone in your area that really knows small airplane design and engineering issues and have him or her go through their factory with you.
This kind of spooked me, (mainly because I do not understand composites); so I did a little research on some of the ponts regarding the spar and hear similar opinions. I would be interested in hearing why the wing spar is constructed in this manner? Why is carbon fiber just through the interior of the wing and not out to the end of the spar. Is there a design consideration in this? The points about the finish are not really that big a concern to me. While true that the finish is not the same as that of say a CT, Dynamic, or Pulsar, I believe this because their products are delivered in a more complete state, (those companies having the opportunity to do more finishing on their end), I don't mind a little body work now and then.
Also, from reading this list, I see that the lightning seems to be a redesign of the Esqual? Did the Esqual use the same type of wing spar composition as the Lightning. If so, this would lend some validation to the fact that there must be several of those flying and no real problems to speak of?
Please understand that I am not complaining about the build quality or design, so do not take offense. I am just searching for some answers to questions that have been raised about the design and finish before I make TV dinner still cooling?
[url=http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/]Check out "Tonight's Picks"[/url] on Yahoo! TV. [quote][b]
PostPosted: Sat Feb 03, 2007 3:45 pm    Post subject: Qualith of build and durability? Reply with quote
Nick,
George wants an affirmation that there is not any carbon fiber in the
Lightning from you. You would be the person to know. Brian W.
Turn searches into helpful donations. Make your search count.
georgiemun
PostPosted: Sat Feb 03, 2007 5:56 pm    Post subject: Re: Qualith of build and durability? Reply with quote
dashvii(at)hotmail.com wrote:
Nick,
I really would like to know what the airframe and wing spar are made of?
Can you help me Nick?
pete(at)flylightning.net
PostPosted: Mon Feb 05, 2007 12:54 pm    Post subject: Qualith of build and durability? Reply with quote
Hi All,
The internet is a great tool but sometimes there are some posts that really make me shake my head. The quote from the moderator of the www.homebuiltairplanes.com web site is another one of those. It always amazes me when someone sets himself up as a self proclaimed “expert” and then makes statements based on assumptions about photos posted on another site.
Sloppy? He first talks about wrinkles in the rudder skin. If he even had a cursory knowledge of composites he would know that the lines he sees are not wrinkles but the relief lines in the foam core that allow resin infusion. He would also know that a light scuffing with sand paper would make them disappear. The material was not bunched up. Nor was it separated from the tool. He makes assumptions without enough knowledge to make valid assumptions.
Second, he talks about the spar. He says that the combination of glass and carbon is “not recommended”. Well, he should tell that to Cirrus, Pulsar, Boeing, and others. Maybe they will change their wing construction to comply with this “expert”. If he tells Cessna right away maybe they can change their wing before the first of the “New Generation” aircraft are sold! He states that the carbon ends at the root rib when in actuality it extends on out the spar. You just can’t see it in the photo. Again, an “expert” making assumptions about items he can’t even see in a photo.
He questions the spar strength? On what basis? Maybe his vast knowledge of composites? We tested that wing to 11 G positive. Then we tested it to 11 G negative. Then in the high speed stall configuration. Photos of the test are on the web site. 95% of all aircraft wings in use today would not hold up to our test including Cessna, Piper, Mooney, Vans RV Series, Sonex, Zenith, and most others.
Finally, he doubts our performance numbers and thinks they are from an “analysis program” and he would prefer to see “[i]something that's a bit more accurate and flight proven”. [/i][i]Again he’s assuming we are not being forthright with our performance numbers. Well, those who know us and build with us know that we have not used “analysis programs” in the development of this aircraft. We built it the way we thought it should be built based on our experience over the last nearly 20 years building dozens of homebuilt aircraft. We put our own butt on the line and went out and flew it and reported the performance we saw. We prove it again every week by flying beside Vans RV-6 & 7’s and finding that we are faster when flown in the economy cruise mode. The RV’s will go faster if the pilots push the throttle to the 13 gph fuel use rate but at their 9.5 gph rate we are faster using our 5.5 gph. We even got to report first hand our glide ratio when Nick hit a turkey buzzard on the spinner and the prop shattered 7 miles away from the airport at 2500 ft above the ground and he had enough glide to get back to the airport and fly a std pattern! Maybe we’ll call that the Turkey Buzzard analysis program reporting a real life 17:1 glide.[/i]
[i] [/i]
[i]To sum it up, when we listen to the comments of builders who have completed composite aircraft and really know what they are talking about, we are encouraged by what they say about our kit. We will get better yet as this year goes by and you can rest assured that we won’t be reporting performance we don’t see.[/i]
[i] [/i]
[i]Part of my reason for responding here is to illustrate that you can’t always believe the info posted on the net. Too often list members make observations and offer opinions and advise that is well out of their area of expertise. Maybe they did sleep at a Holiday Inn but still…… Call me old fashioned but I think authors should remember that the freedom that allows postings on some internet list should be accompanied by the responsibility to have some idea of what they are talking about.[/i]
[i] [/i]
[i]Pete[/i]
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of George SMith
Sent: Saturday, February 03, 2007 8:47 AM
To: lightning-list(at)matronics.com
Subject: Qualith of build and durability?
In reading one particular forum, I came across a couple of guys asking questions about the Lightning and one gentleman’s thoughts on the aircraft after visiting the Arion Aircraft web site.
[i]An interesting new airplane. I haven't heard of this one but they do show quite a bit at their web site to alloow me to make at least a few cursory observations. First, it looks like a slightly modified copy of a Lancair 235 or 320. There are minor differences and it does look to be using a different wing section (although I'd have to confirm that), but overall it seems similar enough to at least raise an eyebrow.[/i]
[i][i]They show quite a few pictures of the parts and the various sub assemblies so you can get at least an idea of what's involved in putting this together. It looks to be a fairly standard structure although one or two areas would need a bit of a closer examination in order to see the details.
[/i]
[i]But looking through all the presentation materials all I could think of is: Sloppy. If these pictures are truly representative of their parts and their work I'd probably recommend a deeper investigation before committing. The first picture I randomly selected was that of the rudder assembly. Even a cursory glance shows that the molded part came out of the tool with surface wrinkles - almost as if the material bunched up and separated from the tool. Also, looking at the sides of the fuselage, that too looks to be uneven. The surface seems to be poorly shaped (look at the light reflections) with surface discontinuities that make it look like the surface of an orange. It is possible that this is misleading and maybe it has something to do with the tool prep or the primer coat, but quite frankly I can't think of anything that would cause this except poor tooling or maybe poor quality control during fabrication.[/i]
[i]Another area that might cause some concern is the wing spar - possibly the strength, but more so the manufacturing itself. First of all, it is a combination of graphite and glass. While feasible, generally this type of structure is not recommended unless one really understands how the materials behave together. The significant difference in stiffness between the glass and the graphite makes each component see the loads a bit differently, with more of the load going to the stiffer component of the structure. If this is not understood in the design of the part, this could lead to eventual structural problems.[/i]
[i]From the layup standpoint, if you look at the root of the spar, the graphite ends petty much at the root rib. Why? And then the way it is laid up, it is very sloppy, with untrimmed fibers running every which way. Not really a good presentation and certainly not something that most companies would want to use as a demonstration of their skills.[/i]
[i]Regarding their performance numbers, they look to be something that they took from some analysis program without really verifying what they were presenting - I'd prefer to see something that's a bit more accurate and flight proven. I too would be a bit skeptical of several of the claims, although it is a clean airplane and some of the numbers may not be too far off. The glide ratio? Yea, I'd question that too. Even without the prop it sounds way too good to be true.[/i]
[i]In short, if you're interested in this airplane I'd suggest that you hire someone in your area that really knows small airplane design and engineering issues and have him or her go through their factory with you.[/i][/i]
Please understand that I am not complaining about the build quality or design, so do not take offense. I am just searching for some answers to questions that have been raised about the design and finish before I make the decision to put down my money.
Thanks for any help that you can provide.
Georgie
Need a quick answer? Get one in minutes from people who know. Ask your question on Yahoo! Answers.
jimandmary(at)fastmail.us
PostPosted: Mon Feb 05, 2007 1:30 pm    Post subject: Qualith of build and durability? Reply with quote
Seems like it would be good if you (or Nick) put your rebuttal on the homebuiltairplanes.com website under the same thread as the comments were made. Letting it stand unchallenged there only seems to give it a sense of legitimacy. Perhaps some of the other happy Lightning owners could also respond there. However, I realize time is an issue so if you can't it's understandable but unfortunate.
Jim Young
[quote] From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Pete
Sent: Monday, February 05, 2007 3:53 PM
Subject: RE: Qualith of build and durability?
Hi All,
[i] [/i]
[i] [/i]
[i] [/i]
[i]Pete[/i]
[/i]
Georgie
5[b]
pequeajim
PostPosted: Mon Feb 05, 2007 6:43 pm    Post subject: Qualith of build and durability? Reply with quote
Well now I feel really embarrassed as I was the one who originally asked the question about Arion Aircraft, looking for some input as to the aircraft finish and performance indicators. Both Buz and Ryan have answered all of my questions to my satisfaction and I want you all to know that I did not let one man’s opinion affect my direction to purchase a Lightning, (or not). Georgie; I have pretty much kept my nose out of this because Pete is right; there are so many “knowledgeable” people on the internet, it can be confusing as to who to believe. I have asked around and understand the plusses and minuses of the Lightning design that I am very satisfied in what I would get when purchased. Believe me, there are NO airplanes out there that do not have faults in some way. Maybe the aircraft is too fast, too slow, requires too much finishing work, not enough, nothing is perfect. In looking at the Lightning, my determination is that the plusses FAR OUTWEIGH any minuses that I would ever have to deal with. That’s why I like the aircraft so much.
Trust me… Let’s ride down and take a look at what Ryan has in the shop. It will answer all your questions.
Jim!
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Jim and Mary Young
Sent: Monday, February 05, 2007 4:31 PM
Subject: RE: Lightning-List: Qualith of build and durability?
Jim Young
Hi All,
Finally, he doubts our performance numbers and thinks they are from an “analysis program” and he would prefer to see “[i]something that's a bit more accurate and flight proven”. [/i][i]Again he’s assuming we are not being forthright with our performance numbers. Well, those who know us and build with us know that we have not used “analysis programs” in the development of this aircraft. We built it the way we thought it should be built based on our experience over the last nearly 20 years building dozens of homebuilt aircraft. We put our own butt on the line and went out and flew it and reported the performance we saw. We prove it again every week by flying beside Vans RV-6 & 7’s and finding that we are faster when flown in the economy cruise mode. The RV’s will go faster if the pilots push the throttle to the 13 gph fuel use rate but at their 9.5 gph rate we are faster using our 5.5 gph. We even got to report first hand our glide ratio when Nick hit a turkey buzzard on the spinner and the prop shattered 7 miles away from the airport at 2500 ft above the ground and he had enough glide to get back to the airport and fly a std pattern! Maybe we’ll call that the Turkey Buzzard analysis program reporting a real life 17:1 glide.[/i][i][/i]
[i] [/i]
[i] [/i]
[i] [/i]
[i]Pete[/i]
[/i]
Georgie
[/b]
[b] href="http://www.matronics.com/Navigator?Lightning-List">http://www.matronics.com/Navigator?Lightning-Listhref="http://forums.matronics.com">http://forums.matronics.com
pdukor1(at)tampabay.rr.co
PostPosted: Tue Feb 06, 2007 7:23 am    Post subject: Qualith of build and durability? Reply with quote
Bravo!
Looking forward to S & F
Paul
Sarasota, Florida
georgiemun
PostPosted: Wed Feb 07, 2007 4:53 am    Post subject: Re: Qualith of build and durability? (Thanks) Reply with quote
Thank you to all who have made the effort to answer my questions.
Jim: I will contact you when I am going down.
Georgie
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
