n395v
Posted: Wed Feb 07, 2007 6:44 am Post subject: MP and fuel flow |
I have reviewed Dennis Savarese's power chart and am still getting the feel for the engine.
Just how much oversquare can you run these things.
It just doesn't feel comfortable running 1800 RPM at high power settings. Is this a legitamate concern or just my prejudice from running direct drive opposed engines?
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
_________________ Milt |
dsavarese(at)elmore.rr.co Guest
Posted: Wed Feb 07, 2007 7:52 am Post subject: MP and fuel flow |
Nothing to be concerned about. Take a look at the original Russian power
setting chart and it clearly suggests the engine being run "over square".
Dennis
george(at)gesoco.com Guest
Posted: Wed Feb 07, 2007 8:43 am Post subject: MP and fuel flow |
The only restrictions that I know of are the 5 minute limit on full power.
Radial engines are often run "over square".
The basic design allows this as they do not have the same torsionial
stresses on their single throw crank shaft. Multiple throw crankshafts set
up torsional and bending stresses on the long crankshafts on other designs.
The simple single plane cylinder arrangement also sets up different
vibration patterns that are easily counteracted with floating
counterweights. The M14P has primary vibrations in the 4.5 th order and the
ninth order that are way different from the four and six cylinder opposed
designs. The M14P has floating counterweights that effectively dampen the
vibrations.
As Dennis pointed out the manuals and log books show operations that
are way over square.
n395v
Posted: Thu Apr 26, 2007 4:07 pm Post subject: Re: MP and fuel flow |
Went to Sun and Fun last week. Departed Atlanta and flew same route and distance as did the prototype at same altitude 5500' and same power settings as the 360 HP prototype with it's pressure carb.The trip took 2.0 hrs.
Made the trip using 7 gallons less fuel consumption. This I attribute to being able to adjust mixture.
After approx 100 hrs I am able to say that:
At low altitude <10,000' I can get 175-180KTS TAS at 11.7GPH running 23" and 1950 RPM
Above 10,000' at 24" and 2000 RPM I can get 205 KTS TAS burning 14.5GPH
At 12,000' at 28" and 2700 RPM I see 225-230KTS TAS at 28-32GPH
