RRTRACK(at)aol.com Guest
Posted: Sat Dec 16, 2006 12:53 pm Post subject: Vixen Information |
I have just purchased a Kitfox Vixen ( HCY-012 ) and would like to talk with any early Vixen owners/builders.
This Kitfox has the long ( 32' ) wings and the wide ( 7' 11" ) elevator. And the wings are swept forward 1 degree. All similar to the Continental-powered Series 5 Vixen shown in the Pilot's Operating Handbook, but this one was originally built and is still powered by a 912 UL . I did not get a builder's manual with the plane and would like to know if this was the recommended set-up for this configuration. None of the "Tested CG Range" charts seem to match the weight and balance information received with the plane.
I have heard of some Kitfox IV builders forward sweeping there wings, was this to compensate for a heavy engine or for some performance design? What should this do for my Vixen? Also would like to know what the gross weight should be for this Vixen.
Thanks for your help,
Mark
Wisconsin
RRTRACK(at)AOL.COM (RRTRACK(at)AOL.COM)
Fox5flyer Guest
Posted: Sat Dec 16, 2006 1:32 pm Post subject: Vixen Information |
Congrats Mark on your new purchase. Yes, the forward wing sweep was to compensate for the heavy engine, namely the Lycoming O235, Cont IO240, and Subarus. Using the light 912 engine with forward sweep wings would probably create a tail heavy condition if not compensated by something extreme forward such as a heavy prop.
The gross weight would be determined by the model/year serial number which would be either 1400 or 1550.
Just my 2 cents.
Deke
S5 with forward swept wings and Soob with heavy prop
aldaniels(at)fmtcblue.com Guest
Posted: Sat Dec 16, 2006 1:50 pm Post subject: Vixen Information |
The 1 degree forward sweep is to move the center of lift forward to give
a better CG for heavy engines. I also put 1 degree on my 5 with a 7 FWF
tailwheel with a 912s that was built light and licensed for 1320 so I
could get the tailwheel on with better control. The only thing it did
for my weight and balance is that it limits how much I can carry in the
cargo compartment. I think it limits me to about 120 pounds, but if I am
not carrying bricks or sacks of cement it is not a problem. You would
have to do the math to see where it puts you with the short engine mount
of the early Vixen, but it should not be a problem. As far as gross
weight it could be 1400 or if it is one of the real early ones it could
be less. The information with the plane should tell you what the design
weights are. Even the later Vixen was limited to 1400 pounds with the 80
HP engine due to performance limitations.
RRTRACK(at)aol.com wrote:
Quote: | I have just purchased a Kitfox Vixen ( HCY-012 ) and would like to
Mark
Wisconsin
RRTRACK(at)AOL.COM <mailto:RRTRACK(at)AOL.COM>
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Sun Feb 04, 2007 6:56 am Post subject: Re: Vixen Information |
Mark -
I just came across your post and also have a very early Vixen (s/n 27). I learned from John McBean that the first 30 had a gross weight of only 1200 pounds. A clue is that the spar tube in front of the pilot's heads is 1" diameter.
As for sweeping the wings forward, it should keep you closer to the aft cg. Good for trim loads and cruise speed, limiting for how much weight can go in the cargo compartment, and watch the weight and balance as it makes it easier to exceed the aft limit.
Bob
_________________ Remember that internet advice may only be worth what you pay. |
Posted: Sun Feb 04, 2007 7:12 am Post subject: Vixen Information |
Hi BOB
Thanks for the reply. All the weight and balance scenarios is near the rear of the CG limits. I will keep close watch of the CG when loading the baggage compartment. My Vixen is disappointing on cruise speeds. It cruises at 80 Knots at 5000 RPM indicated. I think about 90 knots at 5500 RPM. The struts are faired and it has the fiberglass main landing gear and all the wheel pants on. John McBean suggested the tack may be off. I get about 5200 RPM static and it had 430# of static thrust.
What it does do well is land slow. It stalls at 35 MPH with full flaps and lands just under 40 MPH. Also the climb rate is around 1100 FPM with a 170# pilot and 10 gal of fuel. I have the 68" GSC three blade prop. How does this compare to your Vixen performance?
Mark
Wisconsin
Posted: Sun Feb 04, 2007 9:57 am Post subject: Vixen Information |
I would check your airspeed. Sounds like a static port problem giving
you slow speeds.
static thrust.
Mark
Wisconsin
Bob
Posted: Mon Feb 05, 2007 5:34 am Post subject: Re: Vixen Information |
Hi Mark (and others) -
I haven't really introduced myself to the group. I work in DC as an Aircraft Systems Engineer, although my position description says "Aero." I also try to keep my A&P active on the side. I haven't outright built anything since a glider in the late 1970s, but have bought and sold "clean-up" project planes. Tired of blowing 8+ gph of avgas in the last one, a 100 mph Beech Sport, I recently bought a time capsule of a hardly-started 1992 Vixen kit with quick-build wings. One of the few things that has been started on this kit is to convert the gear so it can be a taildragger, using a Grove spring. The structure is much like later models from the factory that can go nose or tailwheel. I've been searching the archives here and on the predecessor Yahoo group for what others have done and had problems with and really appreciate the history. I intend to finish the gear mod and expand the cargo compartment, but want to get it done and keep it light so otherwise plan few mods, probably powering with a 100-hp 912S or 120-hp 3300. I live close enough to DC that I'll need a transponder and comm radio. I enjoy reading of you guys who are actively flying and if you are close enough for a ride I'd love to pay the gas.
Bob
BTW to Mark. As I understand, you have an 80-hp engine and are doing close to 90 mph (80 kts). Others probably can tell better and checking the real speed with a GPS is a good idea, but on 80hp you're probably close to what the airplane should do, especially if the tires are unfaired.
av8rps(at)tznet.com Guest
Posted: Wed Feb 07, 2007 11:54 am Post subject: Vixen Information |
Mark,
I've noticed that the airspeed indicator for my Model IV is off by sometimes 10 - 15 mph (e.g; reading 85-90 when I'm really going 100 mph). Weird thing is that it is not consistent at all. I haven't played with it much to try and improve it, but I suspect it is because I have one static port located midway down the fuselage on the left side. One day I'll disconnect the static from the instrument and try it that way. It hasn't really bothered me much as I have my Gps in the middel of my panel giving me ground speeds, and that is rarely less than 100 mph. I'm totally happy with that as I'm flying my 912ul Model IV on amphib floats. Incidentally, my Kitfox is the fastest 2 seat light floatplane around this part of the country. It will go 118 mph (tested again and again) flat out wide open on floats. However the asi rarely reads much over a hundred. Drives some of the Rans guys nuts as before my Kitfox came along they were the light floatplanes to try and catch.
I'm willing to bet if you test your vixen further you will find you are flying faster than you think you are. Btw, I think the climb rate is about right, but the stall speed sounds slow to me...once again making me think your ASI is off like mine.
Paul Seehafer
Model IV - 912ul on Aerocet Amphibs
Wisconsin
ps - Here's a picture of my plane. Look at all the drag....floats, rigging, water rudder, bubble doors, no radiator scoop, etc., and it will easily go 100 mph even with the wheels down and locked and at gross weight. And I've flown next to enough other aircraft now to know the speeds my gps tests results are accurate (asi isn't). Your Vixen just has to be at least as fast (especially when you start comparing the two aircraft from a logical viewpoint).
Description: |
Filesize: |
226.53 KB |
Viewed: |
559 Time(s) |
rjdaugh
Posted: Wed Feb 07, 2007 7:36 pm Post subject: Vixen Information |
Paul,
What are the Black “bumps” on the top of your wing about on either side of the cockpit?
Randy – inquiring mind,,,,,
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
temco(at)telusplanet.net Guest
Posted: Wed Feb 07, 2007 8:49 pm Post subject: Vixen Information |
Randy
Those look like fairings around the gas filler caps.
Ted
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Randy Daughenbaugh
Sent: February 7, 2007 8:34 PM
Subject: RE: Re: Vixen Information
Paul,
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Thu Feb 08, 2007 4:18 am Post subject: Vixen Information |
I recently had a similar problem on my 2. I replaced the nylon tubing to my pitot tube and ASI with new stuff. When I went to fly, the ASI was all over the place. Apparently, as I was working on the plane, I was folding the wings back and forth for engine runs and working on it. I found that I rubbed a hole in the new tubing inside the wing, and it leaked. I replaced it again, and now its pretty much dead accurate.
I had a piece of plastic tubing for a pitot cover that was totally sealed. When I would slip it on the pitot tube after flying, the ASI would jump up to 35 or so, and hold there. Sometimes, when I would show up the next day, the weather/pressure change overnight would push the ASI up higher. Several people thought my ASI was broken, ‘cuz it would read speed tied down. As soon as I removed the cover, it would drop to zero.
Check your tubing from the pitot. You can check it by lightly blowing in the pitot tube to get a reading on the ASI, and then plug the tube with your finger. If you can get a good finger seal, the reading on the ASI will hold, and not fall off. I actually used a long piece of clear ¼ inch PVC hardware tubing on the pitot, sat in the cockpit, and plugged it with my tongue. Worked much better.
I heard that you can also disconnect the ASI side, and put a small balloon on the tubing, then blow up the balloon from the pitot tube. If the balloon holds pressure, your tubing is good.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Paul Seehafer
Sent: Wednesday, February 07, 2007 2:50 PM
Subject: Re: Re: Vixen Information
Mark,
Paul Seehafer
Wisconsin
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
eskflyer(at)lvcisp.com Guest
Posted: Thu Feb 08, 2007 5:17 am Post subject: Vixen Information |
Brad
You never ever want to blow into the pito with your mouth , You can over pressure the airspeed very quickly , use a fan and stand back away from pito and just blow towards the pito tube from several feet away from the opening . You never want to seal up the opening attached to the airspeed and leave it over night you can over pressure it also . it needs to breathe.
Again this is my opinion and only mine and no one paid me or forced me under duress to say any of this .
Fly safe fly low fly slow
John Perry
Posted: Thu Feb 08, 2007 5:37 am Post subject: Vixen Information |
Randy,
Those are custom fibreglass covers that cover my electronic fuel senders since the sender sits higher than the top surface of the wing. They are also hinged at the front so I can get at the potentiometers that calibrate the senders if needed. Fwiw it works pretty well for fuel levels, but I also use the sight tube as a secondary system for checking fuel level. I've attached two pics that show where they are located on the wing in relationship to the fuel caps.
Ironically, these covers do look like the fuel cap fairings others have used. I haven't installed fuel cap fairings yet, but it's in the works. I had a conversation once with an aerodynamic engineer about those gas cap fairings, and he indicated the reason you should have them is not so much because of the drag of the cap, but the disturbed airflow over that part of the wing is critical and is probably causing a loss of lift. That all made sense to me so it is on my list of projects to do yet.
Maybe my gas cap covers are what make my little float plane so much faster than most other LSA type float planes?? (chuckle)
Paul
Description: |
Filesize: |
138.44 KB |
Viewed: |
498 Time(s) |
Description: |
Filesize: |
463.8 KB |
Viewed: |
541 Time(s) |
dave
Posted: Thu Feb 08, 2007 5:39 am Post subject: Vixen Information |
John is right and on top of overspeeding it you will get moisture in it.
If you have the ASI out you will find 2 ports on the back of it one labeled P and on S
If you tap your finger on the P port the Needle on gauge just jump a bit .
I have a flapper on my pitot tube so it rare to get a blockage. If you have a spot readily assesable like on a windshield pillar where the line from pitot comes into the cockpit you can cut it and blow it out there and just puta piece of tygon over top of it again. Same thing goes for your line to Static port .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dave
Posted: Thu Feb 08, 2007 5:42 am Post subject: Vixen Information |
Paul ,
Very nice !! <<It will go 118 mph (tested again and again) flat out wide open on floats.>>
My 582 on the same amphibs is about 96 to 98 Wide open Throttle.
My ASI reads high and I have no static port outside. GPS only way to accurately give consistant speeds.
Dave
Posted: Thu Feb 08, 2007 6:18 am Post subject: Vixen Information |
Bradley,
Very good information. Thank you, thank you! I will definitely be testing
mine per your instructions. That all makes good sense to do.
What's funny is how my readings are not consistent. Here's a few pics that
show what I'm talking about. Check the GPS groundspeed vs the ASI. (HInt;
two of the photos were taken with 15-20 mph tailwinds - just for grins...and
fwiw on the return flight I had a gs of 93 mph avg with a little more
throttle required) With the exception of those two photos the winds were
for the most part calm.
Btw - Yeah, I know my EGT is not operational - bad connector that keeps
coming loose. And my panel labeling is still a work in progress
Paul
Description: |
Filesize: |
91.83 KB |
Viewed: |
547 Time(s) |
Description: |
Filesize: |
84.71 KB |
Viewed: |
559 Time(s) |
Description: |
Filesize: |
75.15 KB |
Viewed: |
547 Time(s) |
Description: |
Filesize: |
86.89 KB |
Viewed: |
451 Time(s) |
Description: |
Filesize: |
96.62 KB |
Viewed: |
481 Time(s) |
Posted: Thu Feb 08, 2007 6:37 am Post subject: Vixen Information |
Yeah, just wait until I get my 100 hp 912 on it!!
I think your numbers of 96-98 mph is a good number for a 582 powered plane on floats. Cubs are all of 75 mph on floats unless they have large engines. And they aren't even amphibs.
Haven't been doing any flying, too cold around here. How about you?
Paul
Float Flyr
Posted: Thu Feb 08, 2007 7:46 am Post subject: Vixen Information |
I'd try the balloon test but don't ask me to try to regulate a low enough pitot pressure with my warm damp breath on my expensive ASI.
Better still find a friend who has access to a Barfield tester.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Beemer
Posted: Thu Feb 08, 2007 8:25 am Post subject: Vixen Information |
The balloon test I got from the RV builders. Seems to be a good way to see if the lines are sealed up. Visual inspection of the tube isn’t good enough.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Thursday, February 08, 2007 10:44 AM
Noel [quote]
Middle Georgia |
Beemer
Posted: Thu Feb 08, 2007 8:27 am Post subject: Vixen Information |
My readings were not at all consistent either. It'd go from zero to 40, back
again, then to 60, etc. I knew what it was after a few minutes of looking at
it. The instrument was brand new.
Now, on a calm day, my ASI is matched perfectly to the GPS. I'm happy with
it.
Bradley
Middle Georgia |
