fitting needed
Paul Petty
PostPosted: Fri Feb 09, 2007 11:45 am    Post subject: fitting needed Reply with quote
Kolbers,
Does anyone have 1 extra 90 degree fitting with the adapter for the oil cooler for a 912rotax? I need just 1 of each and hate to buy the kit at 70 bucks from rotax. I will be happy to buy them and pay the shipping.
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Paul Petty
PostPosted: Fri Feb 09, 2007 3:35 pm    Post subject: Re: fitting needed Reply with quote
Never mind!
Travis tha man hooked me up! This brings up an interesting subject tho.... John H John W. and Mark G. all have the same set up. They all needed 3 90's to make the oil cooler work on the back of the fuselage. Rotax sends the engenis out with the straight fittings for the oil pump and cooler. The 90's are an option you have to buy at 70 bucks per 2. My question is who has bought 2 pairs and what did you do with the other 90? May could get together on this and pair up the extra fittings and make some gas money if you guys can find them...or at least help out a fellow builder. On another note travis sent me a few photos of the routing of a plane bryan built that used the straight fittings. And the Rotax hose.
I think he said it was MikeB not sure
I would like to see more photos of your oil hose routing and type hose used. Im going with areoquip FC-332
 Filesize:  77.27 KB
 Viewed:  439 Time(s)
 Filesize:  91.16 KB
 Viewed:  414 Time(s)
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
rap(at)isp.com
PostPosted: Sun Feb 11, 2007 5:55 am    Post subject: fitting needed Reply with quote
Paul: CPS has a 90 deg fitting for around 20$
