Deems Davis
Posted: Sat Feb 17, 2007 6:54 pm Post subject: "Experimental" Mark Inquiry |
I've seen that most builders have placed the "Experimental" on the
doors above the windows. I'm interested in seeing if anyone has had any
thoughts/plans/conversations/discussions about any other locations?
Above the doors on the cabin cover?
Aft Bulkhead? (how near is near?)
Center Console?
/FAR § 45.23 Display of marks;
(b) When marks that include only the Roman capital letter "N" and the
registration
number are displayed on limited or restricted category aircraft or
experimental or
provisionally certificated aircraft, the operator shall also display on
that aircraft *near each
entrance to the cabin or cockpit, *in letters not less than 2 inches nor
more than 6 inches
in height, the words "limited," "restricted," "experimental," or
"provisional airworthiness,"
as the case may be./
Appreciate any comments feedback
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/*
Posted: Sat Feb 17, 2007 7:07 pm Post subject: "Experimental" Mark Inquiry |
We have put them on the top of the rear baggage wall. The DARs have had no
problems with that whatsoever.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Deems Davis
Posted: Sat Feb 17, 2007 8:17 pm Post subject: "Experimental" Mark Inquiry |
THANKS Jesse! that' exactly the answer I was looking for!
Deems
Jesse Saint wrote:
flysrv10(at)gmail.com Guest
Posted: Sun Feb 18, 2007 3:45 am Post subject: "Experimental" Mark Inquiry |
Mine is on the baggage compartment's aft bulkhead. The DAR was
interested to see that it was visible to passengers boarding the plane.
On Feb 17, 2007, at 9:54 PM, Deems Davis wrote:
any thoughts/plans/conversations/discussions about any other
locations?
Center Console?
the registration
experimental or
display on that aircraft *near each
inches nor more than 6 inches
Deems Davis # 406
LloydDR(at)wernerco.com Guest
Posted: Sun Feb 18, 2007 8:05 am Post subject: "Experimental" Mark Inquiry |
Rick Gray has also put it on the upper Baggage wall. Abby can embroider
it there as well. I put mine on the doors like Tim.
Dan
