		aprazer
				 Posted: Tue Feb 20, 2007 12:47 pm    Post subject: 3300 Exhaust |
				Ladies and Gents,
 Looking for a solution as what to do with my cowling. I have approximately 1/4 inch between the fiberglass and the exhaust pipe. I have considered wrapping the exhaust pipe with the insulating wrap that Aircraft Spruce sells for $43 for 50' 2" roll or trimming the cowling, which could be unsightly.
 Any and all suggestions will be greatly appreciated.
 Mack
 601XL in final stages
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ The poh-oh-unemployed farm boy from Idaho |
		bryanmmartin
				 Posted: Tue Feb 20, 2007 1:07 pm    Post subject: 3300 Exhaust |
				I wrapped my exhaust system and haven't had any trouble with it in
 180 flight hours. That price is cheaper than J. C. Whitney's.
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
  _________________ --
Bryan Martin
do not archive. |
		japhillipsga(at)aol.com Guest
				 Posted: Tue Feb 20, 2007 1:41 pm    Post subject: 3300 Exhaust |
				Mack, exactly where is the pipe close to the cowl and how much pipe ? If it is at a bend and only a small portion is near it it may not be a problem. Also, inside the cowl a bunch of air is pulling though to the bottom exit real fast and my ground and flight tests of inside cowl tempts were very reasonable. Up on the firewall at the rectifier, with the air temperature on the ground of 100 degrees, at 3500 feet and 135 mph the max temperature was 123 degrees on my digital meter. On the ground after the flight during taxi it went down to 93 degrees which was 7 degrees cooler than the   outside temperature. Weird huh ? Even in hot Georgia summertime. Before doing any cowl cutting I would suggest you do more checking. The distance of 1/4 inch you speak of is about the distance I have on my bottom end where the pipes exit the cowl and I have seen no heat marks. Best regards, Bill of Georgia
				 Posted: Tue Feb 20, 2007 1:57 pm    Post subject: 3300 Exhaust |
				Hi Mack,
 You have two options, one of making an adaptive bump in your lower cowl
 which can look good.
 Or the cowl can be trimmed out and an extension of aluminum that will
 withstand the temps better.
 I've done both of these progressing from the first to the second option
 and also have wrapped my
 stainless exhaust with the belting.  It can be neatly done and not foul
 your sensitivities or prevent you
 from putting in EGT sensors.  See the following links from my cowl page
 and engine page.
 http://www.macsmachine.com/images/cowling/full/formnmold.gif
 http://www.macsmachine.com/images/cowling/full/matoverlay.gif
 http://www.macsmachine.com/images/cowling/full/lowercowl1.gif
 http://www.macsmachine.com/images/cowling/full/cowlfairingsinside.gif
 http://www.macsmachine.com/images/cowling/full/cowelfrtlower.gif
 http://www.macsmachine.com/images/subaruengine/full/exhaustwrapsilver.gif
 Neither of these are hard to do.
 Good luck,
 Larry McFarland 601HDS at www.macsmahine.com
 aprazer wrote:
  Ladies and Gents,
  Mack
		tonyplane(at)bellsouth.ne Guest
				 Posted: Tue Feb 20, 2007 2:15 pm    Post subject: 3300 Exhaust |
				 	  | Quote: | 	 		   	  | Quote: | 	 		  | Mack,I do not know what the clearance is on mine, but it is close.  I hope to be enjoying the sky tomorrow and will look; however, Ishould think that the temps near the end of the exhaust pipes would notbe too high with the 1/4 inch clearance to cause any heat distortion,especially considering the airflow in the area.  I would definitely not trim cowling lip, as that helps to create the low pressure for cowling airflowfor cooling the cylinders.Tony GrazianoXL/Jab3300A N493TG 209 hrs I do not know what the clearance is on mine, but it is close.   | 	  0 	  | Quote: | 	 		  | I do not know what the clearance is on mine, but it is close.   | 	  1 |
		n801bh(at)netzero.com Guest
				 Posted: Tue Feb 20, 2007 2:28 pm    Post subject: 3300 Exhaust |
				What part of Idaho are ya in??. if you are in the east side, I am in Jackson Hole and have extra ceramic header wrap that I use on my beast. Contact me off list if ya need a little to shield your cowling.
 Ben Haas
 N801BH
 www.haaspowerair.com
 -- "aprazer" <aprazer(at)cableone.net> wrote:
 --> Zenith-List message posted by: "aprazer" <aprazer(at)cableone.net>
 Ladies and Gents,
 Mack
 Read this topic online here:
 http://forums.matronics.com/viewtopic.php?p=96329#9632===============================================   [quote][b]
		Float Flyr
				 Posted: Tue Feb 20, 2007 4:57 pm    Post subject: 3300 Exhaust |
				Install the wrap and...put a reflective heat shield of heavy BBQ type foil
 inside the cowl.  Try it for a circuit and then check the temp on the cowl.
 Make sure there is no direct contact of the inside of the cowl with the hot
 exhaust pipe.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		aprazer
				 Posted: Wed Feb 21, 2007 1:51 pm    Post subject: Re: 3300 Exhaust |
				Thanks everyone -- you have been very helpful!
 Mack
