jchang10
Posted: Fri Feb 23, 2007 10:19 am Post subject: Rear spar alignment flaw and Warning |
Has anyone else dealt with this issue? I am on page 16-2 on the Top Wing Skins
section. My left wing lined up perfectly. On the right wing, to my surprise, I
have an alignment problem between the top wing skin and the rear spar.
Here are some photos to illustrate...
Every other hole lines up between the top wing skin and the wing skeleton,
except for the inboard rear spar holes. The holes are out of alignment and
gradually come closer into alignment until they are lined up perfectly again
between the 4th and 5th rib, counting the root rib as rib #1.
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4481.html
Broader picture of the general area...
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4482.html
The inboard most hole is the furthest out of line by about 1/16". The rear spar
hole needs to come further aft by 1/16".
I then did a lot of measuring to compare my left wing (perfect) with right wing
(problem). The problem appears to be with the rear spar. The upper flange seems
to taper from 22/32" wide down to 20/32" wide at the inboard edge, which would
account for the 1/16" alignment error in the top skin.
Photo of rear spar top flange on left (correct side):
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4483.html
Photo of rear spar top flange on right (error side):
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4484.html
I spoke with Van's this morning. They made 2 recommendations:
1. Does the bottom skin line up? Answer: surprisingly enough, YES. It's not
perfect, but will be manageable.
2. Drill and rivet the misaligned holes with 1/8" rivets.
The problem with this solution is that the new hole will have an edge-distance
problem. I should have 1/4" clearance to the edge, but I will only have 3/16"
clearance to the aft edge on the rear spar. As I work outboard, the edge
distance issue should get better and better, but still not within spec.
1/16" would not be a problem anywhere else on the wing, as far as I can tell. I
could have "massaged" things possibly by that amount. However, this problem is
at the wing root and wing walk area, which is heavily reinforced. There is no
"massaging" possible here.
Finally, I could get a new rear-spar, however, that means removing all of the
doublers and tons of AN470AD4-8 and 4-6 rivets!!!
Thus, the warning to other builders, BEFORE riveting the rear spar, measure the
top flange on your rear spar, to make sure it stays even in width. Even better,
try fitting the top skin on before riveting the rear spar.
Can anyone provide any other recommendations?
Another thought is, can I somehow put in a shim between the rear spar and the 2
inboard ribs? The shim would have to only be along the top holes, since the
bottom holes are lined up.
Jae
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Fri Feb 23, 2007 10:35 am Post subject: Re: Rear spar alignment flaw and Warning |
Jae,
I may be coming up on this point in about a month. What was the serial # of your wing spars and how long have you had them?
My builder # is 40674 but my spar # is 10578 which I think means that I have the 578th wing kit shipped.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
kdbelue(at)charter.net Guest
Posted: Fri Feb 23, 2007 10:55 am Post subject: Rear spar alignment flaw and Warning |
Jae,
I had the same problem (about 2 years ago). My rear spar flange was off more
than yours, though. Van's sent me another spar and I drilled out all the
rivets and replaced it. It looks like you can use yours - I would drill the
holes to match and use the "oops" rivets if necessary. It's a good idea for
everyone to check the dimensions on the rear spar before rivetting because
it is a big job to remove it.
Kevin Belue
RV-6A flying
RV-10 finish
jchang10
Posted: Fri Feb 23, 2007 12:35 pm Post subject: Rear spar alignment flaw and Warning |
Kevin... Well, I just hope we can help this from happening to anyone else. I
have already ordered a replacement left rear spar. Even the replacement was not
the SAME as my original. With these discrepancies, I think there are plenty of
quality control issues on the rear spars
At this point, I am leaning towards upsizing to 1/8" hole and rivets. However,
what can I do to deal with the edge-distance clearance issue? Does anyone have
any recommendations?
My thoughts are:
1. Just leave it alone. It's just 1/16" under the edge distance clearance for a
1/8" rivet.
2. Add some extra 3/32" holes and rivets in rear spar upper flange. The current
spacing between holes is 26/32". If I put another hole in between existing
holes, is that safe to do?
Thanks again for the suggestions,
Jae
jchang10
Posted: Fri Feb 23, 2007 2:51 pm Post subject: Rear spar alignment flaw and Warning |
Hi Gary,
The spar # is 10495. I received it in June 2006.
My builder # is 40533.
I would make sure to measure the upper flange width, to make sure it is
consistent along the entire length of the rear spar.
Jae
owl40188(at)yahoo.com Guest
Posted: Fri Feb 23, 2007 2:53 pm Post subject: Rear spar alignment flaw and Warning |
Hi Jay,
I think you will be fine going with 1/8 inch rivets.
You would have reduced your allowable bearing stress on the spar by about 30% due to the shorter edge distance but you will have gained about that much from the higher bearing area. By the way, 1.5D is not considered short edge distance. Many pieces of structure are designed to that edge distance. I am assuming you are measuring from the center of the hole to the edge of the part. Additionally depending on the thickness of the parts the spar might not be the weakest link.
The net area on the spar will be slightly reduced so the spar will be weaker by the difference in the area of the upper flanges which is pretty small. Also the upper spar is usually in compression which minimizes the effect.
I don't think its a problem but you might want to check with Vans anyway. Do make sure though that you get good holes and no "figure 8s"
Niko
40188
jchang10
Posted: Fri Feb 23, 2007 4:47 pm Post subject: Rear spar alignment flaw and Warning |
Niko... Vans is recommending using oops rivets, so i think that would
definitely mean a weaker structure than using the original callout. Part
of the reason, is because this is a tight access area, because of the
built-up doublers in the way.
Finally, Vans brought up another issue. The 1/16" missing from the upper
flange had to have gone somewhere. Yep, it went into the web of the spar.
There is now quite a gap created above the ribs.
This is the gap in the right (problem side) root rib. That is almost 1/8"
thick. 0.125". The top skin is .032". That means the shim I would have to
use to fill that gap will be 3 to 4 times the thickness of the top skin.
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4485.html
This is another inner rib, all the inner ribs have the same problem, up to
the 5th rib, which is fine.
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4486.html
As a comparison, this is what my left root rib looks like - what it should
be.
http://www.jline.com/log/aviation/build/wingkit/photos/IMG_4487.html
I am going to have to think about this over the weekend. Now, i am leaning
towards replacement.
Any opinions on what others would do?
That hissing sound i hear is the sound of building momentum leaking away
again!
Jae
[quote] Hi Jay,
effect.
Niko
40188
orchidman
Posted: Sat Feb 24, 2007 6:09 pm Post subject: Re: Rear spar alignment flaw and Warning |
| jchang10 wrote: | Hi Gary,
Jae
Jae,
I measured my spars which are still on the shelf. Measuring as you did in the pictures IMG 4483 & 4484, I found that all of mine were 22/32 for both the top and bottom flanges. I did find one area that might have been off by as much as 1/32 giving a measurement of almost 23/32.
My measurements were taken by placing a block on the back side of the WEB as you did with your yellow tool and then measuring the flange.
I also attached a couple ribs and they seemed to fit just right. Hopefully they have got their problems fixed.
RV10 - # 40674
(N2GB Flying) |
Posted: Mon Feb 26, 2007 6:56 am Post subject: Rear spar alignment flaw and Warning |
Hi Jae,
Sorry to see you are having such a problem with your rear spar.
After seeing your latest pictures I would replace the rear spar. Not that it couldn't be fixed but you are going to put a lot of time into fixing it with shims, you won't be totally happy with it and then you might still run into unforseen problems when you mount your ailerons and flaps because of the taller aft spar. You would be in effect changing the airfoil shape. One you start drilling out the rivets you might find its going fairly fast and you haven't lost all that much time.
Good luck with it.
Niko
40188
Deems Davis
Posted: Wed Mar 07, 2007 5:21 am Post subject: Rear spar alignment flaw and Warning |
Jae, sorry I was out for a while and just going back through mail that I
missed. I had a similar problem with one of the rear spars that was not
bent/formed correctly and resulted in a slight taper (3/32 - 1-16") in
the spar cap on one of the ends. It throws off a lot of other stuff,
Van's sent me a new one.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Jae Chang wrote:
be.
again!
ericparlow(at)hotmail.com Guest
Posted: Wed Mar 07, 2007 7:00 am Post subject: Rear spar alignment flaw and Warning |
Has anyone had the 430/530 WAAS conversion done and installed it?
We need to know if there were any modification needed to the plane's wiring
or antennas.
It's been suggested that RG-58 is not acceptable and the cable length is
critical. Also that the antenna needs to change.
ERic--
RV-10, 40014
N104EP
