CH701 Landing Lights
arno7452(at)bellsouth.net
PostPosted: Thu Feb 22, 2007 3:05 pm    Post subject: CH701 Landing Lights Reply with quote
Listers,
I am going to install a ldg light on my 701. The most obvious attachment location is the bracket connecting the landing gear bow. However, there are some lights available that might fit in the forward slat. Xevision has one measuring about 4"Wx4L"x2"H. Has anyone installed a light in their slats?
Thanks in advance,
Ken Arnold
Building CH701 QB Kit; target completion May 2007
lgold(at)quantum-associat
PostPosted: Thu Feb 22, 2007 7:25 pm    Post subject: CH701 Landing Lights Reply with quote
Ken,
I installed a landing light in a slat but don't know how effective it will be. Not hard to do, I cut out a elliptical hole, and curved some 1/8th inch thick lexon to the slat shape by heating it to 300F in my oven while it was sitting on the piece that I cut out. Then I found a small 55W 12V light in an auto shop and mounted it so that it could be adjusted after attaching the wing.
Tune in in about a half year when the plane is ready and I'll tell you how well it works.
Les
[quote] From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Ken Arnold
Sent: Thursday, February 22, 2007 3:03 PM
To: Zenith List
Subject: CH701 Landing Lights
Listers,
Thanks in advance,
Ken Arnold
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
rjscep(at)yahoo.com
PostPosted: Fri Feb 23, 2007 6:32 am    Post subject: CH701 Landing Lights Reply with quote
How about in the nose bowl?
--- Ken Arnold <arno7452(at)bellsouth.net> wrote:
Listers,
Thanks in advance,
Ken Arnold
Cheap talk?
dbortol
PostPosted: Fri Feb 23, 2007 7:08 am    Post subject: CH701 Landing Lights Reply with quote
There is a benefit to having the lights on the wing, or at least
somewhere where you can see the light during flight; if you encounter
icing conditions, the ice is much easier to see. You'll be able to see
a reflection from the ice on the adjacent surfaces.
Dino
> Listers,
> Thanks in advance,
> Ken Arnold
Cheap talk?
billmileski
PostPosted: Fri Feb 23, 2007 1:39 pm    Post subject: Re: CH701 Landing Lights Reply with quote
Mine is on the underside of the cowling behind the oil cooler opening. It is an enclosed 55W driving light, with a built-in lens, and a reasonably aerodynamic enclosure. I've used it, but with the standard Rotax alternator, at lower rpm (descent and landing) I can't have radio, transponder, intercom, instruments, nav lights, strobes, and landing light on without watching my battery discharge. And this is while keeping the (incandescent Nu-Lite) instrument lights off. At least with the Rotax the battery is not involved in the ignition circuit, but it would be a drag if my radio dropped out at my towered home airport, due to reduced battery voltage. I say all this in case you have a Rotax. To do over I'd consider LED lighting. By the way, a friend of mine has some 3W LEDs which are pretty amazingly bright, bright enough to make a landing light from in quantity. Might be fun to mess with. Not sure of their price. Food for thought.
Bill Mileski
Ledyard, CT
701/912S
craig(at)craigandjean.com
PostPosted: Fri Feb 23, 2007 1:58 pm    Post subject: CH701 Landing Lights Reply with quote
You can also drop the current consumption by using HID lamps. Expensive but
possibly cheaper than redesigning your charging circuit:
www.creativair.com
www.xevision.com
-- Craig
Tommy Walker
PostPosted: Fri Feb 23, 2007 6:27 pm    Post subject: Re: CH701 Landing Lights Reply with quote
Take a look at this: http://www.ch701.com/builders/Steve%20Johnston/Steve_Mods.htm
If I were going to install a landing light, I think I would do this....
Tommy Walker in Alabama
N8701 92.31416....% complete
[quote="arno7452(at)bellsouth.net"]Listers,
Thanks in advance,
Ken Arnold
Tommy Walker
N25A - Anniston, AL
Tommy Walker
PostPosted: Sat Feb 24, 2007 5:40 am    Post subject: CH701 Landing Lights Reply with quote
Check this out:
Tommy Walker
N25A - Anniston, AL
alex_001
PostPosted: Sun Feb 25, 2007 10:50 am    Post subject: Re: CH701 Landing Lights Reply with quote
i have installed 12v halogen bulbs from home on my 601 same could be done on 701
mounted them in a perspex housing total costs 3,--usd
 Filesize:  543.04 KB
 Viewed:  498 Time(s)
alex_001
PostPosted: Sun Feb 25, 2007 10:52 am    Post subject: Re: CH701 Landing Lights Reply with quote
pic 2
 Filesize:  648.62 KB
 Viewed:  486 Time(s)
