hrs1(at)frontiernet.net Guest
Posted: Fri Feb 23, 2007 7:47 am Post subject: Engines |
List . . . please be patient while I ask a bunch of probably dumb
questions re engines for my 701. I always thought I would use a Rotax
912 - 80 HP, but an awful lot of my buddies in my flying club are down
on Rotax due to the continual AD's (is that the right word?). I also
see a lot of service notices in the EAA mags. This sort of surprises me
since they have been around a long time, and one would think the bumps
would be smoothed out.
First dumb question - why do all of these engines for LSA and ultralites
operate at such a high RPM, i.e. in the 5,000 RPM range? I assume this
5,000 RPM range has some sort of gearbox. What are typical prop RPM's
at cruise?
If I'm not mistaken the engines which powered the Aeronca, Taylorcraft,
PIper Cub and the like were about 65 HP and were direct drive. Why
aren't such engines available for the 701, or are they? Wouldn't these
be much quieter (I"m big on quiet)? Those old classic birds just
seemed to putt putt along. My Piper Dakota of some years ago operated
in the 2,400 range.
Has anyone tried a 60HP HKS in a 701? I've heard nothing but good
things about the HKS's. Are cowlings and FWF packages available? I've
been impressed with the low 2 - 3 gph fuel consumption of these
engines. Would the 701 fly ok with 60 HP? It's my understanding that
the 701 was originally designed for something like 55 HP, but I may be
wrong about this.
Any other thought you might have will be appreciated. Thank you.
Robert Schoenberger 701 60%
Posted: Fri Feb 23, 2007 9:04 am Post subject: Engines |
Robert,
I share your concern with the Rotax engines. They are the most popular,
but I'd be reluctant to use one because of company attitude and
continuous "AD" notes. The latest requiring a waterless coolant didn't
resolve a problem, but does acknowledge one. I'd have preferred they
found a better fix. Most re-drives are nearly 2 to1, but 5000 rpm is
only a number at which the peak HP is developed and it doesn't create
more than the problem with having a re-drive in the first place. There
are smaller engines that would perform just as well on a 701 and the HKS
would, but for it’s light weight, is extremely reliable and well proven
on trikes. Don't think a FWF kit is available at this time. The trend of
putting the largest engine possible on these light Zeniths fails to
realize the value of a "light aircraft". I'd also consider VW or the GEO
aircraft conversions or Suzuki conversion engines. See link,
http://www.ultralightnews.com/sunfun2000/ravenredrivesnf.htm.
You might possibly find a Cont A-65 or a 75 hp Franklin that's
available. Good engines! Simple! Somewhat Rare, as are some parts!
Larry McFarland - 601HDS at www.macsmachine.com
Robert Schoenberger wrote:
<hrs1(at)frontiernet.net>
me since they have been around a long time, and one would think the
bumps would be smoothed out.
ultralites operate at such a high RPM, i.e. in the 5,000 RPM range? I
assume this 5,000 RPM range has some sort of gearbox. What are typical
prop RPM's at cruise?
Taylorcraft, PIper Cub and the like were about 65 HP and were direct
drive. Why aren't such engines available for the 701, or are they?
Wouldn't these be much quieter (I"m big on quiet)? Those old classic
birds just seemed to putt putt along. My Piper Dakota of some years
ago operated in the 2,400 range.
wrong about this.
zenith601xl(at)gmail.com Guest
Posted: Fri Feb 23, 2007 9:49 am Post subject: Engines |
The HKS is also geared and develops max power at around 6,000 rpm.
On 2/23/07, LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)> wrote: [quote]--> Zenith-List message posted by: LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
Robert,
would, but for it's light weight, is extremely reliable and well proven
| Quote: | --> Zenith-List message posted by: Robert Schoenberger
<hrs1(at)frontiernet.net (hrs1(at)frontiernet.net)>
cffd(at)pgrb.com Guest
Posted: Fri Feb 23, 2007 10:14 am Post subject: Engines |
My direct drive Jabiru 2200 works just fine.
Chuck D.
N701TX
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Fri Feb 23, 2007 11:34 am Post subject: Re: Engines |
Scroll down to the bottom page of http://www.zenvair.com/
If you decide you are interested in further research with the Corvair engine, look at www.flycorvair.com
- Patrick
billmileski
Posted: Fri Feb 23, 2007 12:45 pm Post subject: Re: Engines |
| Quote: | First dumb question - why do all of these engines for LSA and ultralites
at cruise?
in the 2,400 range. |
The small displacement is for high volumetric efficiency (hp per displacement). Make a small displacement engine breathe well at high rpm to maintain torque, and inherit increasing hp with rpm. Small displacement equals low weight and small footprint.
Regarding the fear of Rotax..
The service bulletin history reveals the most active closed-loop development process of all the engine manufacturers. Rotax addresses engine issues, maintenance procedures, storage issues, etc etc etc, down to the detail level (e.g. size of vent hole in coolant overflow bottle), because they have a huge number of engines, and a stable installation configuration. The "scary" bulletins are usually a proactive reaction to a small number of incidents. For example, there is a bulletin requiring mandatory inspection of cylinder bases for cracks. Lockwood Repair told me that this issue has only been seen by them (maybe the most experienced Rotax facility) in engines in towplanes seeing repeated, rapid heating and cooling (and I'm guessing all aircooled engines are at risk here too). A lot of the service bulletins are there to report upgrades (e.g. reporting new clamps to hold carb sockets in place that automatically keep the 8mm gap, to prevent overtightening by the end user, which was the cause of some carb self-removals).
The 912S has the lowest prop speeds (5000rpm/2.43=2057rpm) and matches the power-to-weight of any engine. Best floats or stol performance for 701.
Regarding fuel economy, I see 3.2-3.5gph at 4600rpm cruise (cruise pitch). The HKS is better here, and this is probably a tie with the Jabiru, but the Jabiru requires 100LL, causing a 50% fuel cost addition.
Fuel type: The 912S requires premium auto fuel. The HKS has a similar compression ratio (11.3:1) and will be no different. The Jabiru requires 100LL, and if you want to run 100LL this is a good choice -- the Rotax suffers reduced gearbox life if always using 100LL. There may be an issue with 10% ethanol in auto fuel and the Rotax, but I am expecting them to say it's okay.
The Rotax is the LSA standard, with maintenance facilities adopting methods to deal with them, at a greater pace than other engines. Cessna chose it for LSA proof-of-concept. Also stand in the sidelines of the ultralight area at SNF, listen to the announcer talk about the planes as they take off.. "..powered by the Rotax 912S.." repeated as if a broken record.
All Lycomings, Continentals, and Franklins, and Subarus, exceed the max engine weight limit listed on my 701 plans. Maybe the limit has been increased since I checked last, dunno.
Rotax powered airplanes are very likely installed in a standard firewall-forward package provided by a kit manufacturer, with standard results. Insurance companies are most familiar with Rotax (of the non-certified engines).
Rotax has a very stringent documentation practice in order to support a certified engine (installed on lots of certified aircraft, by the way), and we inherit some of the benefit in the uncertified engine. We get lots of detailed info on maintenance practices, operation in a variety of climates, etc. because of the wider variety of uses and conditions these omnipresent engines are exposed to.
Speaking of climates, the Rotax operates nicely with 200F/200F oil/water temps in my 701, whether it's 95F or -10F outside, as long as I tape over the coolers more as the temperature drops. I am wondering how the aircooled engines manage. And you only have to run Evans waterless coolant if you want to push water temps to 260F, otherwise 50/50 standard coolant is fine, and it actually provides better heat removal due to its higer heat capacity.
All the other engine manufacturers are dealing with their own design limitiations and review processes.. Jab with the cooling fin size changes and I think some valve train redesign, plus the current service bulletins on their web site..HKS with a total valve train redesign causing existing engines be replaced, the Subaru conversions with valve guide float and resultant growing pains.. I don't think you can assume their designs are happier just because their documentation is less feverish.
Manufacturer of conversions are even more likely to be playing catch-up with problems with their designs. They are small shops with limited resources, and each installation by their customers is likely very unique. The rate of customer feedback regarding issues is much slower because of the lower number of fielded engines. Meanwhile Rotax is acquiring vast resources in the huge number of sales of these expensive engines, and further increasing their data gathering rate, and pumping more money into design improvements.
I like the Jabiru, the installation is cleaner, the engine is beautiful, I just wanted the stol the plane could achieve with the higher efficiency of a longer prop at lower rpm, and the few extra hp of the 912S might provide a little extra too. The HKS is terrific, just forbids floats probably with only 60hp, and again stol suffers. Everything else was too heavy in my opinion for the 701.
I flew into an airport to meet a friend (fellow builder) and the first words out of his mouth were "gee, I didn't hear you at all until you taxied up", and he was standing outside as I overflew at cruise power. I have made and received cell phone calls in the cockpit at cruise without a headset adapter (can neither confirm nor deny I was PIC at the time). The noise is similar to a C152. Definitely not excessive.
In sum I would treat the active review process of the Rotax as a big advantage, it was one of the reasons I chose it. I would look a little closer at the service bulletins if you think you see a lot of "fear" issues there. And browse the NTSB database to get a feel for Rotax related failures before discounting what might be a very good overall choice for a 701. And none of the engines are perfect by any means.
Bill Mileski
Ledyard, CT
bryanmmartin
Posted: Fri Feb 23, 2007 12:48 pm Post subject: Engines |
By running an engine at a high RPM, you can get the same power out of
a much smaller and lighter engine, even though you lose some of the
weight advantage because of the need for a speed reduction unit. The
tradeoff is a bit more complexity and a few more moving parts. These
engines actually tend to be quieter than direct drive engines because
the higher frequencies produced fade out quicker over long distances
(the high pitched whine can be irritating up close though). In any
case, most of the noise produced by an airplane is from the propellor
not the engine. Speed reduction can be helpful here by allowing you
to run a large prop at a relatively low RPM.
range? I assume this 5,000 RPM range has some sort of gearbox.
What are typical prop RPM's at cruise?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
billmileski
Posted: Fri Feb 23, 2007 12:57 pm Post subject: Re: Engines |
| Quote: | All the other engine manufacturers are dealing with their own design limitiations and review processes.. Jab with the cooling fin size changes and I think some valve train redesign, plus the current service bulletins on their web site..HKS with a total valve train redesign causing existing engines be replaced, the Subaru conversions with valve guide float and resultant growing pains.. I don't think you can assume their designs are happier just because their documentation is less feverish.
Just to clarify -- the problems with the Jab and HKS referred to, are the old problems, not new ones. I meant to say "All the other engine manufacturers HAVE DEALT with their own design.." instead of "are dealing with". I don't want to imply that the Jab or HKS are undergoing major redesign, just that they did.
Sorry for any confusion.
Bill Mileski
Ledyard, CT
p.mulwitz(at)worldnet.att Guest
Posted: Fri Feb 23, 2007 12:57 pm Post subject: Engines |
Hi Robert,
I have been following the responses to your engine questions, and
noticed nobody seems to have answered your question about engine RPM
being so high.
There are two different kinds of engines used in airplanes: Ones
that were designed for aircraft use and ones designed for another
application that have been modified for aircraft use.
The big limiting factor in aircraft is the limit imposed by
propellers. A longer propeller generally works better than a shorter
one, but propeller RPM is limited by the propeller length. As RPM
increases, the speed of the propeller tip also increases according to
simple geometry. As the propeller tip approaches the speed of sound
it becomes inefficient, and if allowed to hit the speed of sound it
can be destroyed. So there is a trade off between RPM and propeller length.
Aircraft engines are designed to live with unusually low RPM limits
because of the propeller trade off. Engines designed for other
purposes tend to use much higher RPM that is limited by engine design
issues rather than propeller issues. To become more compatible with
propellers some sort of reduction gear or other reduction method is
used to make the final RPM compatible with propellers. Many use a
PSRU (Propeller Speed Reduction Unit?) while some others use belt and
pulley approaches. In other cases, the engine is used in direct
drive mode even though it is less efficient at the low RPM.
It is easy to tell that a Corvair or Subaru or VW engine is converted
from automobile use for airplane use. The Rotax is a little more
difficult to guess. This line of engines was originally designed to
operate snowmobiles and modified for aircraft use. It may well be
that more Rotax engines are currently sold for aviation than
snowmobile use, but that is their history.
Good luck with your engine hunt. We all go through this since
engines are a very significant part of the cost of a home built airplane.
Paul
XL Fuselage
At 07:41 AM 2/23/2007, you wrote:
Rotax 912 - 80 HP, but an awful lot of my buddies in my flying club
are down on Rotax due to the continual AD's (is that the right
word?). I also see a lot of service notices in the EAA mags. This
sort of surprises me since they have been around a long time, and
one would think the bumps would be smoothed out.
gearbox. What are typical prop RPM's at cruise?
they? Wouldn't these be much quieter (I"m big on quiet)? Those
old classic birds just seemed to putt putt along. My Piper Dakota
of some years ago operated in the 2,400 range.
available? I've been impressed with the low 2 - 3 gph fuel
consumption of these engines. Would the 701 fly ok with 60
HP? It's my understanding that the 701 was originally designed for
something like 55 HP, but I may be wrong about this.
N601RT
Joined: 25 Feb 2006 Posts: 31 Location: Hillsboro, Oregon
Posted: Fri Feb 23, 2007 10:27 pm Post subject: Re: Engines |
Robert,
Don't make your choice based on opinions from people that may not have real facts. Be careful to understand what are facts and what is rumor, possibly “fear of the unknown�.
We all make significant investments (time and/or money) in our engines and therefore tend to think we have made the best choice. I think this can color our opinions.
I agree the reason there are "lots of ADs" on Rotax 9xx engines is because there are LOTs of Rotax engines in service. I was told that there are more than 20,000 9xx engines in service a year ago. I just read that Rotax is currently producing 5,000 9xx family engines per year. (Both figures from Eric Tucker who teaches a GREAT Rotax maintenance class and who is THE technical guru for Kodiak [North America Rotax distributor]. Lockwood is an example of a dealer who gets their engines from Kodiak.)
All engines have their pluses and minuses. My perspective on Rotax +/-
Minuses:
Expensive (compared to Corvair and Subaru conversion, I believe similar price to Jabaru)
Parts are relative expensive
18a alternator (which I think this is relatively low output)
Positive:
Reliable
Light overall installed weight for the horsepower
Quiet
Water cooled heads. (Different than water cooled engine, simpler)
Mine basically does not use oil. I assume this is typical
Nicasil plated cylinders, close tolerance pistons
Shock cooling is not a concern
Broad dealer network. (But your local A&P may not be familiar with it.)
Large corporation stands behind and supports the engine
LOTs of engines in service. Many examples of these have gone to TBO more than once.
Optional 2nd alternator available. (Corvair and Subaru conversions have option for a variety of alternators. Jabaru has relatively low output alternator as does 9xx series.)
Service and installation manuals available on line for download.
Service Bulletins (ADs) available on line. These ARE NOT required for engines that are not certified. Recommend that you carefully understand what and why they are published.
My local EAA chapter has done some noise testing. Richard VanGrunsven, his brothers and lots of other RV owner's are in the chapter. My plane was the quietest tested during climb out at the end of the runway and tied for quietest with the factory RV-10 for 1000 foot over flight at 90kts. The tests also include “production� planes.
Paul's post to this thread has some misleading statements.
There is no need to guess the history of the Rotax 912, 914 engine series. The Rotax 912, 914 series of engines are clean sheet, modern design aircraft engines. Yes Bombardier (parent company Rotax) makes snowmobile engines, but the 9xx series IS NOT related to the snowmobile engines. Before Bombardier created the separate Recreational Products division, the company who owned Rotax also owned Learjet. Maybe the 9xx was derived from a Learjet.
Propeller tips that are supersonic lose efficiency. They can be destroyed, but there are many propellers that go supersonic regularly. Not saying this is recommended, just not a certain disaster.
Roy
N601RT: CH601HDS, nose gear, Rotax 912ULS, All electric, IFR equipped, 681hrs, 802 landings
btucke73(at)yahoo.com Guest
Posted: Sat Feb 24, 2007 9:05 am Post subject: Engines |
| Quote: | > As RPM increases, the speed of the propeller tip
also increases >>according to simple geometry.
True.
| Quote: | > As the propeller tip approaches the speed of sound
| Quote: | >it becomes inefficient,
True.
| Quote: | >and if allowed to hit the speed of sound it can be
destroyed.
I would love to see your reference on this one. The
Texan I fly on weekends has the tips go supersonic
just about every flight. I haven't done the math, and
don't care to, but you can hear the difference when it
takes off. When I take off, I pull back the prop as
soon as I get the gear up, and it purrs by. Most of
our pilots leave the prop up until at altitude. The
sound is a high pitched whine. The difference in RPM
is only 100 - 200. You can often hear the same thing
on Bonanzas and others if the prop is left up.
R/
Brandon
601 HDS / TD / Corvair
70 hours
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
naumuk(at)alltel.net Guest
Posted: Sat Feb 24, 2007 9:37 am Post subject: Engines |
Or physics, depending on how you look at it.
Bill Naumuk
HDS Fuselage
Townville, Pa
Posted: Sat Feb 24, 2007 11:22 am Post subject: Engines |
Hi Brandon,
No, I don't have a specific reference on the supersonic prop tips. I
wonder if your Texan tips are actually going supersonic or if they
are just transonic. Do you get a sonic boom?
There is a nice prop tip speed calculator on the Culver prop web
site. You can plug in the RPM and prop diameter to get an estimate
of the mach number for the tips. Of course, mach number varies a
great deal with air conditions, but it still might be interesting to see.
I am amused by the responses I am getting to a post I didn't think
would be at all controversial. I was merely trying to help Robert
understand the answer to his question of why some engines run at such
high RPM. Your question about tips going over mach 1 was also
mentioned by Roy while he strongly defended the ancestry of the Rotax
engine design. I guess I am just an irritating guy . . .
Paul
At 09:00 AM 2/24/2007, you wrote:
True.
True.
destroyed.
R/
Brandon
70 hours
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
n801bh(at)netzero.com Guest
Posted: Sat Feb 24, 2007 4:56 pm Post subject: Engines |
destroyed.
R/
Brandon
70 hours
I have had my prop at 1.2 mach. In fact it gets over mach everytime I fly. 76" three blade inflight adjustable Ivo. 160+ hours and the tips look as good as the day I installed them.
Ben Haas
N801BH
www.haaspowerair.com
-- Brandon Tucker <btucke73(at)yahoo.com> wrote:
--> Zenith-List message posted by: Brandon Tucker <btucke73(at)yahoo.com>
True.
True.
destroyed.
R/
Brandon
70 hours
Float Flyr
Posted: Sat Feb 24, 2007 6:15 pm Post subject: Engines |
I'm only going to tackle one question you asked.
About the high RPM of the newer engines. Horsepower is a factor of many
things a few of which are the displacement of the engine and the number of
power pulses per minute. Increase the number of power pulses and you
increase the horsepower. Of course there is a level of diminishing returns
on this or we would all be driving cars with thimble size engines turning 5
million RPM. And producing 500 hp.. Older engines were designed for the
props they would be turning. Those props were most efficient below 3000 RPM
so the engines were designed to have a max RPM of below 3000. They
increased their power by adding cubic inches. Basically bigger cylinders
and more cylinders. Quite a few of the radial engines had planetary
reduction gearing in the nose that allowed than to max out at around 5000.
A few things to consider are the improvements in engineering and materials
in the last seventy years. Newer bearings, cylinder walls and better
cooling methods allow much higher revving engines.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
badbob
Joined: 07 Jan 2007 Posts: 8 Location: Willamina, Oregon
bryanmmartin
Posted: Sun Feb 25, 2007 6:53 am Post subject: Engines |
Those numbers will come down a bit when you take into account the
forward speed of the airplane. But still, that would be one noisy
airplane. Ben's neighbors must really love him.
On Feb 25, 2007, at 6:24 PM, BadBob wrote:
> On Feb 25, 2007, at 12:53 AM, n801bh(at)netzero.com wrote:
> ¨I have had my prop at 1.2 mach. In fact it gets over mach
> everytime I
> fl
> tips look
> as good as the day I installed them.¨
> do not archive
WOW!!! At 70 degrees F that is 3400rpm for Mach 1.0 and at Mach 1.2
that
is around 4100rpm! I am surprised that the prop can take that!
Bob from Oregon.
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
Posted: Sun Feb 25, 2007 7:02 am Post subject: Engines |
I should clarify that the 1.2 number was from my 84" blades at -31 f here in Jackson Hole. Take 4700 motor rpm , redrive ratio of 1.43-1 = 3216.78, Whats that mach number ?? I haven't seen 70 degrees since last oct.. <G>
Ben Haas
N801BH
-- BadBob <badbob0007(at)earthlink.net> wrote:
--> Zenith-List message posted by: BadBob <badbob0007(at)earthlink.net>
¨I have had my prop at 1.2 mach. In fact it gets over mach everytime I
fl
Ben Haas
N801BH
WOW!!! At 70 degrees F that is 3400rpm for Mach 1.0 and at Mach 1.2 that
is around 4100rpm! I am surprised that the prop can take ================================================sp; - The Zenith-List Email Fp;List utilities such as the Subscriptions ================================================ - NEW MATRONICS WEB&n======================================================== [quote][b]
Posted: Sun Feb 25, 2007 7:19 am Post subject: Engines |
Thats why I don't run the 84" blades anymore at those speeds. Close neighbors to the airport are mostly motorheads so the engine itself is music to them. The real issue is JAC is the only airport located in a National park and us locals do try to keep the racket down to a mininum.
Ben Haas
N801BH
-- Bryan Martin <bryanmmartin(at)comcast.net> wrote:
--> Zenith-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net>
> everytime I
> fl
> tips look
> do not archive
that
Bob from Oregon.
Bryan Martin
N61BM, CH 601 XL,
do not archive.
<======================== - The Zeatronics List Features Navigator to browse
_-= the many List utilities such as sp; --> http://www.matronics.com/Navigator?Zenith-Lis========================sp; - NEat content now also available via the ========================================= [quote][b]
Posted: Sun Feb 25, 2007 7:46 am Post subject: Engines |
My bad,,,, the real speed is 106%,
let the flame wars begin........
Ben Haas
N801BH
Ben Haas
N801BH
fl
Ben Haas
N801BH
is around 4100rpm! I am surprised that the prop can take ================================================sp; - The Zenith-List Email Fp;List utilities such as the Subscriptions ================================================ - NEW MATRONICS WEB&n========================================================[quote]
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
