Russ Kinne
Posted: Sun Feb 25, 2007 6:55 am Post subject: Hello from a brand new Kolber... |
Boatner
Any plastics-supply house will have drill bits specially made for
drilling plastics successfully. Really big hardware stores too. Maybe
Home depot?
They work great!
Where are you located?
Good luck, Russ
On Feb 24, 2007, at 10:09 PM, rbhowell wrote:
Rick,
I have a die grinder... is that what you are talking about using to
cut Lexan? This will be the first time I've ever handled Lexan. I
also have a Dremel.
Are you saying to slightly grind the sharp point of a drill bit to
drill holes for attachment? Any advice you have to help me keep
from buying several sheets is appreciated!!!!
Boatner
http://forums.matronics.com/viewtopic.php?p=97151#97151
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Sun Feb 25, 2007 3:34 pm Post subject: Re: Hello from a brand new Kolber... |
Mr. Hauk is correct. Lexan (polycarbonate) can be drilled with normal drill bits. It is Plexi-glass (acrylic) that is prone to cracking and splitting around the holes during the drilling process. You can cut Lexan with a saw as well. The thin stuff used for winshields can also be cut with a good pair of aviation snips. Make sure to de-burr all holes and clean up all cut edges with a file or a sanding block. It is a good idea to drill holes oversize to account for thermal expansion. This is more important when riveting to steel than to aluminum.
Enjoy your new Kolb!
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
FLYMICHIGAN(at)comcast.ne Guest
Posted: Sun Feb 25, 2007 5:45 pm Post subject: Hello from a brand new Kolber... |
I know it doesn't sound very manly, but I used a good pair of regular houshold sissors to cut 1/16" lexan with great results.
Bryan Dever
cstonex(at)msn.com Guest
Posted: Sun Feb 25, 2007 6:54 pm Post subject: Hello from a brand new Kolber... |
Bryan ...what is unmanly about that?? I thought you were going to say you
went flyin' in your mothers underware or sumptin like that. Scared me!
Chuck
Bryan Dever
Don’t miss your chance to WIN 10 hours of private jet travel from Microsoft®
Russ Kinne
Posted: Mon Feb 26, 2007 8:15 am Post subject: Hello from a brand new Kolber... |
Takes a manly set of muscles to use kitchen scissors!
On Feb 25, 2007, at 8:41 PM, FLYMICHIGAN(at)comcast.net wrote:
Bryan Dever
