		gfmjr_20(at)HOTMAIL.COM Guest
				 Posted: Thu Feb 22, 2007 5:40 pm    Post subject: sealing fuel senders |
				John-
   I had leaks in both tanks until I sealed them with gasket sealer.  I would
 add some to the existing gaslet.
 George May
 601xL 912s
  	  | Quote: | 	 		  From: john butterfield <jdbutterfield(at)yahoo.com>
 Reply-To: zenith-list(at)matronics.com
 To: Zenith-List Digest Server <zenith-list-digest(at)matronics.com>
 Subject: sealing fuel senders
 Date: Thu, 22 Feb 2007 15:09:53 -0800 (PST)
 hi list
 is the rubber gasket enough to seal the fuel sender
 housing, or should i put some sealer on the gasket.
 john butterfield
 601XL, corvair
 torrance, ca
 Refi Now: Rates near 39yr lows!  $430,000 Mortgage for $1,399/mo - Calculate
 new payment
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		japhillipsga(at)aol.com Guest
				 Posted: Fri Feb 23, 2007 11:52 am    Post subject: sealing fuel senders |
				John, I used some red Permatex stuff that I have worried about ever since. I am building my RV-8 tanks right now and would recommend ProSeal for sealing in the sender unit. You can buy a pint and that should be more than enough for both tanks and they should not leak. Best regards, Bill of Georgia
		pacificpainting(at)comcas Guest
				 Posted: Fri Feb 23, 2007 1:00 pm    Post subject: sealing fuel senders |
				I cut a sender hole in the wrong place in one tank, so I  made a larger round metal patch, imbedded it in ProSeal I got from Van's and let  it set. It held pressure for several days until I let the air out. I don't think  it is called ProSeal anymore. The can says Flamemaster, but everyone still calls  it ProSeal.I also built 2 RV9A tanks with it. Good Stuff.
  [quote]   ---
		steveadams
				 Posted: Mon Feb 26, 2007 4:32 am    Post subject: Re: sealing fuel senders |
				I would be hesitant to seal the senders in with proseal. I have had to replace a sender and it was relatively simple, however if it is stuck on there with proseal you'll have quite a job getting it off and cleaned up. I used the rubber gaskets with seal lube and they have been leak free for 350 hours.
		planes_by_ken(at)bellsout Guest
				 Posted: Tue Feb 27, 2007 8:21 am    Post subject: sealing fuel senders |
				There are various grades of sealant.  One kind is designed for removable
 access panels.  Once removed however, the old sealant needs to be
 removed and new applied.  It is pink.  The gray sealant becomes one with
 the universe.  On Cessnas and Pipers with rubber sender gaskets, they
 needed to be installed dry.  If Fuelube is used the rubber gasket will
 extrude.  It is the compression that provides the seal.  Cork gaskets do
 not extrude as much.  See
 http://www.ppg.com/prc-desoto/main.asp?img=seal&menuID=3
 Ken Lilja
 steveadams wrote:
  http://forums.matronics.com/viewtopic.php?p=97370#97370
