Re. mono gear collapse
jonsmitheuropa(at)tiscali
PostPosted: Wed Feb 28, 2007 12:53 am    Post subject: Re. mono gear collapse Reply with quote
Hi all, having been following this discussion here's my random thoughts!
ASSUMING THE MECHANISM IS CONSTRUCTED AND ADJUSTED CORRECTLY then with the gear down and locked the over centre lock cannot possibly "unlock" itself (ie travel back undercentre) UNLESS SOMETHING BREAKS OR BENDS. An overcentre lock is exactly that - a lock.
With the gear down the LG8 arms will be tight against the stops and will be held there in place by the retraction lever which will be tight against the FORWARD face of the DOWN gate. (That's important - any gap here and the lever could travel forward a small amount in the gate thus moving the LG8's back off the stops slightly and critically REMOVING the overcentre).
With the LG8's correctly locked against the stops as above, then the overcentre lock cannot possibly "collapse" undercentre. It doesn't need much overcentre. Even a tiny amount will be enough to create a "safe" lock. As long as there is "some overcentre" present it will stay overcentre.
However, studying the diagrams again I then started to worry - and the following is pure speculation! If due to a very unfortunate series of oscillations (bounces!) in conjunction with undulationg ground, could a freak occurance happen such that the rubber block compresses so much that the swinging arm would then be "fired" downwards again with such force that (as the shock absorber became extended again) the arm would continue down with such force that it pulled on the LG8 arms enough to actually pull them back a little off their stops? (Of course, something would have to bend or break - probably the retraction lever - for this LG8 movement to happen). It wouldn't need something to bend much, just enough for the LG8's to move back to a small undercentre geometry. The next ground contact would then finish the job. (One thing is sure, if there is any "undercenter" present for any reason then nothing will hold the plane up - the gear will collapse immediately). Sadly, any "evidence" of damage caused by the first event would be completely lost by the continuing damage caused during the subsequent gear collapse.
Could this scenario happen? I don't know but I feel it is most unlikely. It needs someone with much more engineering knowledge (and knowledge of energy stored in rubber blocks!) than myself to speculate, but I feel that compared to the whole gear assembly the rubber block is tiny and the swinging arm will have a lot of inertia. (The wheel at the end is very heavy though.) Also the angles involved, even with correct overcentre geometry are very small. Any "pull" downwards from the shock absorber will be almost straight down and not much in the direction required to pull the LG8's off their stops! Ironically, too much overcentre could make this scenario worse?? - the angle will then be increased and any pull downwards by the shock absorber will have a greater pull on the LG8's in a rearward direction thus straining the retraction lever. (Zero overcentre and the pull would be straight downwards so no risk - but no safety margin either!). During development one presumes that Ivan, Andy or Nev will have swung and bounced up and down at great length to prove this can't happen!
A while ago in the UK the PFA issued a document detailing mandatory undercarriage inspections at each annual which includes a check of the geometry amongst other things. Compliance with this should be good for peace of mind! If owners from outside the UK don't have this then it may be worth getting a copy as it's good reading.
I love my monowheel and it's flying characteristics and think it's a great design! I will continue with the (completely unproven) thought that in the small number of uncommanded retraction occurances that have happened (with the greatest respect and sympathy to the owners) something must have been wrong somewhere. However I will be checking my geometry carefully and will be trying not to bounce too much!!
Jon Smith
G-TERN
davidjoyce(at)doctors.org
PostPosted: Wed Feb 28, 2007 1:47 am    Post subject: Re. mono gear collapse Reply with quote
Jon, I think you are on the right lines here. Although a lock is a lock it
is clearly capable of being unlocked! If the plane takes off abruptly
having gone over a significant bump the unloading of compression will
encourage the swinging arm to continue downwards, putting tension on the
overcentre elements thus tending to bring them back into a straight line and
indeed travel on into an 'undercentre' unlocked position if the movement is
violent enough, and if the gear lever set up is loose enough.
From this point of view it might be argued that being further over
centre in the downlocked position might increase the hazard as more momentum
(of the overcentre locking elements) will be developed when the swinging arm
unloads downwards, increasing the likelihood of forcing itself undercentre.
If it starts significantly overcentre it effectively (like a good back row
forward) takes a run at it and gets up a fine head of steam by the time it
reaches the neutral centre position, and is inclined to carry on taking
anything in its path with it!
The fragility of the joint between the gear selector lever and the
rest of the system was brought home to me when I found after flying through
some fairly severe turbulence in rotor, that the gear lever stopped 1/4
inch short of the detent on putting the gear down. The inertial effects on
the swinging arm and wheel had been enough to shift the alignment of the
joint where the gear lever joins LG08S with three bolts. Others of course
have reported similar things after trailing the plane with the gear locked
in an up position.
My conclusions are:
(1) that the system is best set up being only just overcentre
(2) that the Gear lever/ LG08S joint has to be as solid as possible, ie
holes precisely to size and faces bonded, and the reinforcing mod added)
(3) that the detents for the gear lever should allow no significant
movement
Regards, David Joyce, G-XSDJ
william(at)wrmills.plus.c
PostPosted: Wed Feb 28, 2007 8:15 am    Post subject: Re. mono gear collapse Reply with quote
To all flying monos,
Has anyone decided to renew the U/C shock cord as a timed maintenance issue?
Mine is 10 years old and 1,000 plus hours, flying off rought grass strips,
but still seems to function well, albeit probably a little tired by now.
(like me!) Someone has suggested that if the shock cord is not sufficiently
tight, it may contribute towards a gear collapse. If that were the case, it
would be nice to know what others think and what maintenance they have done,
or intending to do, to the U/C mechanism over the years. All I have done so
far, is to replace the two bronze bushes, when they appeared to be a bit
sloppy at approx 600 hours, but I am not sure if that was absolutely
necessary.
William
rparigor(at)suffolk.lib.n
PostPosted: Wed Feb 28, 2007 9:33 am    Post subject: Re. mono gear collapse Reply with quote
Hello Jon
I read your post, and:
"the following is pure speculation!" I am not sure that will really
happen.
As far as my speculation, I believe that a rammed and jammed LG08 against
its stop that is 1/16" to 1/8" overcentre can be brought undercentre!
How???
Lets say you hit a ski jump on take off, the plane will get light, and
lets say it is not ready to fly, then when it comes back down, one wing is
slight low (matters not which one), then a outrigger latch decides to be
defeated at that very moment. Can the rearward force on the outrigger, be
applied to the flap, which will be applied to the cross tube, then the
connecting rod and ultimate to the starboard LG08 forcing it
undercentre???
My wings are not rigged yet, can someone next time when doing a gear swing
test, defeat a outrigger latch and push aft on gear leg and have a look at
starboard LG08 to see if it can be lifted off its stop?
Thx.
Ron Parigoris
PostPosted: Wed Feb 28, 2007 10:15 pm    Post subject: Re. mono gear collapse Reply with quote
Ron,
I know of at least two monos that have ground away the front of the
outrigger spat right through to the front face of the wheel fork tube and
removed the head of the retaining bolt. This happens during a ground loop
owing to strong crosswinds on a hard runway. The leg is bent horizontal
when this happens, but it does not cause it to collapse. The U/C will also
withstand an A/C drop after hitting a bump on landing below flying speed,
sufficient to break the prop, but the U/C does not collapse. Hope this give
mono builders confidence, that if the over-centre is correct, the system
should not collapse owing to heavy treatment.
William
gcrowder2
PostPosted: Wed Feb 28, 2007 10:59 pm    Post subject: Re. mono gear collapse Reply with quote
I sure bounced the hell out of some early landings with my mono till I
figured
it out (just get the tail down first - duh!) to the point I thought I was
going
to prop strike but no u/c collapse. I have the mod to stiffen the u/c lever
but
still have not installed it. The lever is still very tight with no play
after 400 hrs.
My flaps can be left in any position in slow flight and they will not move
up
or down. I only fly off of pavement tho. I plan to tighten the u/c bungee
this spring as raising the gear that last inch into the detent can be
difficult.
Glenn
[quote]From: "William Mills" <william(at)wrmills.plus.com>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: Re: Re. mono gear collapse
Date: Thu, 1 Mar 2007 06:13:45 -0000
Ron,
give mono builders confidence, that if the over-centre is correct, the
system should not collapse owing to heavy treatment.
William
grahamsingleton(at)btinte
PostPosted: Sat Mar 03, 2007 2:50 am    Post subject: Re. mono gear collapse Reply with quote
David
My conclusions are the same.
The snap effect on the overcentre is dependant on the amount of
overcentre, IOW if there is no overcentre there will be no tendency for
it to flick undercentre when the load comes off the gear, the more the
O'centre the more the tendancy to flick under.
I think the strut reinforcement is almost essential too, it reduces the
flexibility of the locking mechanism.
Graham
David Joyce wrote:
My conclusions are:
movement
Graham Singleton
Tel: +441629820187
Mob: +447739582005
hurstkr(at)redzone.com.au
PostPosted: Mon Mar 05, 2007 3:16 am    Post subject: Re. mono gear collapse Reply with quote
Fellow Europaphiles (Mono believers only)
I think I made the list aware of this some time back but just in case I didn't . . .
Take a look at the attached photos which are self explanatory and note the packing which was necessary on one of the stops.
Of three undercarriage frames I have checked, all have had this problem. I therefore suspect that YOURS might be like it too.
IOW, one stop is shorter than the other and when the LG08's are pinned to the shaft, although they both touch their respective stops at the same time, they (the LG08's) are not in the same plane. One is more over-centre than the other. I'll leave it as an exercise to work out what this could cause!
Cheers
Kingsley in Oz
 Filesize:  91.28 KB
 Viewed:  219 Time(s)
 Filesize:  81.83 KB
 Viewed:  228 Time(s)
jodel(at)nildram.co.uk
PostPosted: Mon Mar 05, 2007 9:30 am    Post subject: Re. mono gear collapse Reply with quote
Kingsley,
In those photos the mount is resting on the engine mounting points. These are offset toward the starboard side of the aircraft. I suspect that the “error” that you found is supposed to be there.
Simon
G-BZTN
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Kingsley Hurst
Sent: 05 March 2007 11:13
Subject: Re. mono gear collapse
Cheers
Kingsley in Oz
PostPosted: Mon Mar 05, 2007 4:51 pm    Post subject: Re. mono gear collapse Reply with quote
Simon,
You must compare BOTH photos. The frame was in the same position on the bench when both were taken.
The frame was resting on the engine mounts but the purpose of photos was to show the relationship between the stops and the housing for the shaft that ties the LG08 's. A line drawn between the two stops was not parallel to the axis of the shaft. Believe me, the stops were NOT correct.
Anyway, my frame is a Classic one and as such does not have offset engine mounts AFAIK.
Kingsley
PostPosted: Tue Mar 06, 2007 10:34 am    Post subject: Re. mono gear collapse Reply with quote
Sorry! I see what you are getting at now.
Simon
Sent: 06 March 2007 00:54
Subject: RE: Re. mono gear collapse
Simon,
Kingsley
raimo.toivio(at)rwm-syste
PostPosted: Tue Mar 06, 2007 12:06 pm    Post subject: Re. mono gear collapse Reply with quote
All,
Is there any mono flying with fixed main gear
but adjustable /moveable flaps /outriggers?
If so, what is the penalty (speed, handling)?
Just a thought. Personally I will definetely not try it.
Retractable main gear was one of my main
reason to build Europa MW - I like it.
Geometrical lock is safe - if it is there and w/o play.
Regards, Raimo
Raimo M W Toivio
37500 Lempaala
Finland
tel +358 3 3753 777
fax +358 3 3753 100
gsm + 358 40 590 1450
OH-CVK
OH-BLL
OH-XRT #417
karelvranken(at)hotmail.c
PostPosted: Tue Mar 06, 2007 3:43 pm    Post subject: Re. mono gear collapse Reply with quote
Hi Kingsley and all,
I made the same measurements as you did with the same results.
In my logbook I entered the "optional" mod 51 strut application on februari 2001 two years after publication. But I did it my way.
Page two of the mod begins: The strut will not be absolutely straight but its sideways flexibility will allow this. I thought not to allow any flexibility at all. Neither the bending of the lower part of the landing gear lever could ever receive my green to go. Last but not least the moment arm to tranfer the moving forces to the three AN4 bolts seemed to me to long even with the proposed strut. The mecanism has also to work when the supporting bungee eventualy fails; and then friction forces are great.
In attachment a raw outline of my strut mod. Of the same alloy I made it in one flat plane. The problems that further occured were easily solved. a) The shaft moved 1,5 cm outwards to accept the lever without bending. In the cockpit module this was a problem for the incurved swell for big thighs. But since I never had them big, at my age I could easily make the choice and modified the cockpit module, not yet installed. By eliminating the curve I had a beautifull flat surface as well horizontal as vertical and believe me certainly as strong as it was before, because the way it was made was for people who never will look how it was done.
b) I remarked by visiting other builders and Cranfield and Kemble that for those building like the book; the handle to operate the lever was only at the left side (sorry trikers, whe are mono's). In my mod I have sufficient space left to operate the landing gear lever in the same vertical plane without forcing a torsion on the lever and without amputating my little finger.
c) At the lowest end I changed the pivot pin by one 4 mm longer without problem.
d) Finally I was lucky to notice that by fixing the three bolts, the lever gave a light pressure inside to facilitate the locking in the gates of the guide plate.
By trial and error I made the stuts equal to stop the overcenter and avoided hammersledge from metal to metal. I remeber that I was laying under my beauty pushing up and down the gear many, many times. Believe me there was no sexual meaning at all but I got a real satisfaction when I knew it would perform when I would be the pilot. Meanwhile I have only 25 hours self done from the beginning ( I am flying since 1959) and now waiting for the mod 72 and inspection at the same time.
Kingsley, I much appreciate your observations,and forgive me if I did violence to your beautiful language, I am Flemish.
  Since my pics for the modified cockpit module are not available at the moment, I will send them when I am able to do, you will receive them later on your personal e-mail adres.
  Greatings to down under,
Karel Vranken, # 447 F-PKRL
[quote] [quote]
 Filesize:  395.82 KB
 Viewed:  268 Time(s)
PostPosted: Tue Mar 06, 2007 4:04 pm    Post subject: Re. mono gear collapse Reply with quote
Dear raimo,
Don't think you are the first of thinking that it would be better. You know that for the trikes there is an operational mode for flap setting. But we as mono's, we need our outriggers, so we can't separate the setting for half or full or less. But remember we made perhaps the choice to be faster.
I really think the best Europa flyers are the mono's. The trikes are apron exhibition and not without success.
Best regards,
Karel Vranken #447 F-PKRL
[quote] From: Raimo Toivio (raimo.toivio(at)rwm-systems.fi)
Sent: Tuesday, March 06, 2007 9:05 PM
All,
Regards, Raimo
Raimo M W Toivio
37500 Lempaala
Finland
tel +358 3 3753 777
fax +358 3 3753 100
OH-CVK
OH-BLL
OH-XRT #417
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Mijn Postvak In wordt beschermd door SPAMfighter0 spam-mails zijn er tot op heden geblokkeerd.Download de gratis SPAMfighter vandaag nog!
raimo.toivio(at)rwm.fi
PostPosted: Wed Mar 07, 2007 3:02 am    Post subject: Re. mono gear collapse Reply with quote
Dear Karel,
You can be sure I do understand we need
outriggers (and full flaps) when on the ground!
I meant the moment before landing,
it could be possible to have graduated
flaps. Let is say 10 degrees during downwind,
20 degrees during basic and finally all 27 degrees
when landing...that was my point.
I do like my Cessna´s adjustable flaps.
Raimo
