wowens(at)darientel.net Guest
Posted: Thu Feb 22, 2007 3:13 pm Post subject: Instrument panel |
I just clecoed the instrument panel and front cover on my tip up canopy
fuselage. It appears that the brace to the instrument panel centers the
ideal location for an attitude indicator. Does everyone just put up with
offset instruments?
Also the radios in my current plane are about 11 inches long including the
harness (SL 30 and SL 60). The space ahead of the instrument panel and the
bulkhead is only about 9 inches. Do you have to hack holes in the
bulkhead.
Do Vans designers have broken necks? Do they use very short radios?
Wayne Owens
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
yenduc(at)sbcglobal.net Guest
Posted: Thu Feb 22, 2007 3:50 pm Post subject: Instrument panel |
Wayne:
My answer to your questions would be no and yes. I had to move the
braces about 5 inches to the right on the right side and about 4
inches left on the left side.
I had to cut a hole in the bulk head to accommodate the radio stack
and the glove compartment. I then supported and braced the weakened
areas with angle aluminum.
I also used the larger panel which was an inch or so deeper and made
of thicker stock. You can see my panel at steinair.com.
good luck --- it seems to take a bit of cutting and tweeking to get
it right.
dave
On Feb 22, 2007, at 3:10 PM, Wayne wrote:
canopy fuselage. It appears that the brace to the instrument panel
centers the ideal location for an attitude indicator. Does everyone
just put up with offset instruments?
including the harness (SL 30 and SL 60). The space ahead of the
instrument panel and the bulkhead is only about 9 inches. Do you
have to hack holes in the bulkhead.
Wayne Owens
jc(at)INFONET.COM.BR Guest
Posted: Thu Feb 22, 2007 4:59 pm Post subject: Instrument panel |
Helo Wayne:
I´ve got this problem too. What I did was to cut a hole in the rear panel to fit the radio
and reinforced the panel with a frame made of 1/2" L beans.
The brace had to be cutted too, in order to install the airspeed in a simetric good position.
Another L reinforced was rivetted on the brace.
No problem , till now.
RV-9A
90997
flying
165 h
JC - Aracaju - Brasil
matthew(at)n523rv.com Guest
Posted: Sun Feb 25, 2007 4:41 pm Post subject: Instrument panel |
Wayne,
I did the modification to move the support ribs over several inches to allow for a 'centering' of the instruments. It was a bit of work and I probably wouldn't do it again. Primarily because it puts that center instrument dead in line with the support rib between the fw and subplanel. On my panel, right below the AH I have a KI-209A CDI that is fairly long and I had a helluva time getting the connector attached to it because the wires couldn't come straight into the back.
Personally, stick with the stock setup and just offset the instruments a bit. It may save you some headache down the road.
Matthew
RV-9A :: N523RV
www.n523rv.com
chenoweth(at)gwi.net Guest
Posted: Mon Feb 26, 2007 11:59 am Post subject: Instrument panel |
Matthew,
I think that's great advice - plan to follow it.
Bill
Albion, Maine
RV9 last third (I hope) of fuselage)
bill(at)repucci.com Guest
Posted: Mon Feb 26, 2007 1:06 pm Post subject: Instrument panel |
Gang,
Moving that rib is easy, very easy.
Check out the entries on this page: http://www.repucci.com/bill/instruments.html, starting at 1/9/06.
FWIW, I did not install the rib to the right of my Dynon, only the left rib.
Another local builder (-7A) simply used a small section of angle to attach the 1/2 rib in place.
Good luck,
Bill
www.repucci.com/bill/baf.html
Posted: Mon Feb 26, 2007 1:15 pm Post subject: Instrument panel |
Wayne,
Somewhere in the instructions they tell you that it is acceptable to cut
as many holes in that sub-panel as you need.
The trick is to support the radios and anything else that passes through
it.
This picture will give you a good idea of how I supported my radio and
transponder: http://www.repucci.com/bill/panel/radio%20stack%202.jpg
FYI, I made every effort to mount as much of my gear on the forward side
of the sub panel so you wouldn't see it with the canopy up. (I am
building a tip-up.) Because of this, I have mounted everything with
plate nuts and cap screws. Here is a picture of my Dynon blind encoder:
http://www.repucci.com/bill/instruments.html. If you blow it up, you
will see the black cap screws holding it in place.
Another trick I did was to put plate nuts on the bottom of the ribs and
sub panel lip so I could use Adel clamps and cap screws to hold all the
wires in place. Check out this picture:
http://www.repucci.com/bill/panel/ems%20wiring.jpg
Good luck,
Bill
aurbo(at)ak.net Guest
Posted: Tue Feb 27, 2007 6:22 am Post subject: Instrument panel |
Bill, Wayne,
Bill, Great Photos and ideas. I have used many of your ideas in the wiring
of my RV-9. I especially found useful the idea about the Adel clamps on the
bottom of the ribs.
Many thanks,
Mike Ice
wiring done, slider canopy under construction
russra(at)alltel.net Guest
Posted: Tue Feb 27, 2007 8:28 am Post subject: Instrument panel |
Wayine: It's not the length of the radio it's the location in the
panel. Purchase the glove box and put it in. That will give you good
experience on how to cut the hole. Ron Russ EAA 286
Posted: Tue Feb 27, 2007 8:35 am Post subject: Instrument panel |
Thanks Mike.
FYI - The reason I suggest using cap screws is so that they can be
easily removed in places you can't see to get a screw driver on a
Philips head screw.
I HIGHLY recommend this set from Sears:
http://www.sears.com/sr/javasr/product.do?cat=Hand+Tools%2C+General+Purp
ose&pid=00947477000&vertical=TOOL&subcat=Wrenches&BV_UseBVCookie=Yes
Although the set does not come with a hex bit, it does accept standard
size bits, so you might already have one in your shop.
I have also elected to use stainless steel 8-32 cap screws for my fuel
tank covers. By using this tool, the screws are very easy to insert and
remove.
Just another tip I thought I would pass along.
Bill
BAGSTERJR(at)msn.com Guest
Posted: Tue Feb 27, 2007 7:40 pm Post subject: Instrument panel |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Sears link is not working, do you have a catalog # to reference the set you are talking about?? Thanks Bill
gbrasch
Posted: Tue Feb 27, 2007 8:06 pm Post subject: Instrument panel |
Ditto for me too...
Glenn Brasch, Tucson, Arizona, KRYN.
RV-9A Finish kit #90623, 1953 Piper Tri-Pacer
Van's Aircraft Belt Buckles
http://home.earthlink.net/~gbrasch/
_________________ Glenn Brasch
RV-9A Flying
Medevac Helicopter Pilot (Ret)
Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com |
streiker
Posted: Tue Feb 27, 2007 8:11 pm Post subject: Instrument panel |
If you paste both halves of the link together in the URL line of the brower you’ll get the right page.
From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of WILLIAM AGSTER
Sent: Tuesday, February 27, 2007 7:38 PM
To: rv9-list(at)matronics.com
Subject: Re: Instrument panel
_________________ Stephen D Streiker |
Posted: Wed Feb 28, 2007 7:39 am Post subject: Instrument panel |
Wayne,
I put in the map box and ended up removing it. That sucker takes up a lot of
panel space. Cutting holes in the sub panels is not that hard. Make some
lines and fire up your die grinder with a cut off wheel and go for it.After
you get the holes cut use some angle stock as a brace to reinforce where
ever you cut.
Mike Ice
Posted: Wed Feb 28, 2007 8:04 am Post subject: Instrument panel |
It looks like the Sears site is down.
I think the part number might be: 00947477000
However, to help out I took a picture of my tool set and posted on my web site: http://www.repucci.com/bill/images/Craftsman%20Key.jpg
Oh, sorry, wrong tool.
This is the correct one: http://www.repucci.com/bill/things/sears%20tools%202.jpg
The bits are replaceable and the wrenches are reversible.
Hope that helps.
Bill
Posted: Wed Feb 28, 2007 11:18 am Post subject: Instrument panel |
The Sears site is back up.
Go to www.sears.com and enter in the part number listed below (00947477000) for details.
Bill
