Solid riveting spar - setting solid AN6 rivets
Goto page Previous  1, 2
rickpitcher
PostPosted: Thu Mar 01, 2007 9:31 am    Post subject: Re: Solid riveting spar - setting solid AN6 rivets Reply with quote
---[/quote]
The bucking bar I have is pretty substantial, as is the table, even if it is wood, but the table may be contributing to not getting a full set on the rivet. I'll try it with the bar on the concrete floor.[/quote]
I've been told that my posts appear blank in the web-based matronics list, so I'll repeat myself here on the web-based list... :
Try it with the rivet gun in one hand and the bucking bar in the other, or
get someone else to hold the bucking bar. That's the way I was taught many
years ago, it's still the prefered method. Springs and tables are just gonna
add complexity to a simple operation.
Rick Pitcher
millions of rivets shot, only a couple hundred drilled out Wink
Lockheed, Northrop, Grumman... retired and STILL shooting rivets
ashontz
PostPosted: Fri Mar 02, 2007 1:56 pm    Post subject: Re: Solid riveting spar - setting solid AN6 rivets Reply with quote
Rick Pitcher
Lockheed, Northrop, Grumman... retired and STILL shooting rivets[/quote]
Thanks, but I actually like the way the springs hold the assembly. I had to work real hard if I wanted to mess up a rivet that way. Plus, I can't see how holding the bucking bar is going to give you the best set. Obviously if you're riveting a wing skin in the middle and the other skin is already on, you have no choice but to hold the bucking bar. This is a different situation. Thanks though.
ashontz
PostPosted: Sat Mar 03, 2007 8:01 am    Post subject: Re: Solid riveting spar - setting solid AN6 rivets Reply with quote
Tried it on the garage floor. Worked much better. The gun may still be anemic but it go the job done. All are now .270-.280. That should be sufficient.
naumuk(at)alltel.net
PostPosted: Sat Mar 03, 2007 8:56 am    Post subject: Solid riveting spar - setting solid AN6 rivets Reply with quote
A-
Arnie, Arthur, whatever- get yourself a big chunk of steel (I used 1"
thick) and you can get up off your knees.
Bill Naumuk
HDS Fuselage
Townville, Pa
planecrazydld(at)yahoo.co
PostPosted: Sat Mar 03, 2007 9:51 am    Post subject: Solid riveting spar - setting solid AN6 rivets Reply with quote
ashontz
PostPosted: Sat Mar 03, 2007 10:00 am    Post subject: Re: Solid riveting spar - setting solid AN6 rivets Reply with quote
naumuk(at)alltel.net wrote:
A-
Bill Naumuk
HDS Fuselage
Townville, Pa
Andy.
The block I have is about 1 1/2"x 2" x 4". It's pretty hefty. Worked better on the ground. I'm done now with the spar rivetting. It did need to be done on the floor though. The riveter probably was marginally up to the task.
Flydog1966(at)aol.com
PostPosted: Sat Mar 03, 2007 1:28 pm    Post subject: Solid riveting spar - setting solid AN6 rivets Reply with quote
In a message dated 3/3/2007 1:01:33 P.M. Eastern Standard Time, ashontz(at)nbme.org writes:
Well,unless you made 2 left spars. You now have a compulsive urge to go check,don't you : ) He-He.
Please do not archive
AOL now offers free email to everyone. Find out more about what1227241x4298082137/aol?redir=http://www.aol.com" href="http://pr.atwola.com/promoclk/1615326657x4311227241x4298082137/aol?redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com.
Page 2 of 2
