		tleiss(at)earthlink.net Guest
				 Posted: Thu Mar 01, 2007 4:56 pm    Post subject: 912 Carbs |
				Looking for some help.
  My Rotax 912UL is running very rough at Idle.  Also have fuel running out the vent tubes unless idle is above 2400rpm.    I have rebuilt both carbs (Bing 64) with kits from Bing.  Initial set-up as described in the Bing instructions.   I have synchronize the carbs with duel vacuum gauges.  However, adjusting the mixture screws has virtually no effect in RPM or the vacuum gauge readings.  Ignition is working fine, all new plugs.  All new connectors and good drop-offs when switching A or B (Mag Check).
  I have compared my engines performance with two other 912 equipped planes on the field.  Mine is much rougher at low and medium speeds.
  One question is if the Carb piston vents go towards the intake manifold (as I have them) or the intake.
  Engine has 200 hours (192 by previous owner), 1 hour flight time since I've owned it and the rest are ground runs trying to get it running right.
  Todd Leiss
  Kitfox IV Speedster
  N926JB
  Merritt Island Florida
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Thu Mar 01, 2007 7:07 pm    Post subject: Re: 912 Carbs |
				Hi Todd,
 Question:  Are both carbs actting up in the same way?
 Those vents you describe on the carb throat edges are actually inlets. They must face out towards the air cleaner side or you will have the problems as you describe. These intakes help work the diaphram in the top of your carb for pressure changes.
 If this was the problem your home free, if not:
 One of the things you need to check is your fuel pump pressure. There is a new service bulletin out on certain serial numbered engines that they want these pumps replaced. The symptoms are as you describe. The max pressure (without the manual in front of me) is 5.6 psi and some of these pumps are putting out in the 9psi range.
 This type of pressure will cause what you have described. There is a replacement program as I understand it.
 Your mixture screw should be set at 1.5 turns and left alone. Then you should set the carb's idel screw with the engine off and then while it is running.
 My bet is that your carbs are facing the wrong way.
 Good luck!
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		daveaustin2(at)primus.ca Guest
				 Posted: Thu Mar 01, 2007 7:21 pm    Post subject: 912 Carbs |
				Certainly sounds as if you have a flooding  condition.  What fuel pressure do you have to the carbs?  anything  beyond 4 lbs will overcome the needle valves.  Vent tubes should be in a  place which will sense normal air pressure, not near carb intake.
  Dave Austin  601HDS - 912, Spitfire Mk VIII
  [quote]   ---
				 Posted: Thu Mar 01, 2007 9:30 pm    Post subject: 912 Carbs |
				Some more info on my carb problem:
 My vent tubes are the proscribed length (about 4 inches), and tucked under
 the float bowl spring clip.
 I have new Boots or Flanges.
 Vents under Carb inlets are free. Carbs are facing the correct way.
 Synchronized by the Lockwood method (two Vacuum gauges) adjusting the
 throttle cables as described in a "power-up" article.
 On the bottom of the Carb slide (with long needle valve set at proscribed
 clip position) there are two vent holes.  Do these face the air filter or
 Intake manifold (as I have them)?
 I have a new (Jan 07) Fuel pump from Lockwood.  I had ignition issues,
 which I solved, but around the same time my old fuel pump started to leak.
 The carbs didn't have the fuel running out the vents before the new pump,
 but it never occurred to me that the pump could be the problem.  This may
 very well be the issue.  I will definitely check with Lockwood tomorrow
 concerning the fuel pressure.
 Keep the wonderfully helpful cards and letters coming.
 All the Best,
 Todd
  	  | Quote: | 	 		   [Original Message]
  To: <rotaxengines-list(at)matronics.com>
  Date: 3/1/2007 10:15:21 PM
  Subject: RotaxEngines-List: Re: 912 Carbs
  Hi Todd,
  	  | Quote: | 	 		   This type of pressure will cause what you have described. There is a
  	  | Quote: | 	 		   Your mixture screw should be set at 1.5 turns and left alone. Then you
 running.
		oneniner
				 Posted: Thu Mar 01, 2007 10:00 pm    Post subject: 912 Carbs |
				Check with Lockwood, but I bet the new pump has caused the problem.  The Jabiru engines commonly have this problem, because their fuel pump is not consistent in output pressure.
  I have no personal experience with this, but what I have read (especially on the Jabiru forum)  is that the Bing needs a relatively low fuel pressure, something like 5  or 6 psi max.   If it is too high, the fuel will force past the needle valve and raise the float level too high.  It will run very rich, and leak fuel out the vents as you describe.  There apparently are different needle valves available, and using the wrong one can cause the same problem even with fuel pressure within limits.
  This will be an easy problem  to fix, by making sure you have the proper fuel pressure, and the proper needle and seat in the carbs.
  Again, I am sure Lockwood can provide the specific help you need.
  Gary
  Todd Leiss wrote: [quote]    	  | Quote: | 	 		  --> RotaxEngines-List message posted by: "Todd Leiss" <tleiss(at)earthlink.net> (tleiss(at)earthlink.net)
 All the Best,
 Todd
 From: Roger Lee <ssadiver1(at)yahoo.com> (ssadiver1(at)yahoo.com)
 To: <rotaxengines-list(at)matronics.com> (rotaxengines-list(at)matronics.com)
 Subject: Re: 912 Carbs
 --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com> (ssadiver1(at)yahoo.com)
 Hi Todd,
         	  | Quote: | 	 		  If this was the problem your home free, if not:
 running.
           [Original Message]
 Hi Todd,
      | 	  0 [b]
