		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Fri Mar 02, 2007 9:16 am    Post subject: Flap positioning system |
				Getting ready to order standard build fuse kit. Is the flap positioning system that Vans offers on the order form sufficient, or should I go with some of the other one-touch flap positioning systems? What are those of you flying using? Thanks.
 Eric Kallio
 40518 Fuel tanks (which I waited until last to do)
		Rick S.
				 Posted: Fri Mar 02, 2007 12:54 pm    Post subject: Flap positioning system |
				Eric,
 ALthough not quite ready for flight I would reconsider the Van's offering which is made by showplanes, a well made product and does exactly what you want it to do but the FPS from Aircraft Extras: www.aircraftextras.com has a lot more features, if I had know about it before I would have used Aircraft Extras.
 Just the normal 2 cents worth.
 Rick S.
 40185
  _________________ Rick S.
RV-10
40185 |
		Tim Olson
				 Posted: Fri Mar 02, 2007 8:37 pm    Post subject: Flap positioning system |
				Just have the standard one from showplanes.  No complaints.  I was
 skeptical at first since you only get 2 "real" notches of flaps,
 but as it turns out, it's plenty good for what the plane needs.
 Don't know about any other ones from any experience.
 Eric_Kallio wrote:
  Eric Kallio
		wvu(at)ameritel.net Guest
				 Posted: Sat Mar 03, 2007 8:12 pm    Post subject: Flap positioning system |
				Same here... no complaints.
 Anh
		dogsbark(at)comcast.net Guest
				 Posted: Sat Mar 03, 2007 8:16 pm    Post subject: Flap positioning system |
				Question......I'm in the process of installing the doulbers for the Com antennas and going the typical conduit and alodine approach others have used under the rear seats.  I made the hole in the bottom skin and doubler just large enough for the antenna connection to fit through.  Do I need to make this slightly larger so in the future I can get the BNC (sp) connector through the bottom if I need to make a new connection?  It will be trapped in there otherwise.  Will this cause any problems with grounding?
  This stuff is all new to me.  Thanks for any help.
  Sean Blair
  #40225
