		Lynn Matteson
				 Posted: Sun Mar 04, 2007 11:15 am    Post subject: Speaking of trips...Fla. to Cal. |
				I'm thinking of making a trip from back East...Michigan...via Sun 'n'
 Fun,  then on to California in my Model IV.  For those of you who
 have made the crossing, what advice can you give? I'm a Sport Pilot,
 so I have to stay below 10,000 feet MSL. I'm thinking of the
 Guadalupe Pass, down near El Paso, TX, as I'll be down there visiting
 along the way. Any other ideas as to a safe crossing point?
 Lynn
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		rjdaugh
				 Posted: Sun Mar 04, 2007 12:11 pm    Post subject: Speaking of trips...Fla. to Cal. |
				Lynn,
 Remember it is below 10,000' or up to 1,000' AGL.  So if the ground level is
 9,800' you can fly to 10,800'    etc.
 Randy
  _________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
		Lynn Matteson
				 Posted: Sun Mar 04, 2007 2:29 pm    Post subject: Speaking of trips...Fla. to Cal. |
				I wish you were right, Randy, but according to 2007 Far 61.315 (c)
 "You may not act as pilot in command of a light-sport aircraft:  (11)
 "At an altitude of more than 10,000 feet MSL." I don't see anything
 that allows for 1,000 AGL under the Sport Pilot rules, and believe
 me, I've looked at these rules with the eye of a lawyer (ugh), and I
 can't find a loophole in that 10,000 foot rule.
 I realize that nobody's gonna know...under most circumstances...if
 you got a little high, and if safety became a concern, I'd go a
 little higher, but...
 Are you maybe thinking about the allowance for Recreational Pilots
 who may go to 10,000' MSL or 2,000' AGL, whichever is higher?
 Lynn
 On Mar 4, 2007, at 3:11 PM, Randy Daughenbaugh wrote:
  <rjdaugh(at)rapidnet.com>
  Lynn,
  level is
  Randy
N369LM |
		barry(at)pgtc.com Guest
				 Posted: Sun Mar 04, 2007 2:43 pm    Post subject: Speaking of trips...Fla. to Cal. |
				Lynn, I have made the trip many times, both the southern route and following
 I40, but not in my Model IV.  Most trips were in a C182 and some in a
 Cardinal RG.  I have often considered doing it in the Model IV and would
 love to.  However, I don't camp and don't want to spend many nights in
 motels.
 Either way is about the same, depending on the weather you get, and either
 can certainly be done below 10,000.  Summer is bad because the desert heated
 air gets really rough.  Spring should be OK.  Stay in touch with the centers
 for flight following and it would be wise to stay in gliding distance of the
 Interstates.  Watch out for weather near Guadalupe Peak.  Expect headwinds
 going and tailwinds coming back -- but it doesn't always work that way.
 Barry West
		84KF Guest
				 Posted: Sun Mar 04, 2007 2:50 pm    Post subject: Re: Speaking of trips...Fla. to Cal. |
				!0,000' MSL ...no higher as sportpilot.
 Read on.....
 Federal Register / Vol. 69, No. 143 / Tuesday, July 27, 2004 / Rules and Regulations  Page 44825
 Proposed section 73(b)(6) of SFAR No.
 89 (now § 61.315(c)(11)) would have
 restricted the operation of a light-sport
 aircraft to altitudes of no more than
 10,000 feet above MSL or 2,000 feet
 above ground level (AGL), whichever is
 higher. The FAA received several
 comments on this proposed restriction,
 and nearly all of them opposed it. Most
 stated that allowing pilots to fly at
 higher altitudes would enhance safety.
 Several commenters noted that higher
 altitudes permit safer stall and spin
 recovery training because of the
 increased margin for error. One
 commenter specifically noted that
 visibility is often better above 10,000
 feet MSL, which enhances safety.
 Another commenter offered a similar
 observation, noting that pilots often
 choose to fly at higher altitudes to avoid
 flying through dangerous weather
 systems. Many commenters also noted
 that glider pilots often need to fly at
 altitudes greater than 10,000 feet MSL to
 take full advantage of areas of rising
 warm air, called thermals, which help to
 keep gliders aloft.
 The FAA does not believe that these
 commenters provided valid justification
 for amending the rule. After considering
 these comments and other comments
 expressing concern about sport pilots
 operating in congested, high-altitude
 airspace, the FAA has revised
 § 61.315(c)(11) to be more restrictive.
 The rule now prohibits operations above
 10,000 feet MSL, and the latitude that
 was proposed for operations up to 2,000
 feet AGL, if higher, is removed. The
 FAA is making this revision for the
 following reasons.
 First, operations above 10,000 feet
 MSL require that a pilot have skills and
 training on oxygen requirements and
 medical factors, reduced aircraft
 performance, and the other risks
 associated with operations at higher
 altitudes. The minimum training that a
 sport pilot receives does not encompass
 these additional training requirements.
 Second, given that the aircraft that
 typically operate above 10,000 feet MSL
 are often much larger than light-sport
 aircraft and usually cruise at
 considerably higher speeds, the FAA is
 concerned about permitting light-sport
 aircraft to operate at the same altitudes
 as these aircraft.
 Third, light-sport aircraft typically do
 not have position or anticollision lights
 to help other pilots see and avoid these
 aircraft, which would be beneficial at
 higher speeds.
 Lastly, there are still many areas in
 the United States where operations
 above 10,000 feet MSL do not require
 communication with ATC or the
 equipment required to be easily
 identified on radar by ATC, such as
 transponders. Most light-sport aircraft
 do not have transponders or the
 capability to conduct radio
 communications, reducing their ability
 to coordinate their operations with ATC
 and be easily identified to ensure
 collision avoidance.
 Several commenters disagreed with
 the limit of 2,000 feet AGL, arguing that
 most pilots would prefer, in the interest
 of safety, to clear mountains by more
 than 2,000 feet AGL. The FAA agrees
 with these commenters in that there
 could be circumstances in which a sport
 pilot would need more than 2,000 feet
 AGL to safely clear a mountain.
 However, as discussed above regarding
 training and equipment required for
 high-altitude operations, the FAA does
 not believe it is necessary to permit
 operations above 10,000 feet MSL solely
 for the purpose of crossing mountainous
 terrain. The pilot must determine
 whether it is safe to clear mountainous
 terrain and remain below 10,000 feet
 MSL.
 The FAA is revising § 61.311(c), and
 limiting sport pilot operations at all
 times to below 10,000 feet MSL. The
 FAA believes that this revision will
 simplify the altitude restrictions and
 increase the level of safety.
 If this has been changed since original publication, I will stand corrected.
 Steve
		N81JG(at)AOL.COM Guest
				 Posted: Sun Mar 04, 2007 8:06 pm    Post subject: Speaking of trips...Fla. to Cal. |
				I believe the original proposed rule for LSA had the 1000 ft. AGL in it,  but it was dropped for the final rule. I don't understand the reasoning other  than transponder altitude parallel.
  John Greaves
  VariEze N81JG
 AOL now offers free email to everyone.  Find out more about what's free from AOL at6657x4311227241x4298082137/aol?redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com.
		rjdaugh
				 Posted: Sun Mar 04, 2007 8:27 pm    Post subject: Speaking of trips...Fla. to Cal. |
				Thanks for that Steve.  I will try to find one of my sources.  It was on the
 EAA site.
 My other source was a speaker from the FAA at a picnic last summer.  He was
 asked if a sport pilot could fly into the Leadville, Colorado airport which
 is just 73 feet shy of 10,000'.   The speaker said sure.  - and I thought
 mentioned the 1,000' AGL.  It must have been 2,000'.
 I will see if I can find anything on the EAA site.  If not, I guess I am
 wrong.
 Randy
Kitfox 5/7 912S
		84KF Guest
				 Posted: Sun Mar 04, 2007 8:41 pm    Post subject: Re: Speaking of trips...Fla. to Cal. |
				The 10,000' rule is a pilot certificate issue, and has nothing to do with LSA. also... A pilot holding at least a private certificate may fly a ELSA or SLSA aircraft above 10'000' MSL (if properly equipped.)
   The aircraft in question is an experimental-amateur built being flown under sportpilot privileges, not to be confused with LSA compliant aircraft. Don't worry...seems to be a common misconception.
