Step L angles
naumuk(at)alltel.net
PostPosted: Mon Mar 05, 2007 6:37 pm    Post subject: Step L angles Reply with quote
All-
Have conflicting information. On the old hand-drawn plans for HD/HDSs, there are two L angles riveted to the bottom rear fuse skin that are in turn bolted to the center of the tube that goes spanwise between the steps. No additional internal bracing, just L angles riveted with A5s to the .016 bottom skin. Doesn't seen very sturdy.
On the HD/HDS Cad drawings, there's no mention of the L angles at all!
Input greatly appreciated.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
jeffrey_davidson(at)earth
PostPosted: Tue Mar 06, 2007 1:59 pm    Post subject: Step L angles Reply with quote
Bill,
I asked Nick about this a while back. With the new style steps, the tubes interconnect under the middle of the fuselage and the extruded L's are eliminated. There is no longer any attachment in the middle. The difference is a short larger tube that allows the opposite tube to be captured in the middle.
Jeff Davidson
All-
Gig Giacona
PostPosted: Tue Mar 06, 2007 2:16 pm    Post subject: Re: Step L angles Reply with quote
Actually they are about the same length. Only one flares at the end so the other can fit into it.
W.R. "Gig" Giacona
601XL Under Construction
