franicaza(at)yahoo.com.mx Guest
Posted: Tue Mar 06, 2007 8:24 am Post subject: Nose gear convertion for Classic IV |
Dear friends,
I´m installing the nose gear convertion in my classic
IV and I have two questions:
1. I´ve tried to install the brace that goes in the
belly and ataches into the most forward bracket
support. The thing is that I have to bend the brace up
a little (about 1 1/2") to get the point. I don´t want
to damage it but I don´t find any other way. Is that
correct?
2. Besides, the Grove main landing aluminum spring is
not simetrical. I don´t know if the brake lines that
conect to the inner duct have to be looking to the
tail or to the front. I did not recived Grove
instructions for that. In one way both wheels are a
little forward than the other.
Many thanks in advance,
Francisco Icaza.
___________________________________________________________
La mejor conexión a Internet y <b >2GB</b> extra a tu correo por $100 al mes. http://net.yahoo.com.mx
Lynn Matteson
Posted: Tue Mar 06, 2007 8:51 am Post subject: Nose gear convertion for Classic IV |
My instructions...for the rifle-drilled/gundrilled gear...say "Use
upper gundrilled brakeline exit hole to locate rear edge of landing
gear."
Lynn
On Mar 6, 2007, at 11:24 AM, icaza francisco wrote:
<franicaza(at)yahoo.com.mx>
Dear friends,
correct?
Francisco Icaza.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
iworonko(at)cox.net Guest
Posted: Tue Mar 06, 2007 8:54 am Post subject: Nose gear convertion for Classic IV |
Hi Francisco,
the brake line fittings on Grove gear point towards the tail. I did a nose
gear conversion on my Speedster and nothing had to be bent to make it fit.
You can see some pictures of the conversion at
http://new.photos.yahoo.com/irus58/albums
Eric
GENTRYLL(at)aol.com Guest
Posted: Tue Mar 06, 2007 9:40 am Post subject: Nose gear convertion for Classic IV |
Is this a conversion avaialble from Univar or does John handle them. Can it be used on the older Kitfox's say 1993?
AOL now offers free email to everyone. Find out more 326657x4311227241x4298082137/aol?redir=http://www.aol.com" href="http://pr.atwola.com/promoclk/1615326657x4311227241x4298082137/aol?redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com.
JimmieBlackwell(at)austin Guest
Posted: Tue Mar 06, 2007 10:27 am Post subject: Nose gear convertion for Classic IV |
Be careful. Some Grove gear has the brake line outlets on the front
of the gear, while others have it on the back side of the gear. The
only way to be sure is to go by the direction of the sweep. I
verified this with Grove.
Jimmie
dcsfoto
Posted: Tue Mar 06, 2007 12:23 pm Post subject: Re: Nose gear convertion for Classic IV |
on my 7 the brake line is fwd
dan(at)azshowersolutions. Guest
Posted: Tue Mar 06, 2007 5:19 pm Post subject: Nose gear convertion for Classic IV |
Icaza,
Take a look at this link. http://www.azshowersolutions.com/TriGear.html This is how john McBean attached the weldment to my IV. Hope this helps.
Dan B
Mesa, AZ
icaza francisco <franicaza(at)yahoo.com.mx> wrote:
[quote]--> Kitfox-List message posted by: icaza francisco
Dear friends,
correct?
2. Besides, the Grove main landing aluminum [quote][b]
