Rib sealing
roncarolnikko(at)hotmail.
PostPosted: Fri Feb 03, 2006 9:45 pm    Post subject: Rib sealing Reply with quote
Thanks for all of the feedback on the differant sealers. It seems that an
epoxy is the best method, and the polybrush would seal eveything. With
this info I think I will finish all of my structual building with my West
Epoxy, then brush a thin coat as far as the remainder will go on the wood.
Follow this with a good spray coat of polybrush and I'm In them.
Unfortunately in my preparation for covering I have found more damage done
by the former non-builder. My trailing edges ar now removed and I must
replace all of the aluminum backers for the flaperon attachment points,
epoxy the old rivet holes, and drill the new ones in a sraight line. Hope
to be covering in a week or two now.
shericom(at)rogers.com
PostPosted: Sat Feb 04, 2006 12:31 pm    Post subject: Rib sealing Reply with quote
Ron, Your trailing edge aluminum must have been
installed by the same guy that did mine! I had to do
the exact same thing, I also added the 3/8 alum.
tubing to beef them up. Good luck, Don
Don Stevenson, Caledon, Ontario, Canada
M4/1200-912
and I'm In them.
removed and I must
attachment points,
browse
Subscriptions page,
FAQ,
Admin.
