Lynn Matteson
Posted: Mon Mar 30, 2009 5:33 am Post subject: Near disaster |
Just to throw in some more fodder for debate, I have 2 finger
strainers (one in each tank), and three filters....one in each
downline from the tank and before the header, and one after the
header. These filters are the Purolator glass filters in the 5/16"
fuel line size and since the first application of fuel into the
Kreemed fuel tanks, I haven't seen any crap in these filters. Maybe
that means I don't need all these filters, but I'm not taking them
out. My engine runs on gravity feed only. I have removed all the
pumps (engine mechanical, and back-up electric) because the location
of my carburetor is at a position where gravity alone feeds all the
fuel necessary. The reason I like the filters in the down lines, is
so that if I get a bad batch of fuel, or dirt in the fuel I can see
it immediately...the glass filters are visible just above the top of
the back of the seat, and just below the two fuel shut-offs (for
service only). My system flows 12.3 gallons per hour if I recall
correctly. I should take another reading now that I've installed the
Northstar F210 fuel flow meter, and see what it says the flow rate
is. When I checked the flow rate before I installed the flow meter,
it was through the carb inlet. So that much fuel is getting through
the carb.
p.s. I have all "rubber" fuel lines...automotive 30R7
Lynn Matteson
Jabiru 2200, #2062, 622.1 hrs
Sensenich 62x46
Status: flying
On Mar 29, 2009, at 11:16 PM, darinh wrote:
I agree with Deke...there is no need for filters before the header
tank. When I say I have 3 filters, I am including my finger
strainers as one. I have an Earl's filter before the pumps and a
final filter forward of the firewall just before it goes into the
pressure regulator. Had my final filter not been there, all that
disintegrated hose material would have ended up in my pressure
regulator and carbs so it did serve a purpose. After changing the
hose, it is probably overkill to have the last filter but it is there.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p 36799#236799
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
jdmcbean(at)kitfoxaircraf Guest
Posted: Mon Mar 30, 2009 4:14 pm Post subject: Near disaster |
Jim,
You have received a lot of information worth looking into.. Take a close
look at the fuel pump. I have seen this a few times. Works great for
run-up, taxi etc... but not delivering what's required at the higher RPM's
during T/O.
Give a call if we can be of help.
Fly Safe !!
John McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
JetPilot
Posted: Tue Mar 31, 2009 10:44 am Post subject: Re: Near disaster |
| darinh wrote: | | I agree with Deke...there is no need for filters before the header tank. When I say I have 3 filters, I am including my finger strainers as one. I have an Earl's filter before the pumps and a final filter forward of the firewall just before it goes into the pressure regulator. Had my final filter not been there, all that disintegrated hose material would have ended up in my pressure regulator and carbs so it did serve a purpose. After changing the hose, it is probably overkill to have the last filter but it is there. |
What kind of pressure regulator do you use ? Do you have a 912 ? This is the first I have heard about putting a pressure regulator in the fuel line before the 912, am I missing something ?
Mike
Kolb MK-III Xtra, 912-S |
Roger Lee
Posted: Tue Mar 31, 2009 1:35 pm Post subject: Re: Near disaster |
Hi Mike,
Maybe it was a misquote. There should be no pressure regulator on the 912. You should how ever be at least using the Rotax manual operated pump on the side of the gearbox. It supplies the correct pressure to the carbs. (2.2 - 5.8 psi). Just a gravity fed system would have to be tested for delivered pressure, but I would bet it is too low and because of that during certain flight maneuvers starve the carbs. If you have a low feeding tank then a back up Facet fuel pump rated at the proper psi should be plumbed in parallel as a back up. The manual fuel pump was installed for a reason and should not be removed. My FD CT is a high wing and could operate off a gravity feed, but it should not. When the pump fails it fails open. Plus you are supposed to have a recirculating line to help prevent vapor lock. The fuel pump is in the system to help circulate the fuel. With Rotax having spent millions of dollars and millions of hours testing their engine and helped fix all the owner messed up engines why would anyone want to be a test subject with an $18K engine?
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Mar 31, 2009 5:15 pm Post subject: Near disaster |
My set-up was exactly like Lynns, and will be the same in my new build.
When descending once from the 10,000 ft necessary to clear the Sierras, I
watched the fuel in the filters as the tanks drained to check the operation
of my low fuel indicator. (Consider that I was in a 400 fpm descent that
eventually unported the wing tanks). Shortly after the last of the flow
passed the glass encased filters, the low fuel light came on. I can't count
the number of times I looked at the filters to gauge fuel flow. It is sort
of like the drip chamber in an IV. You can see flow of the fuel when low
vs. just seeing the fuel in a transparent line and having no clue if it is
moving.
I respect rules and other's ideas, but wonder about removing a filter after
it has caught something. I recall the original Kreem controversy when the
Kreem came sheeting off one of the first Alaska flyers and clogged the
finger strainer. All of a sudden there was talk on the list of removing the
finger strainers to eliminate that problem.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
building new
Lynn Matteson
Posted: Wed Apr 01, 2009 4:36 am Post subject: Near disaster |
Yikes! (to the thought of removing the finger strainers...that would
be tantamount to eliminating the oil filter because you found some
junk in it)
I've reported here before about being able to see the fuel presence
in both the glass filters, and the clear vent line, while descending,
and watching the fuel "level" in the vent line predict the eventual
turn-on of the low-fuel warning light...this is with low fuel in the
tanks, and the eventual unporting of the tanks. Seeing this, I was
able to flatten out the glide and restore fuel into the lines, the
light goes out, and all is well for another 15 minutes or so, while a
refueling station is sought out. : ) (Damn, just my luck that the
airborne refueling tankers are taking a coffee break)
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 31, 2009, at 10:11 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
build. When descending once from the 10,000 ft necessary to clear
the Sierras, I watched the fuel in the filters as the tanks drained
to check the operation of my low fuel indicator. (Consider that I
was in a 400 fpm descent that eventually unported the wing tanks).
Shortly after the last of the flow passed the glass encased
filters, the low fuel light came on. I can't count the number of
times I looked at the filters to gauge fuel flow. It is sort of
low vs. just seeing the fuel in a transparent line and having no
clue if it is moving.
filter after it has caught something. I recall the original Kreem
controversy when the Kreem came sheeting off one of the first
Alaska flyers and clogged the finger strainer. All of a sudden
there was talk on the list of removing the finger strainers to
Lowell Fitt
Cameron Park, CA
building new
N369LM |
JetPilot
Posted: Wed Apr 01, 2009 8:24 am Post subject: Re: Near disaster |
I think this fuel system setup will be best, and is how I plan on building my Kitfox. I don't want to rely on a little gravity pressure to drive fuel through a filter, so I will not do that that with this system. Finger strainers in the tanks , then fuel lines to a T at the bottom of the airplane where it will go into the header tank. After the header tank have the gascolator at the low point ( has a pretty fine screen built in ). Then from gascolator to the Electric Facet fuel pump, then to a 10 Micron Stainless Steel Mesh filter the to the engine driven fuel pump then to the carbs.
Any thoughts and comments on this setup would be appreciated.
Mike
Fox5flyer Guest
Posted: Wed Apr 01, 2009 8:38 am Post subject: Near disaster |
Why the gascolator? Seems redundant to me. Your header tank is already
filling that square. The rest sounds good.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
- Joseph Joubert
Lynn Matteson
Posted: Wed Apr 01, 2009 8:58 am Post subject: Near disaster |
Why have a T before you go into the header tank? My header tank
(factory supplied, via Deke...I still owe you a beer or 12, Deke) has
two inlets, and I used them both. With a T before the header, you
have just cut in half the probability that fuel will be able to enter
the header tank.....slim chance of something getting into there and
clogging the down leg of the T, but Mr. Murphy will see to it that it
does.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 1, 2009, at 12:24 PM, JetPilot wrote:
carbs.
Mike
http://forums.matronics.com/viewtopic.php?p 37226#237226
N369LM |
Roger Lee
Posted: Wed Apr 01, 2009 10:37 am Post subject: Re: Near disaster |
Hi Mike,
You shouldn't run your electric pump in series with the mechanical pump. It should be in parallel. This set up was just one of the reasons Rotax had that fuel pump recall. As carb internal parts wear you may get fuel leakage too. I just went through this with another pilot with a pump in series and he had over flow problems caused by pressure. It is recommended to be parallel. When I had my dual pump set up (in parallel) I only used the electric if I would have ever had a fuel issue. I put 960 hrs. on that Rotax 912ULS and never a miss on the engine. I have a high wing fuel tank setup now so I don't use or need an electric pump. Pumps fail open. Several aircraft Mfg's. that have duel pumps now have set them up in parallel. In parallel will still be a good system, but without any headaches.
Tucson, Az.
Cell 520-349-7056 |
Posted: Wed Apr 01, 2009 12:38 pm Post subject: Near disaster |
Mike,
It sounds a little bit complicated to me.
I like the filters between the wing tanks and the header tank for the simple
reason that if a filter clogs - both clog as a worst case scenario, I still
should have 30 or so minutes of flying time after the low fuel indicator
flashes. I had no other filters down stream from that. My early Model IV
had the high mounted header tank so the gascolator was included in the
system. I checked it at annual and never found anything (eight years).
Likely this time, the glass Puralator filters between the wing tank and
header tank will again be the only filters in the system. I can't imagine
foreign material getting past the filters and into a closed system.
The only thing I recall from times past is that the fuel shut off valve
Skystar sent with the kit had "O" ring seals and the early ones were not
fuel friendly and some problems occurred then that a filter would correct
down stream from that. The new "O"rings are now compatable.
I was prepared to mention that I had 909 hours with no fuel related
problems, but that would not be completely accurate as I replaced the engine
compartment fuel lines once and in tightening the clamps around the fire
sleeve, I got a bit rambunctious and pinched off the fuel line a bit. It
idled fine, but I sucked the float bowls dry after about 100 ft. of climb
and had to nurse it a bit to do the return to land downwind - the engine
never quit.
One more thing regarding the finger strainers. At annual, I once found a
piece of black rubber approximately the size of half a pencil erasor in one
wing rank after removing the finger strainer for inspection. It was the
perfect size to be sucked into the fuel line and completerly blocking it
off - a total non issue with the finger strainers in place. I presumed it
came from a piece of debris introduced into the fuel during airport fuel
system maintenance as every gallon of mogas from home went through a Mr.
Filter.
Earlier in this thread mention was made of vapor lock. It is possible to
get a similar problem in the lines from the wing tanks to the header tank.
Make sure they are consistantly running down hill especially at the point of
the excess that allows for wing folding. A slight uphill run can trap air
and the bubble will hinder fuel flow.
Aux. fuel pumps? Mine was in series and just below the header tank. It
helped a bit with the fire sleeve incident, and other than that, I seldome
used it. That said, the on switch was mounted just to the right of the
throttle and I could hit it without moving my hand from the throttle. It
will be in series again. I don't want loops and check valves in the system.
Keep in mind that the Bing carburetors don't want much fuel pressure and the
Facet pumps are available in a 4 psi. unit. I don't understand the physics,
but somehow the extra 4 psi. boost never caused a problem as it loaded the
engine mounted fuel pump. Get the big one and you will be flooding the
engine for sure.
This could go on and on with old wisdom, but don't use teflon tape, and if
using a sealing compound like Fuel Lube, make sure it is used minimally as a
chunk of this stuff could clog jets if it gets into the system, as it simply
won't dissolve in fuel.
Lowell
Lynn Matteson
Posted: Wed Apr 01, 2009 1:03 pm Post subject: Near disaster |
Another thing to keep in mind when running a fuel system.....if at
all possible, use a "bulbed" fuel fitting instead of the barbed
fittings. The bulbed (my term) type have a rounded hump that the hose
slides over, and it is able to be pulled off without shearing off
rubber from the inside of the hose. You might have to shop around to
find them, but it's time well spent.
Lynn Matteson
Sensenich 62x46
Status: flying
N369LM |
pwmac(at)sisna.com Guest
Posted: Wed Apr 01, 2009 3:47 pm Post subject: Near disaster |
Proper name is Beaded tube end. Look in the catalogs and see beading
tools. Never use barbed fittings as you said. If you made that
mistake cut the hose off . Do not pull it off.
Lots of shops both auto and aircraft probably have beader in their
tool collection.
Another advantage is the beaded soft AL tubing can be hand bent to
point is a most desirable direction that a barbed fitting cannot deal with.
Paul
At 12:59 PM 4/1/2009, you wrote:
Lynn Matteson
Sensenich 62x46
Status: flying
Float Flyr
Posted: Wed Apr 01, 2009 4:16 pm Post subject: Near disaster |
I don't know about your header tank but mine doesn't have a drip on it that
drains from the bottom. In fact my header has an almost flat bottom which
would be hard to put an efficient drip into. The gascolator on the other
hand drips forn the lowest point, and it is just about a point, in the fuel
delivery system. It has a glass bowl which is easy to inspect for any
sediment that may get through the finger strainers. And the header tank.
If any is seen it's easy to cut the wire and clean both the screen and the
bowl. Personally speaking I think the gascolator is a great, simple and
useful device to have in the fuel system.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Wed Apr 01, 2009 5:49 pm Post subject: Near disaster |
I was referring to the brass fittings that have the smooth rounded
hump, not the aluminum tubing to which the beading tool is applied.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 1, 2009, at 7:35 PM, paul wilson wrote:
beading tools. Never use barbed fittings as you said. If you made
that mistake cut the hose off . Do not pull it off.
tool collection.
deal with.
Paul
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> Status: flying
N369LM |
Fox5flyer Guest
Posted: Wed Apr 01, 2009 5:56 pm Post subject: Near disaster |
My mistake, Noel. I forgot that the early headers didn't have a sump drain.
In your case and others without the sump drain, then gascolator is a good
plan. Of course, just my opinion and others will vary.
Deke Morisse
Mikado Michigan
- Joseph Joubert
Posted: Thu Apr 02, 2009 7:12 am Post subject: Near disaster |
Yes what you describe is the equal of beaded lines. Good comment.
Paul
At 05:49 PM 4/1/2009, you wrote:
Lynn Matteson
Sensenich 62x46
Status: flying
>tool collection.
>deal with.
>Paul
>>Lynn Matteson
>>Sensenich 62x46
>>Status: flying
If I am not mistaken the gascolator became history when the sump
header tank started shipping. All the is used with the deep sump
header is a final filter. or in many cases the filter before the E fuel pump.
PS, the deep sump header is highly recommended since its volume for
crud is far in excess of any gascolaror.
Paul
sump drain. In your case and others without the sump drain, then
gascolator is a good plan. Of course, just my opinion and others will vary.
Deke Morisse
Mikado Michigan
- Joseph Joubert
ruebd(at)skymail.csus.edu Guest
Posted: Thu Apr 02, 2009 8:18 am Post subject: Near disaster |
Jim:
What was the weather like? Did you use carb heat? I am with those who suspect carb ice. Under conditions of temperature and due point where they are perfect for the formation of carb ice, it happens, and it can be rather fast to form when the conditions are just right for it.
Talk to those who know your engine and its rigging for carb heat and be sure you have the carb ice antidote figured out and installed.
Good luck, and good flying, Duane Rueb N24ZM
Float Flyr
Posted: Thu Apr 02, 2009 11:35 am Post subject: Near disaster |
We're both in the same boat... I didn't know the new headers had sump
drains in them.
Noel Loveys
CDN AME Intern
PP-Rec, Kitfox III-A
Areocet 1100 floats
Kitfox III-A
