Float Flyr
Posted: Thu Apr 23, 2009 4:53 am Post subject: GSC props |
All props require attention. Even the certified props that have the
mounting bolts lock wired need to be checked for tracking, cleaning and
leading edge pitting on a regular basis. Wood props are susceptible to
water damage. They are not the first choice for dodging through clouds but
then again you are not supposed to do that.
I would really like to have seen the prop that came apart on you. I suspect
that prop had prior issues that you are not aware of. It is possible the
tap with the plastic had absolutely the square root of 0 to do with the prop
damage. What I'm thinking is a there was a problem with the lamination of
the wood the blades were carved from or you may have had a stone chip you
were unaware of. BTW what make was that prop?
I think if you check the manual on your Warp drive you will find there is
probably some maintenance you should be doing. As for the retorquing every
other day let's face it you, like me like, exaggerate on occasion.
In this country small bush planes which fly hundreds of hours a year, single
operator, have inspections done every 50 hr. These inspections are not
check the ash trays and change the oil. Every 50 hr. All the control
linkages are checked and cables are checked for tension. All the crap is
removed from under the floor boards. All control surfaces are checked and
the hinges are lubricated. I won't go into the details of either the
airframe or the engine suffice it to say there will be measurements taken of
the props and leading edge dressing done on every inspection. What I'm
getting at here is not to think just because you have a particular appliance
on your plane you can slack off your inspections. I know it's so easy to
do that.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Apr 23, 2009 5:38 am Post subject: GSC props |
And the point is???
In each one of those links either the blade had not been properly inspected
or it had been over torqued. One incident was described twice. The one
exception was the strike which hit squarely on the plastic leading edge. A
warp with the nickel edge may have survived but not necessarily . The last
one where the owner of the aircraft actually milled the hub to be able to
put more crush on an already over crushed prop is one for the books.
To answer my own question the point is; refer to GSC manuals. Carefully
do the prop inspections at regular intervals... 50 - 100 hr. I never
thought of it before but it may be an idea to remove the blades to have a
closer look at the collars. That would be a good idea even on the warp
blades. While you are at it you should be checking the hub for any sign of
cracking or wear.
Noel
Kitfox III-A
matronics(at)bob.brennan. Guest
Posted: Thu Apr 23, 2009 8:08 am Post subject: GSC props |
Noel,
Mike's posts may be badly expressed (alright, sometimes obnoxious (sorry
Mike, but it's true)) but they have made me think a lot more about being
careful and what to check on my old GSC prop, which I had been taking for
granted. Much more so then the "mine works great, never had a problem!"
posts.
I am reassured that all of Mike's links show prop failures due to
negligence, sometimes even stupidity, and if well taken care of they seem to
be a damn good prop.
As I embark on making sure mine is still damn good - I notice the prop roots
are glued into the hub or have some kind of sealant there? I am reluctant to
do too much disassembly on what has been a clean and trouble-free prop, and
maybe be Mike's next link to an accident where "the prop had just been
inspected an hour prior to the fatal accident".
Any recommendations on checking the roots? The plane has always been
hangered and the assembly looks like new, the only thing I have done to the
prop blades is a bit of sanding and a light coat of urethane. But this
thread makes me realise I should do more.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade GSC prop
Wrightsville Pa
Float Flyr
Posted: Thu Apr 23, 2009 10:38 am Post subject: GSC props |
The GSC website and one of the sites Mike was so kind to provide alluded the
roots should be checked for any cracking of that glue. No disassembly
required and can be part of your pre-flight walk around. On an annual basis
I would pull the prop blades and check the through holes for any darkening
of the wood.
My reason for not replacing the old GSC with a new one was the IFA. I
thought it would help get my plane off the water a bit quicker.... I was
right! I found the Ivo to be much smoother but I think that was a factor of
getting the pitch the same on all the blades. I'm glad I didn't find out
about my faulty tachometer until I had the Ivo installed. I think the extra
20 power to the blade could have resulted in a bad day for me.
Noel
Kitfox III-A
lcfitt(at)sbcglobal.net Guest
Posted: Thu Apr 23, 2009 4:05 pm Post subject: GSC props |
This topic has pretty much had it's run with me, but I feel I have to make
one last comment.
Kitfox and Avid have been around since around 1984 as I recall. In the
early days, the GSC prop was standard from the factory and if you were to be
able to get a real good survey of what folks flew with in total, the GSC
prop would be the overwhelming choice - probably in the range of three or
four or more to one vz. the other available props. Also keep in mind that
during the time frame when I bought my first kit (1993), Kitfox was
delivering 40 - read forty - kits a month (that is almost 500 kits a year)
vs. the serious drop of from that in the intervening years (to less than 40
a year when Skystar vanished) and this doesn't account for what Avid sold.
The factory claims 4000 Kitfoxes flying. So if you examined the fleets, you
would find many more Model I through IVs and early Avids than the later
models of both fleets and most flew, at least initially, with the GSC to
many hundreds of thousands of hours.
What does this suggest? If there was a serious problem with the Kitfox or
Avid and this prop, we wouldn't be searching the internet to find five
obscure reports of these props failing and as was suggested, all but one due
to serious neglect - and who really knows for sure about the that one, as
all we have is the word of the guy who broke it. Rather, there would be
numerous reports in the archives and very likely Service Bulletins from both
Kitfox and Avid. We haven't been living in a vacuum. More posts containing
the same arguments don't mean more truth, just more posts and more of the
same arguments. Enough already!
Lowell
Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Thu Apr 23, 2009 4:43 pm Post subject: Re: GSC props |
Noel and others.
I guess I started this thread last week with a question about brakes lines... it morphed into a GSC prop discussion when Dave inquired about my prop. Firstly, everyone's answers about the brake lines were really helpful and yesterday I installed the lines in about 1 1/2 hours... no sweat.
Of greater help to me has been the prop discussion here. I appreciate the "spirited" discussion and the accumulated wisdom of the list members. But I feel that the last post by Noel puts it in perspective. I'm an accident investigator with the Transportation Safety Board of Canada. When we do risk assessments we look at the total population of the aircraft, ship, or locomotive along with the failure rate. I agree with Noel, within the Kitfox community of models 1 - IV there are not enough documented failure to condemn the GCS prop and that safety means constant vigilance, no matter what hardware we fly. I do however now have a greater respect for tolerances and maintenance of the prop that I inherited with my previously owned project.
Lets move on.
Cheers
Ken
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
JetPilot
Posted: Fri Apr 24, 2009 5:41 am Post subject: Re: GSC props |
Lowell,
You observation of the numbers of GSC props sold and reported problems does make a very good point. I have to agree with you, given the numbers of props sold, GSC props are not dangerous if installed properly. I would not take that to mean they are the best prop available now, a lot of advancements have been made in sport propellers since the 1980's when kitfoxes started using GSC props.
This thread has been one of the better ones this forum has seen in a while. A reminder of important maintenance procedures is a a good thing. I think the many people here flying with GSC props will be extra vigilant in making sure their props are properly cared for and properly torqued. This is even better information for those buying a used Kitfox with a GSC prop already on it, they will most likely do a better inspection and re torquing of the prop given the information here.
Mike
Kolb MK-III Xtra, 912-S |
dave
Posted: Sat Apr 25, 2009 2:22 am Post subject: Re: GSC props |
Now that GSC are once again a good prop here is one that I had to fix the broken engine mount on a couple of years ago . This one was always kept indoors, never over tightened. Wood did not seem rotted and blades were not loose.
http://www.cfisher.com/gsc/
Owner was in Mid 80s at the time and noticed on run up something was not right and taxied back to his hangar and a few feet from the door it shed one blade. Usually when a prop departs on a Rotax the carbs jump out of the rubber boots and engine shuts down.
| JetPilot wrote: | Lowell,
Mike |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Sat Apr 25, 2009 3:34 pm Post subject: GSC props |
I notice the glue collar completely separated from the root cuff. That one
may have been caught by a careful inspection of the cuffs.
Noel
Kitfox III-A
