		kelmonroe(at)comcast.net Guest
				 Posted: Tue Mar 18, 2014 2:00 pm    Post subject: Coil lead and Air Speed Indicator conversion. |
				I am in need of the high tension lead wire from the  starting coil to the left mag on my CJ.  The engine I removed was converted  to auto plugs and the wire was removed.
  I also need a shop to send the air speed indicator  out to, to be refaced to knots.  Any help would be appreciated.   Thanks Kelley
				 Posted: Tue Mar 18, 2014 2:17 pm    Post subject: Coil lead and Air Speed Indicator conversion. |
				Kelley,
 Here's a link where you can purchase the 7mm wire you need for the starting coil.
 http://www.mfgsupply.com/24-8775.html
 As far as refacing the airspeed indicator, there are many instrument shops in the Wichita, KS area that may be able to do that for you.  Just Google up "instrument repair shops" and give one a call.
 Dennis
  To: Yak-list(at)matronics.com
  Sent: Tuesday, March 18, 2014 5:00 PM
  Subject: Coil lead and Air Speed Indicator conversion.
    [quote]http://www.matronics.com/Navigator?Yak-Li="nofollow" target="_blank" href="http://www.matronics.com/contributi==
				 Posted: Tue Mar 18, 2014 3:25 pm    Post subject: Coil lead and Air Speed Indicator conversion. |
				I also need the shielding with the nuts to attach  to the coil and the mag.
  [quote]   ---
				 Posted: Wed Mar 19, 2014 5:20 am    Post subject: Coil lead and Air Speed Indicator conversion. |
				Try Doug Sapp.          That I can't help you with.
         	  | Quote: | 	 		  A. Dennis Savarese
 334-285-6263
 334-546-8182 (mobile)
 www.yak-52.com
 Skype - Yakguy1 | 	         On 3/18/2014 6:24 PM, Kelley Monroe wrote:
      [quote]                     I also need the shielding with           the nuts to attach to the coil and the mag.
        [quote]         ---
