Thom Riddle
Posted: Thu Oct 05, 2006 4:22 am Post subject: Vamoose' Ex-Reduction DriveVamoose' Ex-Reduction Drive |
Big Lar,
Thanks for the great photos. ALWAYS enjoy them.
I sure hope you get your speed reducer situation fixed so you can do
your own flight-seeing. I know a direct drive is not going to give you
the performance you want but if you did that as an interim solution
while you saved your pennies for a good speed reducer, at least you
would be able to fly. Of course if your density altitude is too high or
your runway too short then that might not work. Just a thought.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
biglar
Posted: Thu Oct 05, 2006 5:14 am Post subject: Vamoose' Ex-Reduction DriveVamoose' Ex-Reduction Drive |
Thanks, Thom. I just wish I had more time to take those pictures. Full
time would be nice. lol Someday.......??
Me being me, if the plane was flying as a direct drive, procrastination
would probably delay further work indefinitely. The biggest thing
against that, tho', is lower performance in an area known for huge density
altitude compensations, and the Palm Springs area is partly surrounded by
huge mountains, and the remaining areas are mostly MOA's.
Lar. Do not Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
Vamoose
www.gogittum.com
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Thu Oct 05, 2006 6:49 am Post subject: Vamoose' Ex-Reduction DriveVamoose' Ex-Reduction Drive |
Lar/All
It isn't all that bad. I flew for four years with a direct drive VW. With a
direct drive engine a MKIII will be a single place airplane and it will
cruise app 10 mph slower but it is real smooth. The problem Lar would have
is that his engine wouldn't make a good direct drive engine and his engine
mount holds the engine in the wrong direction. Direct drive engines need to
have a modified case and crank that allows for a extra large bearing on the
pulley end to handle prop loads.
Rick Neilsen
Redrive VW powered MKIIIc
