tllaz330(at)gmail.com Guest
Posted: Mon Jan 04, 2016 6:12 am Post subject: AeroElectric-List Digest: 2 Msgs - 01/03/16 |
I am new to the forum. Is this where I can ask a question?
Mike L.
On Mon, Jan 4, 2016 at 2:59 AM, AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete AeroElectric-List Digest can also be found in either of the
of the AeroElectric-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2016-01-03&Archive=AeroElectric
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2016-01-03&Archive=AeroElectric
AeroElectric-List Digest Archive
Total Messages Posted Sun 01/03/16: 2
Today's Message Index:
1. 11:53 AM - Re: Switch question (Robert L. Nuckolls, III)
2. 11:30 PM - Re: Re: Alternator and regulator connections (Bob Verwey)
Time: 11:53:52 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: Switch question
At 11:47 AM 1/3/2016, you wrote:
>Bob,
> I am looking to use the switch that you show in your book,
> labeled 2-10. I have searched for such a switch that I can obtain
> locally, but have not had any success using the S700-2-10
> nomenclature. I believe that you reference Carling switches, but
> have not found one in their catalog. Would you have another number
> that would reference this switch? Thanks.
The S700 series switches are a catalog number
first assigned by the AeroElectric Connection
and later adopted by B&C Specialty Products.
These catalog numbers defined a functionality
in a standard bat-handled, 15/32" mounted toggle
switch. This allowed us to offer switches from
a variety of sources under one part number . . .
a number you will not find cited 'in the wild'.
The 2-10 suffix describes the two pole, three
position, progressive transfer switch as and
on-on-on function. You can order that switch
from B&C as the S700-2-10 or seek out its
equivalent based on functional description
from a host of suppliers . . .
Time: 11:30:06 PM PST US
From: Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)>
Subject: Re: Re: Alternator and regulator connections
What is the function of the AUX connection?
On 1 January 2016 at 09:09, Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)> wrote:
> Bob thanks,
> I have the EFIS alarm so will ignore the warning lite connection.
> On 31 December 2015 at 21:51, Robert L. Nuckolls, III <
> nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
>> At 10:17 AM 12/31/2015, you wrote:
>> Guys thanks for all the replies!
>> So I connected everything as postulated by Joe and Bob, and I am seeing
>> 14.2 volts on the Bus, which I believe to be correct.
>> The only thing is that the warn lite connection shows +12v when the
>> master is turned on, and it does not extinguish when the voltage stabilizes
>> and the amp meter is showing a good charge.
>> As a general rule, alternator failure lights
>> built into regulators are of limited value
>> and should never take the place of ACTIVE
>> NOTIFICATION of low bus voltage. I presume
>> you have this function in place with
>> other hardware. I never hook up the built-in
>> lights.
>> Bob . . .
> Best...
> Bob Verwey
Best...
Bob Verwey
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
-Matt Dralle, List Admin.
FORUMS -
b Site -
jmjones2000(at)mindspring Guest
Posted: Mon Jan 04, 2016 6:50 am Post subject: AeroElectric-List Digest: 2 Msgs - 01/03/16 |
Welcome Mike!
You can ask a question right here. Just reply to this email, or create a new email and send it to: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)
Justin
On Jan 4, 2016, at 05:09, Michael Lazarowicz <tllaz330(at)gmail.com (tllaz330(at)gmail.com)> wrote:
| Quote: | I am new to the forum. Is this where I can ask a question?
Mike L.
| Quote: | *
HTML Version:
Text Version:
>Bob,
> Bob thanks,
>> lights.
>> Bob . . .
> Best...
> Bob Verwey
Best...
Bob Verwey
br> fts!)
FORUMS -
b Site -
user9253
Joined: 28 Mar 2008 Posts: 1973 Location: Riley TWP Michigan
Posted: Mon Jan 04, 2016 8:20 am Post subject: Re: AeroElectric-List Digest: 2 Msgs - 01/03/16 |
I like to go here:
http://forums.matronics.com/viewforum.php?f=3
Then click on "New Topic".
Or
Click on someone else's post, then click on "PostReply".
_________________ Joe Gores |
