skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Fri Sep 23, 2016 6:20 am Post subject: issues? |
Gents,
I filled the cooling unit oil reservoir several times over the past few days. Approximately 250 ml was used in total. In all cases the reservoir slowly emptied, and a steady dripping leak saw observed coming from an unidentifiable unit below the Cooling Turbine (as labeled and observed via borescope.)
I can confirm that there is no leak in the reservoir or the hose running down to the Turbine unit. The leak is internal to the Cooling Turbine and/or the assembly attached below it.
Oil is coming from unit with 3 holes in center of photo. Appears to be from left hand holes only. (Looking up)
FUEL LEAK
A fuel leak has developed out of the overflow pipe located just aft of the large belly panel I had removed to investigate the oil leak. The fuel appears to be coming from a rectangular unit just below the burner cans.
Rectangular unit that fuel is draining from. (Looking aft)
Any further thoughts?
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
583.09 KB |
3501 Time(s) |
482.74 KB |
3501 Time(s) |
667.04 KB |
3501 Time(s) |
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
