Wing walk
whodja
PostPosted: Mon Feb 18, 2019 6:22 am    Post subject: Wing walk Reply with quote
Any recommendations for wing walk material? I have searched the archives and a few recommended the clear from ACS. How’s the durability of the
clear? Any other recommendations?
Tim Olson
PostPosted: Mon Feb 18, 2019 6:42 am    Post subject: Wing walk Reply with quote
I think they're all durable, but I've had people buy the clear who've
not been completely happy in the long run, mainly because it can
yellow and it gets dirty and looks bad then. So it's more common to
go black.
But, if someone else has a different reply, please add it. Mine is
not first hand but second hand.
Tim
cooprv7(at)yahoo.com
PostPosted: Mon Feb 18, 2019 7:21 am    Post subject: Wing walk Reply with quote
I like the black because in addition to not yellowing it gives people a clear image of where it is okay to step.
Marcus
go black.
Tim
bill.peyton
PostPosted: Mon Feb 18, 2019 11:43 am    Post subject: Re: Wing walk Reply with quote
I have the vans black wing walk installed. It’s been 6 years and still looks new. It comes with the cutouts for the screws
Bill
WA0SYV
Aviation Partners, LLC
aerosport1
PostPosted: Mon Feb 18, 2019 11:55 am    Post subject: Wing walk Reply with quote
I totally agree with Tim and Marcus.
FWIW
Geoff Combs
Aerosport Modeling & Design
Marcus
> go black.
> Tim
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
whodja
PostPosted: Tue Feb 19, 2019 4:04 am    Post subject: Re: Wing walk Reply with quote
Thanks guys!
Bob Turner
PostPosted: Tue Feb 19, 2019 9:01 am    Post subject: Re: Wing walk Reply with quote
I did the test - black on one side, clear on the other! They both work, have been durable, but, as Tim said, the clear is near impossible to clean. I’d suggest the black.
Bob Turner
RV-10 QB
tshort
PostPosted: Tue Feb 19, 2019 11:59 pm    Post subject: Re: Wing walk Reply with quote
This is relevant to me as I need to replace the wing walk during the inspection this year. Mine is peeling off (maybe because my airplane is so fast?!? ha)
Any experience with the paint on kind?
What is the best solvent to remove the old wing walk / adhesive without paint damage?
Tim Olson
PostPosted: Wed Feb 20, 2019 5:38 am    Post subject: Wing walk Reply with quote
I removed some in the fall and just used a heat gun to heat it gently,
and then it peeled up without any paint issues.  But it would be
easily possible to pull paint off rivet heads if they're covered.
That said, as long as you're reapplying, you can always paint
the rivet heads and they should stay buried.  Peel towards
the center from all edges first, and that should help ensure
no paint issues.
Tim
http://forums.matronics.com/viewtopic.php?p=487706#487706
Kelly McMullen
PostPosted: Wed Feb 20, 2019 5:43 am    Post subject: Wing walk Reply with quote
If it is the self-adhesive variety, I would recommend gentle use of a heat gun....as I see Tim just suggested.
I would recommend against the brushed-on variety. I've never seen any hand-applied wing walk that looked right.
I'm not sure how paint shops put it on, but they generally do a good job.
Sent from my TRS-80 Model 100
On Wed, Feb 20, 2019 at 1:05 AM tshort <tmshort(at)gmail.com (tmshort(at)gmail.com)> wrote:
--> RV10-List message posted by: "tshort" <tmshort(at)gmail.com (tmshort(at)gmail.com)>
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
